My Notch... going Turbo EFI
Goto page Previous  1, 2, 3 ... 29, 30, 31 ... 36, 37, 38  Next
vwfye
vwfye is offline
PostPosted: Fri Jun 08, 2012 8:48 am    Post subject: Reply with quote
ah, now the micromanaging of the carb jetting will begin. 22.5mpg is unacceptable! going to drop the idle jets from 55s to 50s and see where that takes me. then, possibly smaller main jets.
http://www.thesamba.com/vw/forum/viewtopic.php?t=269496&highlight=speedster <--Notch Speedster
http://www.thesamba.com/vw/forum/viewtopic.php?t=214907&highlight=speedster <--Piece o' Crap
http://www.thesamba.com/vw/forum/viewtopic.php?p=5494415#5494415 <--Beige & POR
Notched
Notched is offline
PostPosted: Fri Jun 08, 2012 10:50 am    Post subject: Reply with quote
I take it you're driving the Notch to the Invasion?
Phillip Bradfield – N.O.N.A. Member 10092
The 1500x1.55 Club
notchback wrote:
This is a Fye project. You actually expect it to happen? Confused
Southern Oregon VW Club -- http://www.sovw.org
Oregon VW Forum -- http://www.oregonvw.org
vwfye
vwfye is offline
PostPosted: Fri Jun 08, 2012 1:25 pm    Post subject: Reply with quote
Haven't decided yet. Working on 3 of them right now to chose from.
Tram Premium Member
Samba Socialist
Tram is offline
PostPosted: Fri Jun 08, 2012 2:14 pm    Post subject: Reply with quote
[stage whisper] Fuel Injection Fuel Injection Fuel Injection Fuel Injection [/whisper]
Give A Pal a Hand!
www.happytrailsfarm.org
May 4, 1970... Never Forget.
RIPRW
"Hell is- other people."- Jean- Paul Sartre
Willo357
Willo357 is offline
PostPosted: Fri Jun 08, 2012 7:52 pm    Post subject: Reply with quote
Megasquirt Megasquirt Megasquirt Megasquirt Megasquirt Wink
http://www.thesamba.com/vw/forum/viewtopic.php?t=4...highlight=
Tram Premium Member
Samba Socialist
Tram is offline
PostPosted: Fri Jun 08, 2012 7:55 pm    Post subject: Reply with quote
Sounds like a personal problem. Maybe less beer? Surprised
Give A Pal a Hand!
RIPRW
vwfye
vwfye is offline
PostPosted: Fri Jun 08, 2012 8:31 pm    Post subject: Reply with quote
I am putting CB's Quick Tune on my Notch speedster. If that goes well, I will look to put EFI on this car too in the future. Right now, the EFI I have has the injectors going into the manifolds, not the throttle bodies, or I would put it on this car right now.
Tram Premium Member
Samba Socialist
Tram is offline
PostPosted: Fri Jun 08, 2012 8:37 pm    Post subject: Reply with quote
What are you gonna do with three running cars? Pick the one that's going to break to drive to the Invasion?
Give A Pal a Hand!
RIPRW
vwfye
vwfye is offline
PostPosted: Fri Jun 08, 2012 8:41 pm    Post subject: Reply with quote
Yep! THat would be my friend Murphy trying to tag along again Wink
vwfye
vwfye is offline
PostPosted: Sat Jun 09, 2012 8:55 pm    Post subject: Reply with quote
Moved my 5" tach from under the glove box to the dash. It fits the hole and doesn't interfere with the hands at all on the steering.
Bobnotch
Bobnotch is offline
PostPosted: Sat Jun 09, 2012 9:59 pm    Post subject: Reply with quote
So did you fix it, when you moved it over? If not, it's hardly worth bothering to do. Rolling Eyes
Bob 65 Notch S with Sunroof
71 Notch ...aka Krunchy; build pics here; http://www.thesamba.com/vw/forum/viewtopic.php?t=240540 -tear down
vwfye
vwfye is offline
PostPosted: Sun Jun 10, 2012 7:56 am    Post subject: Reply with quote
you mean the signal interference? yeah, i swapped out the other tach/shift light as it was the culprit. It works fine without the rev limiter, but together they were fighting. This tach is just a tach and seems to have no issue with the MSD stuff.
vwfye
vwfye is offline
PostPosted: Sun Jun 10, 2012 1:56 pm    Post subject: Reply with quote
working on adding the Air/Fuel meter today. I have the sensor in place and the wire routed, not I just have to decide where to mount the gauge and run the wires...
Toby is going to wire it in so that it is all nice and tidy.
All that is left for 'needs' before the trip is an oil change, and if I can find a type 3 speedo cable, I'll install one of them. I don't think I've had a working speedo in this car since 2003.
Tram Premium Member
Samba Socialist
Tram is offline
PostPosted: Sun Jun 10, 2012 2:06 pm    Post subject: Reply with quote
Damn. It's a new day here on the Samba for sure! Not one, not two, but three Fyekelstangs up and running!Shocked
Wanna buy a Type 4? Such a deal I make you!
Give A Pal a Hand!
RIPRW
vwfye
vwfye is offline
PostPosted: Sun Jun 10, 2012 2:22 pm    Post subject: Reply with quote
no, no, no... only 2 running at the moment. the EFI car won't be running until after i get back.
vwfye
vwfye is offline
PostPosted: Mon Jun 18, 2012 6:06 pm    Post subject: Reply with quote
Been an interesting trip in the notch. My mpg on the 2110 is just over 25 Exclamation But, my AFR is at a staggeringly bad 10.7 to 10.9 below 5k feet and in the high 9s low 10s beyond that.
I've always known that my main jets were too big, but I now have some smaller ones to try.
I also found my idles are too small as I am leaning out to almost 19 when I come off throttle to idle at the end of the off ramp.
I will try some jet changes after I get to Colorado Springs and see how they effect the car on the trip back.
vwfye
vwfye is offline
PostPosted: Wed Jun 20, 2012 9:38 pm    Post subject: Reply with quote
The morning will bring the opportunity to change out the main jets. DCNF carbs require a partial dis assembly to change them... so that will take a bit of time. I will do this in the cool of the morning! After that, we will go sight seeing.
vwfye
vwfye is offline
PostPosted: Thu Jun 21, 2012 7:37 am    Post subject: Reply with quote
Okay, jets are swapped down to 120 on the mains. AFR is a bit better this morning, but the test will be when I get on the freeway at this altitude.
The throttle is more crisp however, that's a nice bonus!
COFBack
COFBack is offline
PostPosted: Thu Jun 21, 2012 7:45 am    Post subject: Reply with quote
bump your timing up a bit too.
I'm still tweaking mine, but 11 degrees at idle (unplugged) made a big difference.
iowegian wrote:
Henceforth he shall be known as "Trameltoe".
Chickengeorge's wife wrote:
bing chow ching fong fang T.J. fang ching dow fong
vwfye
vwfye is offline
PostPosted: Thu Jun 21, 2012 10:04 am    Post subject: Reply with quote
This isn't timing at idle, it is air/fuel ratio.
Page 30 of 38
