vwfye Samba Member
Posted: Sun Jul 13, 2014 12:09 am Post subject: |
2110, after some updates is going back in! _________________ 64 No'back Speedster "Pearl"
1980s Sand Dragster "The Plunger"
LME "Little Giant Killer 3" |
vwfye Samba Member
Posted: Sun Jul 13, 2014 4:42 pm Post subject: |
not in yet, but it is completely buttoned up and awaiting a buddy to come help this old broken guy get it off the stand and onto my motorcycle lift. From there, it is super easy to slide into place. No more balancing on the floor jack! _________________ 64 No'back Speedster "Pearl"
vwfye Samba Member
Posted: Sun Jul 13, 2014 4:56 pm Post subject: |
I need to repaint from the trim line up... Since I can't match what is there, I am looking at a two-tone look. John Jaranson waved his wonderwand and came up with this... I like it!
vwfye Samba Member
Posted: Sun Jul 13, 2014 8:26 pm Post subject: |
very good evening! engine is back in the car and all i need is fuel, oil to put the front seats back in. _________________ 64 No'back Speedster "Pearl"
vwfye Samba Member
Posted: Mon Jul 14, 2014 5:58 pm Post subject: |
I came home and added oil to the purple car. Started it up check everything over to make sure it was okay, and found oil gushing out from underneath the engine! Jacked up the back, crawled under, and found one of my brand new oil lines had split. Got out the bucket, took off the old line and lost some oil, put the new line and clamps on, fired it back up. It seems to be ok, i still have to adjust the idle, add the seats, and then go for a test drive. _________________ 64 No'back Speedster "Pearl"
vwfye Samba Member
Posted: Tue Jul 15, 2014 12:37 pm Post subject: |
Everything, less one carb spring is done. Test drive will be this evening. Only one tiny little oil spot was on the driveway this morning and that was probably residual from the gusher yesterday. _________________ 64 No'back Speedster "Pearl"
vwfye Samba Member
Posted: Wed Jul 16, 2014 1:22 pm Post subject: |
Things are all good other than rear wheel rub on the spring plates _________________ 64 No'back Speedster "Pearl"
vwfye Samba Member
Posted: Thu Jul 17, 2014 1:24 pm Post subject: |
Time to put the air/fuel meter back on the car to see if I'm running lean. My header seems way too hot and I can only think it is too lean. _________________ 64 No'back Speedster "Pearl"
vwfye Samba Member
Posted: Thu Jul 17, 2014 2:42 pm Post subject: |
I just added the LM-1 back to the system and will see if I'm suddenly running from rich to lean. I just have to wait for the new gaskets to set. _________________ 64 No'back Speedster "Pearl"
vwfye Samba Member
Posted: Thu Jul 17, 2014 9:36 pm Post subject: |
I am more confused now. With the AFM installed, my 900 rpm idle is at 13.9- 14.3. At 1800 rpm w/o load it is at 12.6. So at least at idle it isn't lean.
I will drive it tomorrow and see what is happening under load. _________________ 64 No'back Speedster "Pearl"
vwfye Samba Member
Posted: Sun Jul 20, 2014 8:36 pm Post subject: |
No bueno. Did a full tune up, still have extremely hot pipes on 2 & 4. Can't find intake leaks, valves not tight, jets are clear. _________________ 64 No'back Speedster "Pearl"
vwfye Samba Member
Posted: Mon Aug 18, 2014 1:28 pm Post subject: |
If this engine is truely in need of a full redo, I am going to go way from VW power. If I can save what is there, then it will still be a VW in every aspect.
We shall see Wait, you will see
Everett, can you get me a emoticon with a red/white cane added? _________________ 64 No'back Speedster "Pearl"
Bobnotch Samba Member
Posted: Mon Aug 18, 2014 7:37 pm Post subject: |
vwfye wrote: |
We shall see |
Well, you're the "guy"started the "Dark Side", so IF you feel you need to go even deeper, then so be it.
Have you figured out where you're going to put the radiator? How are you going to plumb it? Inline? Or Boxster? VR6?
See, you're already getting questions asked. _________________ Bob 65 Notch S with Sunroof
Tram wrote: |
Tram wrote: |
vwfye Samba Member
Posted: Mon Aug 18, 2014 7:46 pm Post subject: |
The rad will have a puller fan, if that helps _________________ 64 No'back Speedster "Pearl"
vwfye Samba Member
Posted: Mon Aug 18, 2014 8:37 pm Post subject: |
Not yet. _________________ 64 No'back Speedster "Pearl"
Tram Samba Socialist
Joined: May 02, 2003 Posts: 22728 Location: Still Feelin' the Bern- Once you've felt it you can't un- feel it.
Posted: Mon Aug 18, 2014 10:45 pm Post subject: |
I heard it's going Mercedes Diesel, but I swear I'll never tell anyone. _________________ Немає виправдання для війни! Я з Україною.
Bryan67 wrote: |
vwfye Samba Member
Posted: Wed Aug 20, 2014 12:56 pm Post subject: |
i want a quiet drive train Tram... _________________ 64 No'back Speedster "Pearl"
Posted: Wed Aug 20, 2014 12:57 pm Post subject: |
vwfye wrote: |
i want a quiet drive train Tram... |
Huh? _________________ Немає виправдання для війни! Я з Україною.
Bryan67 wrote: |
vwfye Samba Member
Posted: Wed Aug 20, 2014 12:59 pm Post subject: |
I spent almost an hour behind a M/B diesel yesterday trying to get through PDX. My head hurt from the noise. _________________ 64 No'back Speedster "Pearl"
