Max Welton Samba Member
Joined: May 19, 2003 Posts: 10697 Location: Black Forest, CO
vwfye Samba Member
Posted: Wed Aug 20, 2014 4:17 pm Post subject: |
Max, would it effect all four cylinders? Timing is stable at 28 btdc just like I always run it at in this engine. _________________ 64 No'back Speedster "Pearl"
1980s Sand Dragster "The Plunger"
LME "Little Giant Killer 3" |
Tram Samba Socialist
Joined: May 02, 2003 Posts: 22697 Location: Still Feelin' the Bern- Once you've felt it you can't un- feel it.
Posted: Wed Aug 20, 2014 4:39 pm Post subject: |
vwfye wrote: |
I spent almost an hour behind a M/B diesel yesterday trying to get through PDX. My head hurt from the noise. |
What? _________________ Немає виправдання для війни! Я з Україною.
Bryan67 wrote: |
Posted: Wed Aug 20, 2014 4:46 pm Post subject: |
vwfye wrote: |
Max, would it effect all four cylinders? Timing is stable at 28 btdc just like I always run it at in this engine. |
I don't know anything about your ignition system. So I don't know if different timing (such as might result from a distributor shaft that wasn't cut right or a Compufire disk in which the magnets are not correctly positioned) is even possible.
But you said that 2 and 4 are running really hot so I recommend checking the actual timing at each cylinder.
Max _________________ 1967 Type-3 Fastback
Home Stretch https://www.thesamba.com/vw/forum/viewtopic.php?t=767836 |
vwfye Samba Member
Posted: Wed Aug 20, 2014 9:28 pm Post subject: |
at this point Max, appreciate any ideas. It's been such a head scratcher, that nothing is off the table. _________________ 64 No'back Speedster "Pearl"
vwfye Samba Member
Posted: Thu Aug 21, 2014 1:50 pm Post subject: |
I sorted the issue (at least so far it seems so). There was an internal failure in the float bowls of the DCNFs. Fortunately, I had spare parts and all seems happier now! _________________ 64 No'back Speedster "Pearl"
vwfye Samba Member
Posted: Thu Aug 21, 2014 4:02 pm Post subject: |
Yeah, I know. _________________ 64 No'back Speedster "Pearl"
vwfye Samba Member
Posted: Thu Aug 21, 2014 4:10 pm Post subject: |
even my EFI will have a distributor Max. _________________ 64 No'back Speedster "Pearl"
vwfye Samba Member
Posted: Tue Sep 09, 2014 9:50 am Post subject: |
I am going to put the car up on stands and yank the engine back out this fall/winter and go through it completely. I won't be satisfied until it is corrected and I don't' want to use a band-aide.
I am also putting the LeMans wheels back on as the CMS will go on the speester. _________________ 64 No'back Speedster "Pearl"
vwfye Samba Member
Posted: Sat Oct 11, 2014 7:44 pm Post subject: |
No time yet. Today I started working with our 1 HP mode of transportation as well as a new work space. _________________ 64 No'back Speedster "Pearl"
vwfye Samba Member
Posted: Mon Oct 20, 2014 11:30 am Post subject: |
The shop space is coming along nicely. It is 12x12 and the first project that will be in it will be the 1600 rebuild for "White Trashed". After that, the 2110 from the POC will go in. It is going to be so nice to have a dedicated work space!!! _________________ 64 No'back Speedster "Pearl"
vwfye Samba Member
Posted: Sat Nov 15, 2014 12:37 am Post subject: |
I had to scrap my carbon fiber injector holders (for now) and tonight I built them from aluminum. They aren't as cool, but they are functional. _________________ 64 No'back Speedster "Pearl"
vwfye Samba Member
Posted: Sat Nov 15, 2014 2:56 pm Post subject: |
Finished them up and now I just need to make them pretty! Now, I need to pull the engine and inspect the heads, cylinders and rings. _________________ 64 No'back Speedster "Pearl"
vwfye Samba Member
Posted: Sat Nov 15, 2014 6:20 pm Post subject: |
Bobnotch Samba Member
Joined: July 06, 2003 Posts: 22356 Location: Kimball, Mi
vwfye Samba Member
Posted: Mon Nov 17, 2014 9:16 am Post subject: |
Yes if I run shorty air cleaners and no turbo. No if I run the blow through set up...
At this point, the back trunk never gets used anyway except for the second spare on long trips. _________________ 64 No'back Speedster "Pearl"
