vwfye Samba Member
Posted: Mon Nov 17, 2014 12:37 pm Post subject: |
Tonight I am going to try and lay-out the fuel lines, pressure regulator and such in the engine bay.
Even after that all happens, I still need to install the fuel pump, and fit a return line on the car.
I guess, as always, the target is spring and hopefully I will get lots of shop/garage time on the Christ's Mass break. _________________ 64 No'back Speedster "Pearl"
1980s Sand Dragster "The Plunger"
LME "Little Giant Killer 3" |
vwfye Samba Member
Posted: Tue Nov 18, 2014 12:42 am Post subject: |
Type 3 manifolds, throttle bodies, fuel pressure reg all mocked up. I need to shorten my hex bar a bit though.
vwfye Samba Member
Posted: Mon Nov 24, 2014 11:59 am Post subject: |
Well,
I am moving ever closer to a single Type 3. I have decided to pull the 2332 out of the speedster, convert it to type 3 cooling and stuff it in the the notch. While it is in there, the 2110 will get a complete overhaul and then parked as a back up engine.
My goal of making the speedster a track car has gone away, as I just can't swing it financially, and I will concentrate on one car for now.
I'm sure this is the best thing, in the long run, but it still stings a bit to do.
So, this week I will continue to prep the car for the EFI components, pull the 2110 and start working on making the 2332 a type 3 layout. Then, hopefully during Christmas break I can put the 2332 into the car with the EFI and start connecting everything up.
I promise, before I die, this project will be finished! Really!!! I prom-SQUIRREL! _________________ 64 No'back Speedster "Pearl"
vwfye Samba Member
Posted: Fri Nov 28, 2014 4:48 pm Post subject: |
I did a final burn out in the car today when I had to turn it around and back it into the garage. Now that that is happened the car is in a position for the 2110 to come out, and the 2332 to go in.
Perhapsthe pull will happen saturday? Then, next up is making space in the garage for the 2110 to sit until it goes on the stand for a rebuild.
I also am working on an idea for fitting the turbo with the EFI under the stock lid, but I'm not sure if that will work unless I go to a single TB. _________________ 64 No'back Speedster "Pearl"
Salty Samba Member
Joined: April 28, 2010 Posts: 197 Location: Melbourne, Australia
Posted: Sat Nov 29, 2014 5:16 am Post subject: |
Single or dual throttle bodies shouldn't affect the space - you just build a chamber connecting the throttle bodies with boost pipe feeding them from centre
Your biggest issue is getting turbo fitting. I found you need a very small turbo which isn't ideal for larger displacement. |
vwfye Samba Member
Posted: Sat Nov 29, 2014 11:30 am Post subject: |
I will be running my T3 from when the car was draw through. _________________ 64 No'back Speedster "Pearl"
Mike Fisher Samba Member
Joined: January 30, 2006 Posts: 17970 Location: Eugene, OR
Posted: Sat Nov 29, 2014 12:38 pm Post subject: |
Don't worry about keeping your engine under the engine lid in a notch/fasty! _________________ https://imgur.com/user/FisherSquareback/posts
69 FI/AT square Daily Driver
two 57 oval ragtops sold
'68 Karmann Ghia sold
vwfye Samba Member
Posted: Sat Nov 29, 2014 1:54 pm Post subject: |
I'm not worried. But I like the challenge. _________________ 64 No'back Speedster "Pearl"
vwfye Samba Member
Posted: Wed Dec 03, 2014 11:01 am Post subject: |
I have to rent a cherry picker to get the 2332 out of the pink car. Then, I will start prepping it for the POC and a type 3 cooling system.
Normally, it just takes me + 3 buddies... but I don't have any buddies. _________________ 64 No'back Speedster "Pearl"
vwfye Samba Member
Posted: Mon Dec 08, 2014 12:08 pm Post subject: |
Well,
what do you get when your main seal, valve guides and cross hatching on your cylinders are all gone?
My 2110... and lots of oil consumption, lose, dripping.
Boy oh boy... what a mess _________________ 64 No'back Speedster "Pearl"
vwfye Samba Member
Posted: Tue Dec 23, 2014 7:59 pm Post subject: |
I have all the engine tins now to convert the 2332 to type 3 cooling. Looks like I need to get a step stud for the oil cooler and make an extension for the type 1 dipstick. I can fill the engine oil thought the CB Performance breather.
But first... Repaint all the tins. _________________ 64 No'back Speedster "Pearl"
Bobnotch Samba Member
Joined: July 06, 2003 Posts: 22422 Location: Kimball, Mi
Posted: Tue Dec 23, 2014 8:09 pm Post subject: |
vwfye wrote: |
But first... Repaint all the tins. |
Or drill out the type 3 oil cooler, and use a longer 8mm stud in that spot.
That's what I did on the engine I used to have in my Notch (converted t-1), along with the 1 that's currently in it (all aluminum universal case). No big deal, as that spot isn't anywhere near any oil passages. _________________ Bob 65 Notch S with Sunroof
Tram wrote: |
Tram wrote: |
vwfye Samba Member
Posted: Tue Dec 23, 2014 8:12 pm Post subject: |
Well, that seems too simple Bob! _________________ 64 No'back Speedster "Pearl"
Posted: Tue Dec 23, 2014 9:58 pm Post subject: |
vwfye wrote: |
Well, that seems too simple Bob! |
Hey, I like simple.
But, if you like complicated, see if Tram has a conversion stud for you. _________________ Bob 65 Notch S with Sunroof
Tram wrote: |
Tram wrote: |
Tram Samba Socialist
Joined: May 02, 2003 Posts: 22727 Location: Still Feelin' the Bern- Once you've felt it you can't un- feel it.
Posted: Tue Dec 23, 2014 10:18 pm Post subject: |
Bobnotch wrote: |
vwfye wrote: |
Hey, I like simple.
But, if you like complicated, see if Tram has a conversion stud for you. |
Sure, Fye, bring me a late Notchback and I'll fix you right up! _________________ Немає виправдання для війни! Я з Україною.
Bryan67 wrote: |
vwfye Samba Member
Posted: Fri Jan 02, 2015 11:12 pm Post subject: |
It polished up pretty easily! _________________ 64 No'back Speedster "Pearl"
vwfye Samba Member
Posted: Mon Feb 02, 2015 10:54 am Post subject: |
I think we finally have our daily/commuter cars sorted out. So, I can get back to playing with things VW. _________________ 64 No'back Speedster "Pearl"
vwfye Samba Member
Posted: Tue Feb 03, 2015 11:58 am Post subject: |
going to reinstall the turbo and see if i can get over to the 1/8th mile in May. _________________ 64 No'back Speedster "Pearl"
vwfye Samba Member
Posted: Fri Feb 20, 2015 9:39 am Post subject: |
I brought the car to life (still on the DCNF carbs) last evening after a long slumber. I will be driving it Saturday for local car club member's memorial service. We were asked to bring our cars for a cruise in his honor. After that run, the turbo will be installed and hopefully by the May TnT events, I can make a pass.
After driving my truck for such a long time, the car feels tiny and nimble! _________________ 64 No'back Speedster "Pearl"
vwfye Samba Member
Posted: Fri Feb 20, 2015 9:58 pm Post subject: |
The new nose emblem is installed.
