Bryan67 Samba Member
Joined: January 01, 2003 Posts: 2942 Location: Fresno, Ca.
Posted: Thu Dec 19, 2013 7:39 pm Post subject: |
My 68 has 3.5 drop plates, Flat Four/Enkie 5 spoke wheels and 185/65x15 tires and had maybe 1/8 inch of clearance. I had to pull the fender wells out by hand for clearance. It works but barely. _________________ If you`re going to do something, do it right. |
GLHTurbo Samba Member
Joined: March 30, 2009 Posts: 1376 Location: New Jersey
Posted: Wed Jan 22, 2014 3:49 pm Post subject: |
Anyone ever put 16" fuchs on a non-lowered bus? Does it look horrible? _________________ 1957 Beetle
1966 Bus |
Posted: Wed Jan 22, 2014 4:17 pm Post subject: |
I think that on any VW that isn`t lowered looks funny with custom wheels. _________________ If you`re going to do something, do it right. |
Posted: Wed Jan 22, 2014 4:20 pm Post subject: |
Bryan67 wrote: |
I think that on any VW that isn`t lowered looks funny with custom wheels. |
I think you're right. _________________ 1957 Beetle
1966 Bus |
mtb7001 Samba Member
Joined: February 11, 2009 Posts: 899 Location: Meridian Idaho
Posted: Fri Feb 28, 2014 4:30 pm Post subject: |
GLHTurbo wrote: |
Anyone ever put 16" fuchs on a non-lowered bus? Does it look horrible? |
http://www.busselecta.com/bus/ _________________ 63 15 window deluxe Turkis walk through 1500
"comfort the afflicted, afflict the comfortable" |
ricosworld Samba Member
Joined: September 05, 2010 Posts: 57 Location: Oregon
Posted: Sat Mar 01, 2014 8:49 am Post subject: build a bus |
Very cool link, now I sit here and wish I had more buses. _________________ 66 13 window Deluxe
73 Wild Westerner |
sebuno Samba Member
Joined: April 17, 2006 Posts: 32 Location: Toulouse, France
Posted: Sat Mar 15, 2014 6:18 am Post subject: |
Front :
175-55-15 Conti
Dropped spindles + sway a way
Rear :
185-65-15 Bridgestone
1968 Bay IRS Conversion |
OldVolks67 Samba Member
Joined: August 18, 2010 Posts: 159 Location: Boston Metro West
Posted: Fri Mar 21, 2014 10:02 am Post subject: |
sebuno wrote: |
Front :
175-55-15 Conti
Rear :
How do the front tires ride? I am currently running pirellis 195/60/15 and rub way too much up front! I have been looking for 175/55/15 size tire and they are hard to come by in my area. Plus they keep telling me the load rating isn't sufficient. Might have to buy them online and hope someone will mount and
balance the new tires.
I Could use 195/50/15 but I read in here they rubbed for someone else.... |
kingsfanrob Samba Member
Joined: December 24, 2007 Posts: 126 Location: San Dimas
Posted: Fri Mar 21, 2014 10:18 am Post subject: |
I'm running 185/55 in the front and have no rubbing issues. Spindles on a stock width beam.
GarryA Samba Member
Joined: September 28, 2009 Posts: 612 Location: South Carolina
Posted: Fri Mar 21, 2014 11:04 am Post subject: |
kingsfanrob wrote: |
What size and setup are you running in the rear?
And those fronts are 14"? _________________ Where's Garry |
el jeffe Samba Member
Joined: April 28, 2008 Posts: 43 Location: Pittsburgh
Posted: Wed Mar 26, 2014 6:44 pm Post subject: |
Wagenswest flipped spindles
5" narrowed/adjustable beam with wagenswest byob kit
175/55 up front
165/80 in the back
Wagenswest adjustable spring plates
68 beetle trans
Type 3 rear drums |
Smooth60 Samba Member
Joined: February 21, 2007 Posts: 69 Location: PANSCRAPERS Barcelona
Posted: Thu Mar 27, 2014 4:12 am Post subject: |
4'5 Narrowed beam
Flipped spindles
Steering box raise
Narrowed rear torsion housing
Adjustable sping plates
15x4,5 Fuchs 155/60
15x5,5 Fuchs 205/65
_________________ '61 Westfalia So23
'54 Oval window |
Kchulick Samba Member
Joined: October 27, 2004 Posts: 47 Location: Cumming, GA
mandraks Samba Member
Joined: November 28, 2004 Posts: 7050 Location: Lawrenceville, Ga
Posted: Sun Apr 06, 2014 9:21 am Post subject: |
put them on and post some pictures _________________ regards
Uli
Posted: Sun Apr 06, 2014 8:19 pm Post subject: |
GarryA wrote: |
And those fronts are 14"? |
15" Crowsfeet. Rear has drop plates from Old Speed with 185/65's. 67 bug trans with machined early bus drums. |
electronictofu Samba Member
Posted: Tue Apr 08, 2014 6:57 pm Post subject: Combo? |
I'm finishing my front end build and moving to the fun stuff. I have a couple things I'd like some advice on, if you would
Main Q-
My bus came with a Ghia Trans 4.12 Swing Axle (seems healthy but I'd still take it somewhere to check it checked out if I use it, Im not much of a trans guy). My specs are below, Im curious if 4.12 is too tall. Worth investing in a 3.88 trans? Sounds like it may be a little better for freeway and acceleration from what I've seen. My main goal, driving it a lot and being able to pass grandmas on the freeway when needed. Light hills and long trips during the summer.
I don't have a motor! I followed a nice 1600SP build on here with dual kadrons. May go that route, or getting into a 1776.
Rear 195/65/15's
Fronts 165/50/15's
4" narrowed adjustable beam with welded spindles
Offset spring plates from Wide Five
1.5" steering box raise |
cdennisg Samba Member
Joined: November 02, 2004 Posts: 20278 Location: Sandpoint, ID
Posted: Tue Apr 08, 2014 7:28 pm Post subject: Re: Combo? |
electronictofu wrote: |
Main Q-
Rear 195/65/15's
Fronts 165/50/15's
You left out the year of your bus, and what kind of weight it needs to haul around. (empty panel, or loaded Westy) _________________ nothing |
WideFive SBS Hit Squad
Joined: August 20, 2002 Posts: 1147 Location: Litchfield, Ohio
Posted: Tue Apr 08, 2014 7:58 pm Post subject: |
This is a general statement, but run the 4.12R&P, something smaller than a 2liter with a 3.88 R&P isn't going to pull hills well.
I've done 1,000+ mile trips with a 3.88 and a built 1600, it wasn't that fun. Same trans and a 2276, those trips were fun, ha, ha. _________________ Aaron D. Badertscher
Click here for ALL my links. |
Posted: Tue Apr 08, 2014 9:58 pm Post subject: |
WideFive wrote: |
I've done 1,000+ mile trips with a 3.88 and a built 1600, it wasn't that fun. Same trans and a 2276, those trips were fun, ha, ha. |
It's a 65' 13 window. I'll haul stuff here and there, but mostly building it as a normal driver, empty for the most part.
Cool, so smaller builds are generally good for a 4.12 in this situation. What breaks down to a 2Liter? 1915cc-ish? |
joe56vw Samba Member
Joined: June 24, 2004 Posts: 3202 Location: Olympia wa
Posted: Tue Apr 08, 2014 11:10 pm Post subject: |
WideFive wrote: |
1L ==1000cc 1.6L==1600cc and so on
My last bus was a stock 4:12 tranny with a mild 1776cc and it ran great fully loaded or empty
But i was also running 205/65/15 on 5.5" wide rims in the rear if you run a smaller tire combo it will change the ratio _________________ '60 15 window walkthrough
why is there no sarcasism button on here? |
