RockyGun Samba Member
Posted: Mon May 12, 2014 10:05 pm Post subject: |
Ok guys ive been reading and reading and freaking readin and yes I am a noob. I have a 1960 11window walkthrough and Im doing an irs conversion with 4.12 trans and 3.5 drop spindles up front... 1776 with 110 cam 044heads and single weber progressive and 1 1/2 sidewinder exhaust... what size tires should I be running? I dont want to risk rubbing up front but I would like to run same tires all the way around. would a 185/50/15 work for me or a 185/45/15 does that sound about right? or something more like 175/50/15 up front and 185/50/15 in back?
Im using stock 15 bus wheels |
zcruisers Samba Member
Joined: August 08, 2006 Posts: 153 Location: Long Beach, Calif
Posted: Tue May 13, 2014 3:10 pm Post subject: |
Why do you want to be the same size all the way around. You can fit a bigger tire in the rear which will help keep the RPMs down.
Plus it fills up the rear wheel well with more tire. Some people think this looks better. I'm one of those people.
I have a 175/55/15 up front and 195/60/15 in the rear. I only run drop spindles and a straight axle kit in the rear. I never notice any rubbing up front. I like the way it rides.
Good Luck. |
cdennisg Samba Member
Joined: November 02, 2004 Posts: 20278 Location: Sandpoint, ID
Posted: Tue May 13, 2014 6:37 pm Post subject: |
zcruisers wrote: |
Good Luck. |
Keeping the RPM down can be a bad thing. Need that RPM to turn the fan. In his case, that rear tire might be too tall. 195/50-ish is probably better. _________________ nothing |
electronictofu Samba Member
Posted: Sat May 17, 2014 2:06 pm Post subject: |
Wow, the day has come! 4 wheels on the bus! Well 2 as of now. I am trying to fit the rears on today. When I got these wheels they came with a set of low mile 195/65/15's for the rear. Are these too fat to fit in the wheel well? Is there a trick to maneuvering them in?
Swing type 1 rear, long axles, type 3 brakes, offset wide 5 spring plates...
Posted: Sat May 17, 2014 2:09 pm Post subject: |
joe56vw wrote: |
electronictofu wrote: |
WideFive wrote: |
This is a general statement, but run the 4.12R&P, something smaller than a 2liter with a 3.88 R&P isn't going to pull hills well.
I've done 1,000+ mile trips with a 3.88 and a built 1600, it wasn't that fun. Same trans and a 2276, those trips were fun, ha, ha. |
It's a 65' 13 window. I'll haul stuff here and there, but mostly building it as a normal driver, empty for the most part.
Cool, so smaller builds are generally good for a 4.12 in this situation. What breaks down to a 2Liter? 1915cc-ish? |
1L ==1000cc 1.6L==1600cc and so on
My last bus was a stock 4:12 tranny with a mild 1776cc and it ran great fully loaded or empty
But i was also running 205/65/15 on 5.5" wide rims in the rear if you run a smaller tire combo it will change the ratio |
Nice! How the heck did you squeeze those fatties in the wheel well? |
west coast ghia Samba Member
Joined: October 22, 2008 Posts: 200 Location: Antelope, CA
Posted: Sat May 17, 2014 3:00 pm Post subject: |
west coast ghia wrote: |
remove axle from springs plate, install rim and tire, now remount axle to spring plate. |
Shoooooot, so easy. Thanks. Back to the garage. |
durfeec Samba Member
Posted: Sat May 17, 2014 3:56 pm Post subject: |
or scissor jack the spring plate down. _________________ 1960 Bus Panel/Camper |
Posted: Sat May 17, 2014 5:22 pm Post subject: |
I don't have a scissor jack, I'll pick one up at some point. Chances are I'll be doing this again this summer for adjustments. This is how much room I have in the garage on the driver side, photo taken from the kitchen.
Posted: Sat May 17, 2014 6:05 pm Post subject: |
what's your set up at front |
4" Narrowed adjustable beam from WW. 4.5" welded drop spindles also from WW. 1.5" Raised steering box. 165/50's
Been on jack stands since I got it last year. Getting pretty close. |
Posted: Sun May 25, 2014 12:49 am Post subject: |
zcruisers wrote: |
Good Luck. |
I was just wanting to keep em the same so I could have the spare fit both front and rear... think im going to try 175/50/15 in front and 185/60/15 in rear and just get the spare 175/50/15 and call it good |
kingodirtp3 Samba Member
Joined: December 07, 2007 Posts: 1062 Location: Monterey CA
Posted: Fri Jun 06, 2014 10:22 pm Post subject: |
RockyGundersonMusic wrote: |
you don't have enough carb for a 110 and 11/2in exhaust. your engine and you will be much happier and same mileage with a set of kadrons. if you have big valve heads then get the bigger kadrons. loose the progressive, its robbing power. I'm running 215/65/14 tires on widened stock bug rims, 14x6 with 4in backspacing, 1955cc singleport stroker stock geared 4.12 prostreet trans. pulls hard past 5000rpms. heads are ported with bigger intake valves. I can cruise at 80 around 4200 rpms, 70 at 3500rpms. |
DubStyle SBS Hit Squad
Joined: July 26, 2003 Posts: 6250 Location: SBS headquarters: Missery
Posted: Thu Jun 12, 2014 10:20 pm Post subject: |
Man it's been a long time since I could contribute to this thread.
Front narrowed so the tubes were flush to my side plates. Flipped spindles and adjusters
Front tire: 155-60-15
Rear long axles with the rear torsion narrowed 3"
Rear tire: 195-65-15
_________________ Anthony
SBS #1
SBS #1 on FB
"The original & best lowered Split Bus website/club" |
thericklang Samba Member
Joined: July 12, 2012 Posts: 24 Location: Cleveland, OH
Posted: Tue Jun 17, 2014 5:44 am Post subject: |
Just got my 63' done and on the road. Aaron @ Widefive helped me get down with his flipped spindles, 3.5" narrowed beam, and his offset spring plates. 68' T1 swing axle with late T1 brake parts. Empi 9650 shocks up front. Front stock KYB gas-a-just shocks in the rear. 185-55-15 up front and 195-65-15 in the rear.
Posted: Tue Jun 24, 2014 10:17 pm Post subject: |
I found out that federal makes 155/65R14 FEDERAL FORMOZA FD2 75H which is an inch narrower than my 185/55 so that will take care of my tire rubbing issue, now just to do something about the box hitting. |
mandraks Samba Member
Joined: November 28, 2004 Posts: 7050 Location: Lawrenceville, Ga
Posted: Wed Jun 25, 2014 11:51 am Post subject: |
load index of 75 is a 800 pound load rating...
the stock size 185/14 C rated tires have a 1600 pound rating
just saying _________________ regards
Uli
Posted: Wed Jun 25, 2014 3:49 pm Post subject: |
its not a camper, at post a mountain bike and me, I don't get the family in there too often, even though that's only another250lbs at most. no reduction boxes or heaterboxes so 100 or so pounds were removed. |
Posted: Fri Jun 27, 2014 8:27 pm Post subject: |
mandraks wrote: |
just saying |
Stiff sidewalls are the important thing, not load rating specifically. _________________ nothing |
ricosworld Samba Member
Joined: September 05, 2010 Posts: 57 Location: Oregon
Posted: Sat Jun 28, 2014 8:30 am Post subject: |
Before Last July..2013
June 2014
Nate's 3x4 Beam with 944 front Brakes, Spindles and hubs
Rear adjustable spring Plates with Type 3 Swing axel trans
All 5x130mm pattern, 165/50-15 frt and 185/60-15 rear, rear needed wheel spacers. Good ride but need more poop to go...
_________________ 66 13 window Deluxe
73 Wild Westerner |
