OCBuggy Samba Member
Posted: Fri Dec 06, 2013 3:18 pm Post subject: 1776 With Dual 40 Dellorto Jet Question |
Hi all.
I have been visiting the site alot for the last few months. I did alot of reading and finally decided to do my own carb work and not pay some one else.
I was having issues with my dune buggy. The top end was just re done, but the carbs were running rich, leaking and fouling out my plugs. So I took my time and rebuilt both carbs. It was pretty straight forward and i felt pretty confident in the end.
Last night i put everything back together and backed off my idles screws 1 1/2 turns. I fired it up and it ran very well for the first try. I still need to do some mixture screw settings, but i think i am pretty close.
I understand that there are alot of topics on this, but i would like to ask the pros if my carbs are set up for my specific setup.
Eng: 1776
Heads: 40x35.5
Cam: stock
Vents: 34
Airs: 180
Mains: 145
Jets: 60
I live in southern California so im at sea level. When its driven, I go to the high desert witch is around 3-5k ft in elevation.
Thanks you in advance for reading my post, any insight, tips, or improvment ideas will be greatly appreciated.
[/u] |
74 Thing Samba Member
Posted: Fri Dec 06, 2013 4:27 pm Post subject: |
First of all verify your fuel pressure, check and set your floats properly then verify the jet sizes are correct and you can begin jetting.
With your set up I bet you will end up in the 135-140 range for mains and 50-55s for idles. I am guessing 138s for mains and 52s for idles.
Best way to set idles are to pull the main stacks out and just drive on the idles only. Keep going smaller (and adjust the mixture screws each time you make a jet change) and when you get to one that spits and pops then go up one and you are done. |
pumpedto2365 Samba Member
Joined: December 05, 2013 Posts: 48 Location: Phx,Arizona
Posted: Sat Dec 07, 2013 12:14 am Post subject: |
you'll take the guesswork out of the equation if you use a uni-syn gage.
i had the same setup as yours(except bigger cam) and it took a uni-syn to get it purring with no lag or sputtering. |
Paul Wilson Samba Member
Posted: Sun Dec 08, 2013 2:53 pm Post subject: |
I think I would go with 30 mm vents or 32's. 135 mains, 55-60 idles.
Paul |
