Douglas711 Samba Member
Joined: June 21, 2006 Posts: 272 Location: Riverside, CA
Posted: Wed Mar 14, 2007 12:50 pm Post subject: Westfalia MCode Question |
If a vehicle has 523907 in the mcode for the paint code does that mean it is a S0XX camper? Or does it just mean it is a commercial bus by westfalia? If it is a camper where is the S0 code or where is it marked if at all? If not marked how do you figure out what SO it is?
Thanks,
Doug |
fig Samba Member
Joined: August 17, 2000 Posts: 1080 Location: 26.15°S, 28.2°E
Posted: Wed Mar 14, 2007 1:01 pm Post subject: |
That sounds more like the VIN for an October 1959 bus than a paint code. _________________ fig
Kaapse Kombi Kult
"Don't make a fuss, just get on the bus ..." |
Posted: Wed Mar 14, 2007 1:06 pm Post subject: from the technical area |
1963-1967
Westfalia and Commercial Codes
The following codes are usually preceded by 523
where 5 = export model and 23 = Model (Kombi) |
Clara Samba Member
Posted: Wed Mar 14, 2007 8:28 pm Post subject: |
please post your entire M-code plate (make the last 3 digits of the VIN xxx if you are shy) _________________ The Obsolete Air-Cooled Documentation Project http://oacdp.org/ |
Kombi Samba Member
Joined: August 02, 2002 Posts: 562 Location: Edmonton, AB, Canada
Posted: Thu Mar 15, 2007 12:03 am Post subject: Re: Westfalia MCode Question |
Douglas711 wrote: |
Thanks,
Doug |
As Clara said it'd help to see your whole M-plate
523907 would suggest to me pearl white westy
look on your M-plate for something that starts with a letter followed by two #s if it has D23, B35, A42, or something like that then look at this page
http://www.thesamba.com/vw/archives/info/mcodest2.php
to see what westy you have. _________________ Air and Water are needed to survive,
you just can't live as long without air!
Air Riders, VW Club |
Posted: Thu Mar 15, 2007 1:46 pm Post subject: Kombi |
Kombi
Yes I am familiar with the list you provided. From what I can tell it doesn't need to have SOxx to be a westy? If it doesn't have that code there how can you determine what Westy model it is?
Thanks,
Doug |
Major Woody Samba Enigma
Joined: December 04, 2002 Posts: 9010 Location: Portland, OR
Posted: Thu Mar 15, 2007 2:16 pm Post subject: |
If the camper is a late 60s westy, one of the M codes is probably A42, B42, C42 or D42 and another one is 108.
The 108 code refers to the deletion of the side windows because they are replaced with louvered. The _42 code refers to the option package on your camper (if it is an SO-42, the most common late sixties westfalia camper).
The fact that you have the SK907 paint combination on the MCode plate would tend to suggest that the bus left the factory as a kombi intended for conversion by Westfalia, instead of another conversion company. |
Posted: Thu Mar 15, 2007 2:20 pm Post subject: paint |
The mcdoe the bus has is for Westfalia or commercial use. Does it have to have a code to be a westfalia camper.
I found a pic in the gallery of a 67 camper with no such code. Nwo that is of course assuming it is a real westfalia camper
https://www.thesamba.com/vw/gallery/pix/174148.jpg[/url]
///Mink Samba Member
Joined: May 03, 2000 Posts: 5051 Location: Fair Oaks, CA
Posted: Thu Mar 15, 2007 2:21 pm Post subject: |
There has been some discussion here in the past about non-M-coded Westies. They primarily seemed to be european delivery busses. I think most US-bound Westies had the M codes.
So what was your export code from the M plate? |
Posted: Thu Mar 15, 2007 2:24 pm Post subject: |
Doesn't have an export code |
Posted: Thu Mar 15, 2007 2:26 pm Post subject: |
it does have the 430 mcode |
Posted: Thu Mar 15, 2007 2:29 pm Post subject: |
Hmmm. Puzzling. This question is out of my league!!!
Bring in the gimp! |
Posted: Thu Mar 15, 2007 2:43 pm Post subject: Re: paint |
Douglas711 wrote: |
That bus has the B42 Westy M code and the Tourist Delivery (UT) export code... |
Posted: Thu Mar 15, 2007 2:51 pm Post subject: school |
Well school is in session |
Clara Samba Member
Posted: Thu Mar 15, 2007 10:22 pm Post subject: |
no, it doesn't have to have the westy M-code to be a westy.
I had a '65 westy with no westy code.
I think it was brought over by a PO in the Air Force.
I kept an eye out, and it seems that there are a number of euro sold westies that tend to have these features:
no westy code
no port code (blank, not UT)
yes with NA specs
no louvered side windows (no M-code 108)
have steering/ig lock
more likely to be two tone
no electrical outlet (sometimes)
possibly have the 'early' tent mounts rather than the 'later' ones?
They also tend to have more interesting options. _________________ The Obsolete Air-Cooled Documentation Project http://oacdp.org/ |
Clara Samba Member
Posted: Fri Mar 16, 2007 8:06 am Post subject: Re: paint |
///Mink wrote: |
Douglas711 wrote: |
...and that one has M-code 108
here are some no westy code westy M-code tags:
'65 SO-42 w/ dormobile top:
here is another:
a good eye will spot the westy kit from the formica pattern:
Posted: Fri Mar 16, 2007 9:45 am Post subject: Thansk |
Clara,
That is very helpful. I have sent you a pm. Why do you think they made Westfalias and didn't put the code on them? Do you think they might have needed more buses then they ordered and ordered them after the mcodes were stamped?
Thanks,
Doug |
Erik G Samba Member
Joined: October 16, 2002 Posts: 13280 Location: Tejas!
Posted: Fri Mar 16, 2007 10:45 am Post subject: |
Clara wrote: |
no westy code
yes with NA specs
They also tend to have more interesting options. |
agreed
my 64 westy (subhatch)
no westy code
no port of entry code
6 pop out code
steering/ignition lock
2 tone mouse grey/pearl white
no electrical hookups
I don't think it had a subhatch code
the bus had lots of cool oddities _________________ Stop dead photo links! Post your photos to The Samba Gallery! |
crofty Judas of the North
Joined: August 09, 2000 Posts: 19672 Location: Land of Whine and Phonies
Posted: Fri Mar 16, 2007 11:04 am Post subject: |
Erik G wrote: |
Clara wrote: |
no westy code
yes with NA specs
agreed
no westy code
6 pop out code
the bus had lots of cool oddities |
I've never seen a SO22, 33-35 with a electrical hook up. I think that was a So42-44 thing. _________________ Your Vanagon sucks, Stop waving at me.
HamburgerBrad wrote: |
I slept on crofty's tent once. I passed out drunk from two bottles of Everett's brother's wine. |
Posted: Fri Mar 16, 2007 11:05 am Post subject: Re: paint |
Clara wrote: |
Mmmmm SO44... _________________ Your Vanagon sucks, Stop waving at me.
