JKLNHYD Samba Member
Joined: July 21, 2007 Posts: 260 Location: Pasadena, CA
Posted: Sun Nov 06, 2016 8:01 pm Post subject: Re: Official "What oil / additives should I use" topic |
So 203 pages of bs proves that you can run any oil that you choose in your Bug with little or zero difference, because every oil stated has been run for 30+ years by at least one of you, your barber, or a blogger.
Hmmm, sounds good to me...
_________________ Jon
1971 1776 |
rockerarm Samba Member
Joined: December 16, 2009 Posts: 3552 Location: Los Angeles
Posted: Mon Nov 07, 2016 11:54 am Post subject: Re: Official "What oil / additives should I use" topic |
blue65 wrote: |
I like to change the oil in my engine every 1000 miles. But do I also have to change and clean the filter and replace my external filter as well (I have an external filter)? |
Hi. Check this out. May not be 100% applicable to the samba community but is an interesting read:
https://bobistheoilguy.com/forums/ubbthreads.php/t...ost4112079 |
modok Samba Member
Joined: October 30, 2009 Posts: 26781 Location: Colorado Springs
Posted: Mon Nov 07, 2016 9:53 pm Post subject: Re: Official "What oil / additives should I use" topic |
If you are a member there remind them the first years of DI VW engines had a factory recognized problem with turning their oil to smoke in as little as 5000 miles. A good friend of mine bought one, and it sure did.
Perhaps.... if you are adding a quart every 3000 miles, then only have to drain it every 30 thousand miles?
From what I've seen the "I add oil so often I don't need to change it" approach does not work well. Usually causes sludge apocalypse.
I think if you add as much oil as the full capacity then it is time to change it. You keep adding and adding and you are concentrating SOMETHING into a witches brew. The auto companies won't tell you this because they don't want to admit this stuff happens. |
68IHscout Samba Member
Joined: March 10, 2010 Posts: 3122 Location: santa ana ca
Posted: Fri Nov 18, 2016 9:52 pm Post subject: Re: Official "What oil / additives should I use" topic |
I have a 74 I use diesel engine oil 15 40 rotella, i just got a 79 with catalytic converter ,what oil is recommended so it doesn't hurt the cat |
Posted: Fri Nov 25, 2016 8:11 am Post subject: Re: Official "What oil / additives should I use" topic |
68IHscout wrote: |
Any oil will cause a catalytic converter to stop functioning.
Ideally, no oil should be getting anywhere near the cat. If it does, you need to tear the engine apart and possibly rebuild it. _________________ Jon
1971 1776 |
Posted: Fri Nov 25, 2016 9:03 am Post subject: Re: Official "What oil / additives should I use" topic |
68IHscout wrote: |
You need to balance the cost of a replacement cat against the cost of a replacement engine. Personally I would want an oil that I was sure would protect the engine internals. |
Posted: Fri Nov 25, 2016 11:46 am Post subject: Re: Official "What oil / additives should I use" topic |
Wildthings wrote: |
68IHscout wrote: |
a good conventional oil seems to be the practice for catalytic converter cars ,thanks guys for the reply's.. |
Posted: Fri Nov 25, 2016 6:04 pm Post subject: Re: Official "What oil / additives should I use" topic |
68IHscout wrote: |
Wildthings wrote: |
68IHscout wrote: |
Not really. The newest oils are not, and haven't been, spec'd for flat tappet engines for over 10 years. If I had a late converter equipped air-cooled engine I would do one, or both, of these items:
1- Run the 15w-40 robust oil but install a gutted cat housing, or test pipe, til smog check time.
2- Contact a company like Chevron, who uses Boron, in conjunction with the common zinc/phosphorus anti-wear additives and see what their recommendation is for your application. My guess is they will endorse their Chevron Supreme passenger car motor oil. |
Posted: Sun Nov 27, 2016 7:33 pm Post subject: Re: Official "What oil / additives should I use" topic |
rockerarm wrote: |
68IHscout wrote: |
Wildthings wrote: |
68IHscout wrote: |
I think I'll get a regular replacement (with no cat) muffler till smog day ,thanks for the advice much apreciated... |
gingergypsy Samba Member
Joined: April 28, 2016 Posts: 129 Location: Yosemite Valley
Posted: Wed Dec 14, 2016 2:35 pm Post subject: Re: Official "What oil / additives should I use" topic |
maybe i am opening a can of worms here but whatever. I just read through the past 30 pages of BS with no answer to my question.
what would be the secondary option after valvoline vr-1 for a 10w-30? i dont want to buy a whole case, because i want to see how my engine reacts to 10w-30. ive been experimenting with a couple different oils. _________________ Royal Red 1970 Beetle "Elizabeth Bathory"
Currently residing in yosemite valley with Elizabeth, if you are in the park come say hi! |
Posted: Wed Dec 14, 2016 3:47 pm Post subject: Re: Official "What oil / additives should I use" topic |
Hi. What is your particular application? The big deciding factor is what cam/lifters your engine has inside and/or what your engine builder has recommended.
If you have an engine with a mild combination, I see no reason why you could not use any of the following lubricants:
1- A traditional diesel, dual rated motor oil, such as Chevron's or Shell's 15w-40, 30, or 40 oil. Very easily bought in SoCal's area.
2- Shell Rotella 10w-30 oil
3- Chevron's Supreme line of oils. They have pioneered the use of Boron as an anti-wear additive when the zinc-phosphorus was being reduced.
These are a few of the best recommendations for an oil that may meet the original engine oil specs of "SL".
I have used the diesel spec motor oils for approx. 10 years, minimum, on my daily driver cars. A very well respected member here has repeatedly stated that, per the federal gov't, diesel motor oils should not be used in gasoline powered engines. Well, sir, nothing has happened and right now Chevron Delo oil is on sale at O'Reilly's for $14/gallon ($3.50 per qt).
Hope this helps, Bill. |
vwracerdave Samba Member
Joined: November 11, 2004 Posts: 15303 Location: Deep in the 405
Posted: Wed Dec 14, 2016 4:21 pm Post subject: Re: Official "What oil / additives should I use" topic |
Federal regulations (EPA bullshit) for all brands and types of oil has changed tremendously the last 3-5 years. It DOSE NOT matter at all what you did 10 or 20 years ago, it only matters what is going on today and the last few years.
Valvoline VR-1 racing oil comes 6 qts in a case _________________ 2017 Street Comp Champion - Thunder Valley Raceway Park - Noble, OK
Featured in Dec. 2001 HOT VW's Magazine page 63
Watch my racing video's http://www.youtube.com/user/okvwracer/videos |
Posted: Wed Dec 14, 2016 4:49 pm Post subject: Re: Official "What oil / additives should I use" topic |
Roger that racerdave. The bottom line, as I interpret this is, is would you utilize a dual fleet motor oil for a mild/moderate engine to protect its friction areas, in lieu of any gov't concerns about using a diesel rated oil in a gasoline engine?
Thanks in advance, Bill |
Posted: Wed Dec 14, 2016 4:58 pm Post subject: Re: Official "What oil / additives should I use" topic |
vwracerdave wrote: |
Valvoline VR-1 racing oil comes 6 qts in a case |
im aware but im also young and poor and unfortunately for me, if i dont end up needing those extra 3 quarts ill be pissed i spent the money for nothing. _________________ Royal Red 1970 Beetle "Elizabeth Bathory"
Posted: Wed Dec 14, 2016 4:59 pm Post subject: Re: Official "What oil / additives should I use" topic |
rockerarm wrote: |
my beetle is 90% of the time my DD. so thats the application. engine is stock 1600. _________________ Royal Red 1970 Beetle "Elizabeth Bathory"
Danwvw Samba Member
Posted: Wed Dec 14, 2016 5:09 pm Post subject: Re: Official "What oil / additives should I use" topic |
Federal regulations (EPA bullshit) for all brands and types of oil has changed tremendously the last 3-5 years. It DOSE NOT matter at all what you did 10 or 20 years ago, it only matters what is going on today and the last few years. |
An oil carrying an S rating is still fine to use in a gasoline engine. Nothing has changed in the last 3-5 years or the last twenty to thirty years to make an oil that is rated for a gasoline engine unsuitable for use in a gasoline engine just because it also carries a rating for a Diesel engine.
Quit spreading misinformation. |
Posted: Wed Dec 14, 2016 5:23 pm Post subject: Re: Official "What oil / additives should I use" topic |
Hi. The fact that you add an additive to the Castrol GTX tells me that you know this oil, GTX, to be a sub-standard oil. Less than 10 years ago, Castrol put out a memo that their own GTX was not suited for flat tappet cam/lifters.
On the other hand, Mobil 0w-40 is one of the only oils rated for the air cooled Porsche cars.
Bill |
Danwvw Samba Member
Posted: Wed Dec 14, 2016 5:32 pm Post subject: Re: Official "What oil / additives should I use" topic |
Yeah, I have always ran the castrol oil in the air cooled yes for at least 10 years, When I rebuilt the bus engine in 2013 the crank was pretty messed up with pitting, rust, you name it, it was going on. (no zddp back then was ever added) It looked like it had been through hell. But it still ran perfectly. The lifters were worn but were wearing fine. _________________ 1960 Beetle And 1679cc DP W-100 & Dual Zeniths!
Posted: Wed Dec 14, 2016 6:24 pm Post subject: Re: Official "What oil / additives should I use" topic |
gingergypsy wrote: |
what would be the secondary option after valvoline vr-1 for a 10w-30? i dont want to buy a whole case, because i want to see how my engine reacts to 10w-30. ive been experimenting with a couple different oils. |
on my 74 I used vr1 ,but now I run Rotella 15w40 year round here in so cal. |
