Max Welton Samba Member
Joined: May 19, 2003 Posts: 8171 Location: Black Forest, CO
Posted: Mon May 14, 2012 4:48 pm Post subject: |
Is this the first drive of the season? And the difference is between last summer and today?
Max _________________ "Someone" told him it was true. That should be good enough for anybody. |
denver_74 Samba Member
Joined: May 30, 2011 Posts: 210 Location: Northern NY
Posted: Mon May 14, 2012 5:32 pm Post subject: |
no..i've had it on the road for a couple weeks (+/-) and its ran great. change out the oil with gtx 20-50 and it continued to run great. decided to invest in new oil with minerals and the safe choice was vr1 20-50. the engine has approx. 2000 miles on it and other than starting lil hard and feeling as if its lost some performance in runs great..idles nicely, runs smooth etc etc etc
the bug only gets driven in the spring/summer/fall months..never on really cold days
maybe i just tired and there isnt an issue... _________________ 1974 Standard Beetle Sunbug |
DarthWeber Samba Member
Joined: November 24, 2007 Posts: 7557 Location: Whittier,CA
Posted: Mon May 14, 2012 6:39 pm Post subject: |
Forgive me but by "minerals" do you mean zinc and phosphorus? Just asking. I see you are in "northern, NY". Seems you are pretty close to Bradford, PA - Brad Penn Oil refinery. Might want to try some PennGrade 1 10W-30 oil, just a thought. _________________
| Mitey62 wrote: |
| Swapped the Compufire for a Bosch blue and some points I had sitting around, started 1st crank. Took her out for a drive, pulls harder, more RPM, and runs smoother. I think I'll be sticking with points from now on. |
| RockCrusher wrote: |
JB weld the case halves....that'll keep the fretting to a minimum.  |
Posted: Tue May 15, 2012 4:56 am Post subject: |
yes minerals = zinc and phosphorus
(thank you for the brad penn idea..i will check into into it)
i would prefer to get an off the shelf oil and not have to deal with order and delivery.
obviously designer oils are the best...and i may order in future..but for now..what to do.. what to do _________________ 1974 Standard Beetle Sunbug |
Posted: Tue May 15, 2012 5:06 am Post subject: |
| denver_74 wrote: |
| i would prefer to get an off the shelf oil and not have to deal with order and delivery. |
As a rule to get higher ZDDP, you can either buy an oil with a second number of 40 or higher, or buy an oil specifically marketed for high mileage (75,000+ mile) vehicles. Either can be found at Walmart or most any autoparts. |
Posted: Tue May 15, 2012 7:08 am Post subject: |
ok, thanks.
i assume there is not disadvantage on running "high mileage oil" in a low mileage engine....?
and i guessing that my vr1 choice is not correct?? _________________ 1974 Standard Beetle Sunbug |
Glenn  Mr. 010
Joined: December 25, 2001 Posts: 55841 Location: Long Island, New York, USA
Posted: Tue May 15, 2012 8:01 am Post subject: |
| denver_74 wrote: |
| guessing that my vr1 choice is not correct?? |
VR1 "racing oil" was still good on ZDDP numbers the last time I saw an oil analysis on it. You may want to search these sites for VOA's and UOA's to see what the latest numbers are:
http://www.bobistheoilguy.com/forums/ubbthreads.php?ubb=postlist&Board=3&page=1
http://www.bobistheoilguy.com/forums/ubbthreads.php?ubb=postlist&Board=11&page=1
http://www.pqiamerica.com/
If you select an oil labeled as "racing oil" in general it will have higher ZDDP levels but you should do some research to verify. Brad Penn (Penn Grade 1 racing oil) is a proven oil offered in weights that work well with the VW engine. You don't necessarily need to have a higher weight, xxW-40 or xxW-50 to get the proper levels of ZDDP. _________________
| Mitey62 wrote: |
miniman82 Samba Swamp Donkey
Joined: March 22, 2005 Posts: 8859 Location: No F*uck Vagina
Posted: Tue May 15, 2012 8:03 am Post subject: |
| Wildthings wrote: |
| As a rule to get higher ZDDP, you can either buy an oil with a second number of 40 or higher |
Right, because viscosity is directly related to what's actually in the oil.  _________________ Build thread: http://www.thesamba.com/vw/forum/viewtopic.php?t=212747
| mark tucker wrote: |
| make up your own##s.that way you will still sound like an exspert. |
Jake Raby Samba Member
Joined: August 23, 2003 Posts: 6930 Location: Aircooled Heaven USA
| Quote: |
Then you will have to accept the compromise that comes with oil that is formulated ONLY for modern engines, with modern components. These oils are formulated with an emphasis on keeping the engine cleaner rather than better lubricated. _________________ Jake Raby
Raby Engine Development
www.rabyenginedevelopment.com
"I've never given anyone Hell, I just told them the truth and they thought it was Hell" |
Posted: Tue May 15, 2012 8:07 am Post subject: |
ok good information.
i guess here is the big question that will generate the most issue..the weight.
i used 20-50 because thats what dad was using..again i assumed he was either advised or he came to that conclusion on his own...
but from what i understand THAT IS WRONG WRONG WRONG? (or at least wrong for a low mileage engine)
most of the folks that i talk to with vw or air cooled engine experience (including motorcycle and corvair owners) give the rationale that you want the 50w because the engines get so hot etc etc _________________ 1974 Standard Beetle Sunbug |
Posted: Tue May 15, 2012 8:12 am Post subject: |
You want to shoot for 10 psi per 1,000 rpm. Start with as light an oil as you can, 5W-30, 10W-30. Choose an oil with proper zinc and phosphorus levels. In a newer healthy engine this should be all you need. _________________
| Mitey62 wrote: |
Posted: Tue May 15, 2012 8:49 am Post subject: |
...that sounds great but it also sounds as if it would require some additional diagnostics..i don't have tach or pressure/temp gauges set up
valvoline zr1 makes 10w30 dino and its local
but again lnengineering said NEVER 30w blend _________________ 1974 Standard Beetle Sunbug |
Posted: Tue May 15, 2012 9:22 am Post subject: |
| denver_74 wrote: |
ok, thanks.
and i guessing that my vr1 choice is not correct?? |
"High mileage" oil just means that it has added ZDDP as the catalytic converter has already reached the end of its prescribed service life. High mileage oil is available in 5w30, 10w30, and some other weights.
| miniman82 wrote: |
| Right, because viscosity is directly related to what's actually in the oil. Rolling Eyes |
The SM, SN specs for lowered ZDDP do not apply to oils with a first number of 15 or greater, or a second number of 40 or greater. Oils like 5w40, 10w40, and 20w50 are not specced for modern cars where they want to eek out that last bit of gas mileage and need to protect those shiny new converters. Adding a few ppm of ZDDP is not going to change the viscosity of an oil much.
Off the shelf "high mileage" oils tend to have 1100+/- ppm ZDDP verse 800 ppm max for oils that must meet the low zinc spec. |
Posted: Tue May 15, 2012 10:33 am Post subject: |
so bottom line: i am no closer to an answer javascript:emoticon(' ')
oil is very important to an aircooled engine..it acts as lubricant and coolant...i just never really dug into the subject.. there is a lot to consider.
i wish i could put this subject to a vote javascript:emoticon(' ')
"what locally available, brand/weight dino oil should he put in his engine (+/-2000 miles)... without running diagnostics?" _________________ 1974 Standard Beetle Sunbug |
Posted: Tue May 15, 2012 10:52 am Post subject: |
Again, I say look into Brad Penn Penn Grade 1 oil. You are near their refinery. Go to their web site and look up their distributor list. If you have a hot rod/performance shop near you there's a good chance they carry it and have or can get 10W-30. _________________
| Mitey62 wrote: |
Posted: Tue May 15, 2012 11:05 am Post subject: |
(actually i just called a local truck stop and they have it in quarts)
and i want 10w30? nothing higher? despite the fact that everyone says don't use 10w30?? lol
annnnd how about the dino? is it up tp spec? _________________ 1974 Standard Beetle Sunbug
Das Dragon Samba Member
Posted: Tue May 15, 2012 11:33 am Post subject: |
| denver_74 wrote: |
and i want 10w30? nothing higher? despite the fact that everyone says don't use 10w30?? lol |
Umm....everyone who?
I live in the desert south west, it'll be 110* today and I use Brad Penn 10/30 and have since it became available. I would use 5/30 if it was available. _________________ Rest In Peace HamburgerBrad, we will never forget you!
Outside the Bus Table Brackets Available!
http://www.thesamba.com/vw/classifieds/detail.php?id=576723
__________________________________________________________
DB3 said:
"Awesome!!!
*********'s constant over-estimation of his own importance never ceases to amaze me."
With *****, "Bullshit Happens"! |
Posted: Tue May 15, 2012 12:26 pm Post subject: |
lol ok not everyone..many do use it and i am sure it works great
http://www.lnengineering.com/oil.html
"What viscosity motor oil should I use?
You should always refer to your owner's manual for the recommended grade and viscosity of oil to be used in any engine (see chart above for aircooled Porsche engines). A good rule of thumb is your should always have 10psi for every 1000 rpm minimum with the engine and oil hot BUT do not run an oil too thin, as you also have to consider than a lighter oil has lower film strength when hot! It's ok to have the pressure relief bypass some of your oil with the trade-off of a higher HTHS viscosity. If you scroll back up to the top of the frequently asked questions, you'll find a chart showing viscosity recommendations for an aircooled engine which are pretty much the same as you would want to run in any vintage or performance engine unless your engine builder or the engine manufacturer states otherwise.
We are aware of the group of people who believe thinner oils are better for their engines. This is only the case if the engine is of a design requiring thinner oils or can support use of these thinner oils. Where choosing the thinnest oil to maintain the required pressure might seem logical, you have to also consider that you have a thinner oil film and lower HTHS viscosity for that thinner viscosity oil, which provides less protection in areas where metal to metal contact occurs where pressure itself only insures bearing protection, which has not been a problem we've ever experienced using higher viscosity oils like 15w40 and 20w50 viscosities. "
"Additionally, try to use a 5w40 rather than a 0w40, as the viscosity with the narrower spread will have a higher high temperature high shear viscosity and should protect critical engine parts better at the upper limits. You do not need a 0w over a 5w until cold start temperatures are under -25C. Do not run any 0w30, 5w30, or 10w30 oil in your Porsche, aircooled engines included!"
i don't know noth'in. _________________ 1974 Standard Beetle Sunbug |
Posted: Tue May 15, 2012 3:32 pm Post subject: |
i don't have a clue about oil (well, of course i understand weight etc but not specifically to bug engines)...i will be the first to admit it. i know more about motorcycles than i do bugs.
ok..so here is where i am at:
the engine was "good" with 20w50 castrol gtx (why did i use this weight and brand? because this is what my father had been using...no other reason)
having read information regarding zinc etc and having spoke to other classic car owners i decided zinc was good. and not wanting to go the additive route ..i went with an over counter oil: valvoline zr1 20w50
and there was noticeable change in engine performance. not only, did it start harder but did the engine sounded as if it was working harder annnnd to get the same performance feel that i had prior to the oil change...i really had to push the throttle.
i am sorry i don't have any firm data.
i decided i need to make a change..either go with a lighter weight or change brands and weight.
everyone has their favorite and i do consider their opinions as reliable..thank you. BUT i decided to first go with a lighter weight before i changed brands..so i grabbed some zr1 10w30 after work (yes i know what lengineering says but WTH)
before i put it in a decided to give the 20w50 one more chance: it started hard and the engine sounded like it was working hard...plus the engine got very hot in a short amount of time...noticeably hot..more so than with the castrol
out went the 20w50 in went the 10w30
annnnnnnnnnd it started easy and rev'd easy. very much the opposite of the zr1 20w50
its too early to guess whether or not this the right oil..but the initial results are promising.....
and i did find a source for brad penn in the area...but i really don't want to go with synthetic ....or semi-synthtic ..so green oil is out (why? i am old school and don't believe in them new fangled oils..its a religious thing)
any thoughts? questions or ridicules? javascript:emoticon(' ') _________________ 1974 Standard Beetle Sunbug |
