rrcade Samba Member
Joined: May 29, 2010 Posts: 735 Location: WI 1962 Bug 2276
Posted: Wed Apr 08, 2015 10:25 pm Post subject: |
Why do MOST of the big boys with drag cars run 20/50? It's obviously not just "because they saw others were using it" I mean when you have 20,000 or more into a car I would think you would know what you were doing and not just running what other guys in Hot Vws are running?? |
Posted: Thu Apr 09, 2015 3:05 am Post subject: |
rrcade wrote: |
How these big boys operate their engines and what they know and don't know about lubrication has nothing to do with how most ACVW engines are operated. I don't ever give my engine full throttle at idle, rev the $hit out of it and put it under load for a few seconds, and then cut it off, can't hardly think of an easier life for a load of motor oil.
I need an oil that will protect my engine through daily cold starts followed by a 4000' climb day after day, year after year, and worse it has to cold start on a winter evening and then come down that same hill with the engine never really warming up. Sorry, I need a real oil, not what those so called big boys run. |
Glenn Mr. 010
Joined: December 25, 2001 Posts: 76938 Location: Sneaking up behind you
Posted: Thu Apr 09, 2015 3:26 am Post subject: |
rrcade wrote: |
I have more than $20k into mine, will you blindly do what I do?
Drag engine are torn down and rebuilt every few passes, so unless you plan on rebuilding your engine after everytime you drive it, I would not do what drag racers do. _________________ Glenn
Member #1009
#BlueSquare |
Quokka42 Samba Member
Joined: December 02, 2010 Posts: 3117 Location: Melbourne, Australia
Posted: Thu Apr 09, 2015 3:52 am Post subject: |
rrcade wrote: |
That's a pretty wild claim.
When I was doing race engines we kept everything a secret. Sure, old school was loose tolerances and thick oil, but later evidence was that as it did not reach operating temperature a lot of the time in drag applications it would actually cause problems with the rings. But while we were experimenting with thin oils and tight tolerances, we were sometimes beaten by the old school guys...
I've given my opinion - I don't think there's anything wrong with running 20W50 in a VW engine if you need it - usually very hot climate or a worn engine. I haven't needed more than 15W40 in Australia, except in a very tiered engine to keep it going to rebuild (we can actually get a 20W60 here.)
If your boost is such that you suffer fuel dilution of the oil in the course of a run, then the thickest you can get is probably your best bet. _________________ There has only ever been one man who was perfect, and they nailed Him to a cross. |
rrcade Samba Member
Posted: Thu Apr 09, 2015 8:36 am Post subject: |
Glenn wrote: |
Everyone does...... In case you haven't noticed you're kind of a Big Deal around here
But seriously my car has run 20/50 for 15 years since the birth of its 2276 that's street driven and has run 11.80 in the 1/4 Last summer I played with viscosities to see what effect it had on oil temps i didn't see any huge change I'm currently running BP 10/40 but something just don't "feel" right I'm gonna go back to the old 20/50 it's always used but I'll try the BP instead of Dino
My oil temps are more a product of 10.8:1 compression than oil choice and the temps ain't that out of hand |
oilcan Samba Member
Posted: Thu Apr 09, 2015 10:25 am Post subject: |
I found the VR_1 racing syn oil to be more expensive than the same in dino. My experience with motorcycles is that syn oil runs cooler. I have gathered that syn oil is the preferred oil in VW's. So do you think the VR-1 dino works well? And what viscosity? I will not be driving in extreme heat, or cold, and not that many miles per year, 3-4 thousand miles a year, so 2 oil changes a year.
Thanks for responses. |
Posted: Thu Apr 09, 2015 11:09 am Post subject: |
rrcade wrote: |
Okay, explain to me the connection between compression ratio and oil temperatures. Seems odd to me that increasing the efficiency of the engine would raise oil temps. |
modok Samba Member
Joined: October 30, 2009 Posts: 26788 Location: Colorado Springs
Posted: Thu Apr 09, 2015 5:44 pm Post subject: |
Quokka42 wrote: |
You CAN run 20-50 weight but the clearances must be on the loose end, especially rod bearings, .0025" MIN clearance OR the oil needs to be really HOT, as in endurance racing.
My engines are built "old school" so I run 15-40 in hot temps after broken in.
VR-1 dino seems to be GREAT stuff.
10-30 is a normal weight, for normal bearing clearances, and normal temperatures.
Sorry to be a broken record but oil mythology takes a long time to change, like religion! |
Juanito84 Samba Member
Joined: March 17, 2012 Posts: 2436 Location: Colorado Mountains
Posted: Thu Apr 09, 2015 6:54 pm Post subject: |
Wildthings wrote: |
rrcade wrote: |
No. But if you change the air pressure in the spare tire I find that has a huge effect on oil temps! _________________ If a water cooled engine cools its water with air, isn't it just an overcomplicated air cooled engine? |
rrcade Samba Member
Posted: Thu Apr 09, 2015 10:56 pm Post subject: |
I was under the impression that
1. The higher the compression, the higher the combustion efficiency. This means more power.
2. The higher the compression ratio, the higher the temperature in the cylinder
3. Pistons in cylinders are lubricated by oil
4. Oil in contact with a hotter than normal cylinder will get....well "hotter"than normal
Am I completely wrong here?
Thanks for the tip on spare tire, glad I don't have one or my Temps would be off the chart |
Posted: Thu Apr 09, 2015 11:18 pm Post subject: |
rrcade wrote: |
Yes and no. When you are cruising down the same stretch of road with more efficiency the power output will still be the same. Yes, the engine is more efficient, so yes, if the throttle is held open at the same angle as before it will produce more power. But if that happened then the car would be accelerating and would end up going faster. Mind you that even then you only increased the efficiency, meaning more heat is turned into power (which equals less heat). Now add that to the fact that you must close the throttle to cuise at the same speed as before. Now not only are you converting more heat into power but you are also using less fuel and producing less heat. So in the end increasing CR tends to decrease temps.
Now if you are running full throttle that's a different story. _________________ If a water cooled engine cools its water with air, isn't it just an overcomplicated air cooled engine? |
Posted: Fri Apr 10, 2015 12:03 am Post subject: |
If you are always running full throttle you need to build a bigger engine! _________________ There has only ever been one man who was perfect, and they nailed Him to a cross. |
Posted: Fri Apr 10, 2015 12:29 am Post subject: |
Just plainly put, the higher the efficiency the lower the heat output. If your engine were 100% efficient the exhaut temperature would be the same as the intake temp and there would also be absolutely no need to cool the enigine.
If the engine is 50% efficient than only 50% of the energy is being turned into power. The other 50% is being turned into heat. If it's 25% efficent, then 25% turns into power and 75% turns into heat. Etc. etc. etc. _________________ If a water cooled engine cools its water with air, isn't it just an overcomplicated air cooled engine? |
Slow 1200 Samba Member
Posted: Fri Apr 10, 2015 1:42 am Post subject: |
set a stock-cammed engine for 10:1 and see what's your oil temperature |
Posted: Fri Apr 10, 2015 8:54 am Post subject: |
rrcade wrote: |
Glenn wrote: |
I think it's more than just your CR. First of all you have a 2276cc engine. Now for cruising around that's all right. But what about full throttle? Do you have a stock cooling system, or worse, one of those cheap Scat or Empi cooling shrouds? So you increase the amount of fuel the thing burns yet then you decrease cooling or keep it the same? Of course I don't know what cooling shroud you have. Hopefully it's much more powerful.
Also yes, the 10.8 CR can have a lot to do with it. But it's not because you've increased efficiency. Like I've said, if you increased efficiency then you are converting more heat into power so then you end up with less heat. If you over do CR then you have to cut back efficencies elsewhere, like timing back the ignition. Now it's possibly not more efficient, it's quite possibly less efficient so less heat turns into power and more of it heats the engine. Also you likely have a high profile cam. So then you've cut back the dynamic CR. Now it's the dynamic CR that stipulates the efficiency, not the static. You could have a static CR of 20:1, but if your valve timing puts it back at 7:1 then your efficiency is still the same as any 7:1 engine.
Also this is an 11.80 second engine in the quarter mile. Cool! But I just can't see a several hundred horsepower engine like yours just not creating a lot of heat when you put it to use, period. Remember, it's the fuel that you burn that heats the engine. If you cruise along and find you are getting 40mpg, then you should be getting very cool engine temperatures. If you only get 15mpg, then you're burning a bunch more fuel and getting a lot more heat. Now put your foot into it and how many miles per gallon do you think you are getting? All that fuel is burning, and probably less than 15% of it is turning into power. The other 85% is heating the engine and the exhaust.
I think all that has more to do with you needing a 50 weight oil for driving. Also what are your bearing clearances? But no, the 10.8:1 CR isn't in itself causing hot oil. If you made a little efficient fuel sipping engine with a high CR then you most likely would have problems keeping your oil temperature up. _________________ If a water cooled engine cools its water with air, isn't it just an overcomplicated air cooled engine? |
Lingwendil Samba Member
Joined: February 25, 2009 Posts: 3988 Location: Antioch, California, a block from the hood
Posted: Fri Apr 10, 2015 10:15 am Post subject: |
vwracerdave wrote: |
NAPA has VR-1 on sale this month. |
I have several bottles each of this stuff at home, in SAE30 and in 10W/30. Which would I be better off using at my next oil change in my h30/31, header exhaust, 1600SP? Daily driver, about 60-75 miles mixed city/highway driving every day in my 61 rag with the stock ratio transaxle, I cruise at 60-70mph. Engine is within tolerances on endplay and runs great. I currently run o/Reilly brand 10/30 but feel like a bum putting cheap oil in it, just using up the last of it that I had. I know this is a heavy question for most of you religious types, but any suggestions would be appreciated. Also, it's this stuff good for breaking in a new build? I figure it I have it and it works well it'll save a few bucks. _________________ 73 super beetle thread http://www.thesamba.com/vw/forum/viewtopic.php?t=649622 Back on the Road!
Modify your Kadrons for SVDA http://www.thesamba.com/vw/forum/viewtopic.php?p=8115884#8115884
Cast iron VJU4BR8 SVDA reference thread- https://www.thesamba.com/vw/forum/viewtopic.php?t=...mp;start=0
Need replacement filters for original Kadron aircleaners? WIX #42087 is a perfect fit, as is Napa Gold #2087! |
Posted: Fri Apr 10, 2015 12:23 pm Post subject: |
Lingwendil wrote: |
I have several bottles each of this stuff at home, in SAE30 and in 10W/30. Which would I be better off using at my next oil change in my h30/31, header exhaust, 1600SP? Daily driver, about 60-75 miles mixed city/highway driving every day in my 61 rag with the stock ratio transaxle, I cruise at 60-70mph. Engine is within tolerances on endplay and runs great. I currently run o/Reilly brand 10/30 but feel like a bum putting cheap oil in it, just using up the last of it that I had. I know this is a heavy question for most of you religious types, but any suggestions would be appreciated. Also, it's this stuff good for breaking in a new build? I figure it I have it and it works well it'll save a few bucks. |
There is no right and wrong answer. Pick an oil and go with it and see if it works for you and your driving style. |
vwracerdave Samba Member
Joined: November 11, 2004 Posts: 15308 Location: Deep in the 405
Posted: Fri Apr 10, 2015 12:47 pm Post subject: |
Use the 30W during summer when it's 60* or above. You can use the 10W-30 all year long. _________________ 2017 Street Comp Champion - Thunder Valley Raceway Park - Noble, OK
Phil911 Samba Member
Posted: Tue Apr 21, 2015 4:56 am Post subject: |
I just picked up Quaker State Defy 5/30 ... it already has a Zinc additive. I hope it will be ok even though its not Rotella lol
I mean really, theres lots of discussion about this but at the end of the day, does the metal really care as long as its slippery? _________________ 1990 911 Porsche C2 (964) - Sold
1976 VW bug (sold) |
BenJAMin Samba Member
Joined: February 01, 2004 Posts: 461 Location: Michigan
Posted: Tue Apr 21, 2015 5:45 am Post subject: |
It will probably be fine. If you were to be doing something really crazy like racing or something it might be different. |
