15x6 centerlines on a 67 bug...How low can you go?
Forum Index -> Custom Wheel/Tire Share: Facebook Twitter
risk
risk is offline
PostPosted: Thu Mar 22, 2007 9:41 am    Post subject: 15x6 centerlines on a 67 bug...How low can you go? Reply with quote
I am looking at a set of 15x6 centerlines, not sure of the offset...but I was hoping someone could help anyways. Suspension is stock now, but I plan on dropping the front 2-4" soon. Will these wheels fit under the fenders and not rub without having a narrowed beam?
THanks!
risk
rambler1959
rambler1959 is offline
PostPosted: Thu Mar 22, 2007 9:45 am    Post subject: Reply with quote
in the front no... (unlessyou get some realy crazy offset) in the back maybe. do you still have long axles?
risk
risk is offline
PostPosted: Thu Mar 22, 2007 9:48 am    Post subject: Reply with quote
yes, I have the stock setup in the rear...I guess that they are long axles. How do you tell?
Skim
Rants Master
Skim is offline
PostPosted: Thu Mar 22, 2007 10:34 am    Post subject: Reply with quote
measure the length of the end castings on the axle tubes.
52 Split Rag
54 Barndoor 23
GFK
My 61 Impala Vert Build Up Topic Pics
risk
risk is offline
PostPosted: Thu Mar 22, 2007 11:10 am    Post subject: Reply with quote
It is the original setup --build date is sep '66. Should it be long or short?
ashman40
ashman40 is offline
PostPosted: Fri Mar 23, 2007 5:25 am    Post subject: Reply with quote
VW Beetles had three different sized swing axles:
~'66 Short axle w/ Short splines (no cast marking)
'67 Long axle w/ Short splines (marked "A")
'68~ Long axles w/ Long splines (marked "B")
I can't exactly recall, but the "A" or "B" stamping was either on the axle tubes or the end casting. My '75 S/A tranny has a "B" (same as '68 ). I say '68~ because the S/A tranny was still used outside the US until just recently.
This Sway-A-Way link shows the different axle lengths:
http://www.swayaway.com/VW_Components.htm#VW6
So if yours still has the original tranny it should have an "A" stamped somewhere on the axle and would be a short splined/long axle.
AshMan40
'75 Beetle 1200LS (RHD)
"stock" 1600 w/ 34 PICT-3 carb & S/A tranny
risk
risk is offline
PostPosted: Fri Mar 23, 2007 6:24 am    Post subject: Reply with quote
thanks for the info. the wheels have a 2" offset, so I'm pretty sure that they will rub regardless...
Reply to topic    Forum Index -> Custom Wheel/Tire All times are Mountain Standard Time/Pacific Daylight Savings Time
