Temmett Samba Member
Joined: April 19, 2010 Posts: 334 Location: Ferndale, CA
sharkskinman Lateral Lunatic
Joined: April 26, 2006 Posts: 4030 Location: Deep In My Own Psyche
Posted: Sat Mar 31, 2012 12:45 am Post subject: |
the videos are great
and im glad he made them
did you read how i was saying you can raise/lower the front from stock atleast 2 notches without taking all that off
and once you have done it once it would take you maybe 30 Min to do both _________________ 74 Mexi Swamp Thing. 70 square volksrod (Swamp Rat)..65 C10
Me of Course wrote: |
Extremity is relative to how far your willing to jump |
Ward Cleaver wrote: |
You ever try a pink golf ball, Wally? Why, the wind shear alone on a pink golf ball can take the head off a 90-pound midget at over 300 yards |
PS4 "NKOGNEATO" |
Posted: Sun Apr 01, 2012 7:40 pm Post subject: |
sharkskinman wrote: |
and once you have done it once it would take you maybe 30 Min to do both |
I did see that. This whole thread is going to be a big help when I get to lowering my car. _________________ 1978 Westfalia - pre-purchase walk around
1969 Squareback http://squarebackresto.wordpress.com/ |
DaBlackSamba Samba Member
Joined: August 22, 2010 Posts: 317 Location: west eugene, or
Posted: Sun Apr 01, 2012 11:34 pm Post subject: |
Temmett wrote: |
I did see that. This whole thread is going to be a big help when I get to lowering my car. |
i agree, gonna use this when i lower my 68., just have to wait for my motor to get back do i can set a good ride height _________________ 1968 VW variant |
gokufreak1 Samba Member
Posted: Mon May 21, 2012 1:48 am Post subject: |
Hey guys. I read on one of Cugir's videos (someone left a comment) that said you should buy new LOWERED oil shocks instead of using the stock ones. Do I need to invest in new shocks? Thanks |
Bobnotch Samba Member
Posted: Mon May 21, 2012 9:26 am Post subject: |
gokufreak1 wrote: |
It really depends on how low you want to go. More than 2 splines really requires shorter shocks (get oil lowered link pin shocks). If you're only dropping it 2 splines, you'll be fine with the stock shocks. _________________ Bob 65 Notch S with Sunroof
Tram wrote: |
Tram wrote: |
Posted: Mon May 21, 2012 4:33 pm Post subject: |
Bobnotch wrote: |
gokufreak1 wrote: |
It really depends on how low you want to go. More than 2 splines really requires shorter shocks (get oil lowered link pin shocks). If you're only dropping it 2 splines, you'll be fine with the stock shocks. |
Thanks. I'm thinking of dropping until it's about 3 inches off the ground. Cugir, in his videos, said he bought those white ones for 15 dollars each, but I can't find them anywhere for that cheap. Do you happen to know a good location to purchase them? Thanks. |
PumaGTe Samba Member
Posted: Fri Jan 11, 2013 4:32 am Post subject: |
When talking about the front end, is there a guide how many splines and what combinations give wich results?
I am working on my car, all 4 corners had different heights. The rear is nearly there right now, I want to set the front first before I go any further.
I want to raise one side of the car (left, drivers side) about 2cm. What combination of splines do I need to get this result? |
vdubin Samba Member
Joined: September 09, 2006 Posts: 305 Location: Huntsville, Al
Posted: Fri Jan 11, 2013 6:07 am Post subject: |
posted again....
just so there are no what's a minute questons. when dealing with very long distances a single degree can cover a few hundred miles or more. so, a degree is broken into 60 minutes and each minute has 60 seconds in it.
so there are 3600 seconds in one degree... rather hard to see on a degree finder. just ignore the miutes info and just use the inches and degree of change numbers.
Posted: Fri Jan 11, 2013 6:09 am Post subject: |
Cheers! |
Posted: Sat Jan 12, 2013 9:44 am Post subject: |
Just one more question,
Until two days ago I didn't know there was another way of lowering our cars on the front then lowered spindles or an adjustable front beam.
When lowering the front say two splines will the ride get very hard, just as it gets with an adjustable front beam? Or will it still be near stock comfort?
Thanks,
Dennis |
Posted: Sat Jan 12, 2013 11:25 am Post subject: |
PumaGTe wrote: |
Thanks,
Dennis |
That's the beauty of the type 3 beam, in that it keeps the same ride whether at stock height, or lowered. Just be aware that when dropping the front, you might be sitting on the lower bump stops. You'll need to remove them to get the suspension to work. Otherwise, you'll just be riding around on them, and the ride WILL be harsh (no suspension to move). _________________ Bob 65 Notch S with Sunroof
Tram wrote: |
Tram wrote: |
Shaven Samba Member
Joined: September 17, 2006 Posts: 879 Location: Australia
Posted: Wed Apr 10, 2013 11:00 pm Post subject: |
Is there NEW videos of lowering a Type 3 Squareback anywhere???
Appreciate the help in advance
Cheers Matty _________________ the dc baggin is because its a well known fact that a restored sc will never be worth anywhere near what even a shitbox dc is |
Tram Samba Socialist
Joined: May 02, 2003 Posts: 22728 Location: Still Feelin' the Bern- Once you've felt it you can't un- feel it.
Posted: Thu Apr 11, 2013 2:36 am Post subject: |
Shaven wrote: |
Cheers Matty |
Why? Have the laws of physics or the alignment of the universe changed somehow? I'm scared. Cheers Georgy _________________ Немає виправдання для війни! Я з Україною.
Bryan67 wrote: |
Shaven Samba Member
Posted: Thu Apr 11, 2013 5:47 am Post subject: |
Tram wrote: |
Shaven wrote: |
Cheers Matty |
Why? Have the laws of physics or the alignment of the universe changed somehow? I'm scared. Cheers Georgy |
thanks sweet cheeks
because we have a VW show on the weekend & i wanted to have a crack & lowering the square... _________________ the dc baggin is because its a well known fact that a restored sc will never be worth anywhere near what even a shitbox dc is |
Posted: Thu Apr 11, 2013 8:30 am Post subject: |
Shaven wrote: |
Tram wrote: |
Shaven wrote: |
Cheers Matty |
thanks sweet cheeks
because we have a VW show on the weekend & i wanted to have a crack & lowering the square... |
It's basically "what you see is what you get". It's not rocket science. With a Bentley or Haynes, you should be able to figure it out. Also, start reading from the beginning of this thread, as there's some good advice along the way. It should take about 1.5 to 2 hours to do the front, and about 3 hours to do the rear. The first side will always be the hardest to do, since you're trying to figure out how it all comes apart. _________________ Bob 65 Notch S with Sunroof
Tram wrote: |
Tram wrote: |
Erik G Samba Member
Joined: October 16, 2002 Posts: 13281 Location: Tejas!
Posted: Thu Apr 11, 2013 8:45 am Post subject: |
Tram wrote: |
Shaven wrote: |
Cheers Matty |
well, the original videos were removed. So, valid question.
No, there isn't. Take one side of the front apart, and you will see how it works. Thats the best advice I can give. It's very easy, I think Bob's times allow for some beer drinkin and learning. I think a newb could probably figure it all out in a couple hours like stated, someone thats done it before half that time or faster. I can drop a type 3 all around in less than 90 minutes if the tools are all laid out in advance. If you were in Houston I'd supervise and drink your beer while you learn lol. maybe someone local can teach ya _________________ Stop dead photo links! Post your photos to The Samba Gallery! |
Posted: Thu Apr 11, 2013 10:35 am Post subject: |
Erik G wrote: |
Tram wrote: |
Shaven wrote: |
Cheers Matty |
No, there isn't. Take one side of the front apart, and you will see how it works. Thats the best advice I can give. It's very easy, I think Bob's times allow for some beer drinkin and learning. I think a newb could probably figure it all out in a couple hours like stated, someone thats done it before half that time or faster. I can drop a type 3 all around in less than 90 minutes if the tools are all laid out in advance. If you were in Houston I'd supervise and drink your beer while you learn lol. maybe someone local can teach ya |
I rough figured the times for a complete newbie, and without having the tools laid out. The number 1 tool I'd buy before I started is an angle finder. That way you can match both sides to each other. _________________ Bob 65 Notch S with Sunroof
Tram wrote: |
Tram wrote: |
Posted: Thu Apr 11, 2013 12:34 pm Post subject: |
Erik G wrote: |
Tram wrote: |
Shaven wrote: |
Cheers Matty |
Well, shit. I had no idea.
You can call me Vlad all day today. _________________ Немає виправдання для війни! Я з Україною.
Bryan67 wrote: |
Erik G Samba Member
