pastorbill30 Samba Member
Joined: September 17, 2012 Posts: 16 Location: Newbury Park, California
Posted: Wed Dec 16, 2015 7:05 pm Post subject: Re: Lowering and leveling the Type 3 - video |
I am fixing up a '69 Square back, this is helping so much thanks! _________________ 1968 Squareback . |
gm4lnch Samba Member
Posted: Mon Oct 29, 2018 9:58 am Post subject: Re: Lowering and leveling the Type 3 - video |
Well I guess it's time to bring this back from the dead. I followed the advice here and Diesel"s video but my brake lines, even with the clip removed is still stopping me from getting the trailing arm down far enough. Do I need to break the line apart to get this down? I am trying to raise my car as right now with the EJ22 I am sitting on the bump stops so I plan to go up 2 inner splines hoping to get it back to stock height. Also someone said you can raise the trailing arm and pry a little on the bottom of the spring plate and it will still slip off fine, is that true?
Bobnotch Samba Member
Joined: July 06, 2003 Posts: 22422 Location: Kimball, Mi
Posted: Mon Oct 29, 2018 11:53 am Post subject: Re: Lowering and leveling the Type 3 - video |
I don't think I completely disconnected the brake line when I raised up my old 71 Notch. I think I removed the clip, and disconnected the parking brake cable as that was what was limiting me. I also had to disconnect the CV joints to get the arm to move enough.
Getting the spring plate off the step is the hard part, as there's 2 of them. You'll have to remove the spring plate cap to get the plate off so you can re-set the plate angle. _________________ Bob 65 Notch S with Sunroof
Tram wrote: |
Tram wrote: |
