Lowering and leveling the Type 3 - video
Goto page Previous  1, 2, 3, 4, 5, 6, 7  Next
sharkskinman
Lateral Lunatic
sharkskinman is offline
PostPosted: Tue Jul 29, 2008 7:13 pm    Post subject: Reply with quote
i think i skimmed thru the video
Before i lowered my car
To Learn and Because i cant make up my Friggin mind
i have messed with lowering and then raising the rear
suspension Probably 10 times in the last 2 months
and it still doesnt come off and go on as with the same ease
Now the front ???
I lowered it 1 time and it was fairly easy
But i borrowed a 30mm and a torque wrench
I took a look at the video for the rear
I Definitely helped on How long it took
4/71 ~311 "Bettie" (F.I./Auto)
Supaninja wrote:
BTW none of us are "buggin" here, we roll something far superior to a bug
Ward Cleaver wrote:
You ever try a pink golf ball, Wally? Why, the wind shear alone on a pink golf ball can take the head off a 90-pound midget at over 300 yards
PS3 Black Ops "NKOGNEATO"
jasle
jasle is offline
PostPosted: Wed Jul 30, 2008 12:02 am    Post subject: Reply with quote
I've lowered a few and I still found the vid's pretty informative. nice to see a different way I was actually unaware of.
One note i'd like to add is that i find it much easier to work if you remove the caliper and hang it up out of the way and then remove the entire spindle. only need to take the upper ball joint off so its only 1 extra bolt or nut whichever way you take it off.
i use the outers to lower the front. I modified the jaws of a 2 arm puller and put it in between the trailing arm and beam and use a slide hammer to pull it out. pretty easy as the hammering action pops it free. I just did a OG 68 the other day and it came off pretty easy.
Also you can just pop the rubber snubber off the arm. works for 3 notches lower without bottoming but then no need to cut.
brezel50kaefer
brezel50kaefer is offline
PostPosted: Sun Sep 07, 2008 10:13 pm    Post subject: lowered the ghia Reply with quote
Thank you so much for the awesome video! Gave me more than enough confidence to go and do it to my Ghia today. Down 1 spline, approx 2".
Took about 3 hrs.
Lowered
DamagedJustice86
DamagedJustice86 is offline
PostPosted: Sun Feb 01, 2009 4:22 am    Post subject: Reply with quote
Hey Cug,
Thanks for makin this video man it really helped me get a better understanding of the techs on the splines. I was wondering if it would be the same steps as lowering but in reverse to raise the square? I have been dying to raise mine a few inches.
I know it's considered heresy among most type 3 guys but everyone has to get their car to where they see it in their own mind right? Thanks again for all the info.
James
_______________________________________________________
'71 FI Squareback "The Suz..."
View user's profile Send private message MSN Messenger Classifieds Feedback
Bobnotch
Bobnotch is offline
PostPosted: Sun Feb 01, 2009 10:45 am    Post subject: Reply with quote
DamagedJustice86 wrote:
Hey Cug,
James
Yup the same, but reverse the lowering steps. Note when you do the rear, getting the spring plate back on it's stop will be a bitch, but it can be done (remember, you'll be dropping the spring plate down to raise the car up). I hope this helps and makes sense.
Bob 65 Notch S with Sunroof
71 Notch ...aka Krunchy; build pics here; http://www.thesamba.com/vw/forum/viewtopic.php?t=240540 -tear down
Mike Fisher
Mike Fisher is offline
PostPosted: Sun Feb 01, 2009 10:55 am    Post subject: Reply with quote
I used a tow chain wrapped around the upper bump stop AND my floor jack to compress mine.
http://s169.photobucket.com/albums/u236/mr_bojangles500/
69 FI/AT square Daily Driver
66 sunroof,67,71,71,71 AT,72,72 AT Parts
56 & 57 oval ragtop $2,500
Russ Wolfe
Russ Wolfe is offline
PostPosted: Sun Feb 01, 2009 11:03 am    Post subject: Reply with quote
Has anybody tried one of these to when lowering/raising the rear on your T-3??
http://www.harborfreight.com/cpi/ctaf/displayitem.taf?Itemnumber=3980
Gary: OK. Ima poop.
DamagedJustice86
PostPosted: Sun Feb 01, 2009 10:30 pm    Post subject: Reply with quote
Anyone have an idea of how many notches I can raise my '71 Squareback without any major issues? I actuall started cleaning up the axles today to get them ready for me to do the lift on it. I can't wait. So any opinions on how many clicks to go up, let me know. I'm going to do it this upcoming weekend. I will have to post a thread for this build man. Thanks again guys.
James
_________________________________________________________
KTPhil
KTPhil is online now
PostPosted: Sun Feb 01, 2009 10:34 pm    Post subject: Reply with quote
No, but I used a similar VW-custom version you often see on ebay or in vendor ads. It tends to wear the threads when using a lot of force--it needs to be greased which makes it slippery and messy, but it works. I used it on the front, too. It doesn't really fit either well, since it was made for swing axle rears, but I am careful about it slipping since the hooks are not made for IRS or the front.
DamagedJustice86
PostPosted: Mon Feb 02, 2009 12:03 am    Post subject: Reply with quote
One more thing concerning the lift....you guys think I should do the inners or outer splines? Also anyone know if I need to buy new shocks before I do this or will the stock shocks work for a lift of a couple inches? Thanks again for any info.
James
___________________________________________________________
isenegger
isenegger is offline
PostPosted: Sun Apr 26, 2009 8:30 am    Post subject: Reply with quote
i have watched all 4 videos and read this whole thread but im still confussed on how to lower the back of my 73 bug.
sharkskinman
Lateral Lunatic
PostPosted: Sun Apr 26, 2009 9:10 am    Post subject: Reply with quote
what is confusing
unbolt axle from end of spring plate
unbolt torsion cover
jack arm up by axle end
and pry out (behind arm at body/past small ledge)
with big screw driver (i use lug wrench or pickle fork)
while lowering jack
MARK WHERE YOU START!!
pull spring plate out and turn Up or Down desired splines
(I always prefer inner)
put torsion cover on with 2 Long bolts
Jack arm back up and onto the small ledge
bolt in
attach axle
My question is
why cant i Raise the front up 2 splines
it seams as i only get 1 then right side tierod bottoms out
this info would be good
isenegger
PostPosted: Sun Apr 26, 2009 3:03 pm    Post subject: Reply with quote
i guess i need someone to do it for me
tomnotch
tomnotch is offline
PostPosted: Sun Apr 26, 2009 5:41 pm    Post subject: Reply with quote
For the easist this method is a tried and proven one, and most certainly would work well for you. Laughing
Go to your local big box home improvement store and buy some bags of sand or cement and place behind the rear seat. Very low skills level required, but a good back helps. Laughing
Tom
DVKK
DSD, Dark Side Disciples
Progenitor
isenegger
PostPosted: Sun Apr 26, 2009 6:20 pm    Post subject: Reply with quote
ok so how much "ass" does it take to lower it a few inches? will this kill the gas mileage?
Soul Built Premium Member
Pimpin' Aint Easy
Soul Built is offline
PostPosted: Mon Apr 27, 2009 7:57 am    Post subject: Reply with quote
ISENEGGER....it isn't very hard at all. Honestly, all it takes is a bit of patience and confidence.
Follow the video and it is okay to stop mid-project to reference the video again.
Don't pay a shop to do something you can do yourself. In the long run, if you get good at it, you can make money lowering your friends cars Smile
ekuhl123
ekuhl123 is offline
PostPosted: Thu May 07, 2009 8:16 pm    Post subject: Reply with quote
with the bolts on the cv joint that my haynes manual calls "spline drive" if i strip them out could i replace them with regular bolts or is there a reason for them being the spline drive bolts?
ekuhl123
ekuhl123 is offline
PostPosted: Fri May 08, 2009 9:27 pm    Post subject: Reply with quote
Disregard my last posti found the too to take them out so its not a problem. my new problem is that im trying to lift a 71 bug using this same process and i took it all apart like you said but the trailing arm will not move far enough to get out of the way of the spring plate. is there some trick to getting it to move or should i just remove it entirely?
Bobnotch
Bobnotch is offline
PostPosted: Sat May 09, 2009 7:45 am    Post subject: Reply with quote
You have to remove the CV's to get enough drop from the trailing arm. I've even had to remove the brake hose clip, to get a little more working room. You might have to release the parking brake cables as well, as not all cars are exactly the same in this respect.
ekuhl123
ekuhl123 is offline
PostPosted: Sat May 09, 2009 5:18 pm    Post subject: Reply with quote
i did remove teh cv joint and handbrake cable but did not un clip the brake line, and it was still a long way off from being out of the way. is there a reason not to take off the diagonal railing arm besides the fact that it takes some work to do?
Page 3 of 7
