suruba Samba Member
Joined: January 13, 2012 Posts: 69 Location: Seaside, CA
Posted: Thu Apr 11, 2013 7:28 am Post subject: Need quick advice about panhead replacement |
I've got a question that I need answered quick fast
I've crashed my 69 fasty and bent the panhead, but the rest of the pan is in top notch condition.
I'm loooking at a 65 Notch that's got a late model pan but it's rusted as hell...
Can I take the pan head from the 65 notch and weld it onto the 69 frame ?
How hard is this?
I've tried searching but I haven't been successful with the search terms
I really appreciate a quick reply, as i'm about to back out of the deal if I can't get an appropriate answer
Dave |
Bobnotch Samba Member
Joined: July 06, 2003 Posts: 10612 Location: Kimball, Mi
suruba Samba Member
Posted: Thu Apr 11, 2013 10:26 am Post subject: |
I was also wondering about straightening it from like, a frame shop...has that been done?
Dave |
Mike Fisher Samba Member
Joined: January 30, 2006 Posts: 12415 Location: Eugene, OR
Posted: Thu Apr 11, 2013 10:51 am Post subject: |
I would guess that a Frame Shop would love the work.
P.S. I can cut/ship you a panhead if you don't want to cut up the '65. _________________ http://s169.photobucket.com/albums/u236/mr_bojangles500/
69 FI/AT square Daily Driver
66 sunroof,67,71,71,71 AT,72,72 AT Parts
56 & 57 oval ragtop $2,500 |
suruba Samba Member
Posted: Thu Apr 11, 2013 11:16 am Post subject: |
bob, who is russ? I'm looking but I'm not sure who it is
Dave |
Brent Samba Member
Joined: April 28, 2010 Posts: 986 Location: Yokosuka, Japan
Posted: Fri Apr 12, 2013 1:38 am Post subject: |
Dave, glad you were not hurt, but put up some carnage pics.
Remember your wrecked pan is an auto, different than a manual... Not sure what you're planning with the Notch, but probably easier to get a manual pan. Or use the tunnel from the Notch and weld in the old Fasty's pan halves.
*spelling edit _________________ 69 Fastback Build (Doris)
Posted: Fri Apr 12, 2013 5:21 am Post subject: |
| Brent wrote: | Dave, glad you were not hurt, but put up some carnage pics.
Remember you're wrecked pan is an auto, different than a manual... Not sure what you're planning with the Notch, but probably easier to get a manual pan. Or use the tunnel from the Notch and weld in the old Fasty's pan halves. |
Also, I should mention, that IF you're replacing the pan head, you'll NEED the body to be off the pan. This way, you can double check everything for being square. Here's a couple of pics of my pan head swap.
And a gratuitous used pan swap (same car) for reference.
One other thing, IF you decide to replace the entire rolling pan section (or middle pan and tunnel section), get a title with it, as you'll be changing VIN's, and California might not like you doing that. Some states are fussy about pan swaps. Just a heads up. _________________ Bob 65 Notch S with Sunroof
71 Notch ...aka Krunchy; build pics here; http://www.thesamba.com/vw/forum/viewtopic.php?t=240540 -tear down
64 T-34 Ghia...aka Wolfie, under construction... http://www.thesamba.com/vw/forum/viewtopic.php?t=412120 |
suruba Samba Member
Posted: Fri Apr 12, 2013 7:07 am Post subject: |
Bret, Thanks for the kind words. As far as pictures go, I don't have many, only one actually, and I already took off a lot of the sheet metal that was removeable, and took a sawzall to the front clip to get the wiring harness and gas tank out and start deconstruction
i've got a title for the fastback that got wrecked, I was thinking of either using the pan halves from that or swapping the panhead from the notch onto the fasty pan, or getting the fasty panhead straightened and reinforced at a body shop
why is the auto pan so different? If i was to use the fasty pan I would keep it automatic, and I thought that the pans were exactly the same as far as bolt pattern, but I could be wrong. I know there are differences in the tunnels, but nothing I thought would interfere when swapping a body
Dave |
