MichaelSpark Samba Member
Joined: June 17, 2010 Posts: 2 Location: California, Bay Area
Posted: Sat Apr 23, 2011 8:04 am Post subject: Thump noise in rear of bug |
I have a thump noise in the rear when I go over a bump -- it's a 67 bug. I've replaced shocks, put new rubber in the Z bar and it's still there. It sounds like the rear wheel is hitting the wheel well but I dont see any indication of that.
Any ideas from anyone? [/list] |
Raymond73 Samba Member
Joined: March 07, 2010 Posts: 225 Location: North Dakota
Posted: Sat Apr 23, 2011 8:40 am Post subject: |
| Take off the rear fender and have someone drive over a bump while you watch? |
wbrown45 Samba Member
Posted: Sat Apr 23, 2011 10:55 am Post subject: |
I would inspect the rear body mounts, by the shocks. They have a habit of loosening up. If not that, then take a large prybar and start pulling, pushing, and investigating. _________________ OK Thang |
KTPhil Samba Member
Posted: Sat Apr 23, 2011 11:23 am Post subject: |
| Worn torsion arm rubber bushing. |
drscope Samba Member
Joined: February 19, 2007 Posts: 13440 Location: Baltimore, Maryland USA
Posted: Sat Apr 23, 2011 5:38 pm Post subject: |
Is the deck lid fastened and tight?
Rear bumper mounts in good shape and bolts tight so the bumper isn't bouncing?
Check the 3 big bolts that hold the spring plate to the axle.
Look close at your shock rubbers.
You don't have a flash light or other lost device rolling around under the rear seat or back in the package tray area? _________________ Mother Nature is a Mean Evil Bitch! |
Posted: Sat Apr 23, 2011 5:40 pm Post subject: |
| wbrown45 wrote: | | I would inspect the rear body mounts, by the shocks. They have a habit of loosening up. If not that, then take a large prybar and start pulling, pushing, and investigating. |
Thanks for all of your suggestions, I had the rubber in the torsion bars replaced as well. |
KTPhil Samba Member
Posted: Sat Apr 23, 2011 6:02 pm Post subject: |
| Loose battery hold-down clamp? |
KingWeazle Samba Member
Joined: November 30, 2007 Posts: 39 Location: Bedford, Ohio
Posted: Tue Apr 26, 2011 6:55 am Post subject: |
Inside or outside of the car ? My noise was the bottom of the back seat lifting and crashing down. A buddy of mine had his battery tie down clamp loosen up, banging the battery around on bumps. _________________ Have fun and play hard !! |
