aircooledmark Samba Member
Posted: Wed Jun 25, 2008 3:07 pm Post subject: |
| artie325 wrote: |
That car is bad ass! I too am running 16x6 Fuchs with 205/50r16 Goodyears on the front of my car with a 4 inch beam and CB drop spindles and disk brakes, and 16x7 inch Fuchs with 205/55r16 Goodyears on the rear mounted on redrilled drums. I am in the process of installing short axles on my '67 so the rear wheels will tuck under the rear fenders. When I am finished restoring my car, I hope it looks half as cool as yours. The alpine white with the polished Fuchs is a great combination.
Thank you for the compliments. My car is beige grey... The same color typically seen on a sealing wax red/beige grey bus.
Post some pics when you're done... We need to keep this thread going  |
Speedy Samba Member
Joined: January 05, 2005 Posts: 166 Location: Cape Fort St. Port River Inlet Bay Coast Canal Beach, the median on Hurricane Highway, Florida.
Posted: Wed Jul 09, 2008 2:41 pm Post subject: |
16's x 6 on front and 7 on rear. 4" narrowed beam, CB drop spindles, ghia disks, 68 drums w/porsche pattern, and short axles. _________________ pimp
_________________________________
Wanted:
A.J. Pierson VW Tag Frame - Orlando FL.
Original Solid Oval Rag In Central Florida!
Always something for sale... click ↓ below (O\ ! /O)
DORIGTT Samba Member
Joined: October 01, 2003 Posts: 140 Location: Forest Grove, OR
Posted: Wed Jul 09, 2008 6:28 pm Post subject: |
What size rubber? _________________ To err is human, but if the eraser wears out before the pencil does you're a major screw-up. |
Slowlow  Samba Member
Joined: March 17, 2004 Posts: 4081 Location: Kingsport,Tennessee
Posted: Wed Jul 09, 2008 7:06 pm Post subject: |
| Skim wrote: |
| I really like the 16"s and the tire sizes they have in 16 are bad ass. |
For sure!
Sometime in the future I wanna dig up some 16's for my bus.  _________________ *Autowerks Suspension* |
Speedy Samba Member
Posted: Wed Jul 09, 2008 7:13 pm Post subject: |
| DORIGTT wrote: |
| What size rubber? |
195/45 on front & 215/50 rear IIRC. _________________ pimp
Wanted:
Always something for sale... click ↓ below (O\ ! /O) |
speedbuggy67 Samba Member
Posted: Thu Jul 10, 2008 8:48 am Post subject: |
sweet looking car glad i put 16's on my 67 im shocked they aren't more popular then they are.... Im still running the tires that came off the 911 porsche 225/50 and 205/55 since they are new i feel like a 4x4 with them but jersey roads.......
Scott _________________ 1967 florida blue sedan w/berg2006cc and fuchs
1992 Nissan Pathfinder 225k+ miles
2002 subaru wrx
VW clubs---- www.cjvws.com --- NJ
----- www.cal-look.com ----- |
Speedy Samba Member
Posted: Thu Jul 10, 2008 11:25 pm Post subject: |
| speedbuggy67 wrote: |
Scott |
Thanks, it now belongs to my friend Jose. Here in FL for the most part they've been keeping up on road maintenance except for a few places. After you install shorter axles it will look even better! _________________ pimp
Wanted:
Posted: Sun Jul 13, 2008 5:47 am Post subject: |
just out of curiousity does anyone with the narrowed beam and wider rear track get more road wander then when stock width? Seems my 67 long axle with 225/50's and 2in narrow beam with 205's seems to have more wander(mostly highway (65-75mph) then when it was stock width with empi 5's and cb dropped spindles. I figure same situation with 3-4 in narrowed beams and earlier short axle cars. Yes it was aligned, wheels balanced, steering box adjusted for 1inch of wheel movement. Anyone wander more then stock width???
2002 subaru wrx
Speedy Samba Member
Posted: Sun Jul 13, 2008 8:56 pm Post subject: |
Scott |
Did you use caster shims? Is the steering damper new? Just asking 'cause of the stance/rake of the car, also remember that with a light car and wide tires you will wander some depending on the roads. If the caster shims are in place, the steering damper is new and the steering box is good you can tighten it a bit more, i personally do not like much play. _________________ pimp
Wanted:
Posted: Mon Jul 14, 2008 4:19 pm Post subject: |
caster shims- check new steering stabilizer (year old)- check, steering box tight- check. I took it for a long ride yesterday i think the balljoints since they are new are pretty stiff and that is contributing to some stiffness as they are getting better every drive but after 50miles or so are pretty stiff yet. Car tracks very straight and i have to remember its not my subaru wrx with modded suspension. Before when i had 145's spindles and drums you tend to drive slower and expect less. Im sure the wider rear end leads to some "dartierness" maybe when i redo the tire combo i'll do the 195/50 205/55's that i had planned and will most likely help out as well.... thanks for the advise its always appreciated.
2002 subaru wrx
lonotch Samba Padrino
Joined: August 28, 2004 Posts: 2793 Location: So. Cal. Oceanside GFK!
Posted: Mon Jul 14, 2008 6:07 pm Post subject: |
Back in the 80's, 16"s rears with early 4.5"s fronts.
 _________________ It's not about the window, it's about the people.
German Folks |
luckystiff Samba Member
Joined: September 28, 2005 Posts: 2086 Location: hickory,nc
Posted: Mon Jul 14, 2008 9:17 pm Post subject: |
Scott |
it's mostly the 205s up front thats causing it to find every rut in the road. wider wheel/tire up front will do it every time. if all the stuff you mentioned is indeed new it may get somewhat better but with 205s up front it's gonna wander. the 195s may help some. there are 175/55/16s available but they are expensive...ken.... _________________ ITMC
Secret Service |
RA 70 Samba Member
Posted: Sat Jul 25, 2009 11:41 pm Post subject: |
So I have a 70 beetle with IRS, and the axle sticks out and pushes the cap off..... Any adapters out there for the cap, or this there a shorter axle you can use on IRS? I can't run a spacer behind the wheel because the rim wheel stick too far out beyond the fender, any help is apperciated.
Wheels 16 inch fuchs off a 911 6's ET43 in the front and 7's ET44 in the rear. |
Speedy Samba Member
Posted: Mon Jul 27, 2009 10:43 pm Post subject: |
| RA 70 wrote: |
I know someone with the same situation, could u please post some pics at different angles???
Wanted:
RA 70 Samba Member
Posted: Tue Jul 28, 2009 4:24 am Post subject: |
Ill see if i can get some pics of how far the the axle sticks out, but I would say about 1/4 inch, wont be able to get to till this weekend I think... I already know I will have to smaller tires on it and looks as though it will barely clear doing that.
Also are lug bolts ok to mount the 911 fuchs? Or is press in studs the way to go, and if so what is the proper length studs to use? |
Speedy Samba Member
Posted: Tue Jul 28, 2009 8:38 am Post subject: |
| RA 70 wrote: |
Always use studs, they are safer. The length of the studs depend on the wheel & nut combo, the shoulder length depends on the drum. You don't want the splines protruding beyond the drum or hub into the wheel. And if the nut is a "closed end" style (not open) you need to make sure it does not bottom out on the stud and that it seats correctly on the wheel tightly. _________________ pimp
Wanted:
buddy boy Samba Member
Joined: June 14, 2009 Posts: 218 Location: vancouver b.c. canada
Posted: Tue Jul 28, 2009 9:00 am Post subject: |
16x7's all around !!.. 205/16/50's rear 205/16/40's front , 3" narrowed front beam , drilled drums.
 _________________ "love lasts forever, tattoos last six months longer"
Click to view image |
RA 70 Samba Member
Posted: Wed Jul 29, 2009 4:54 am Post subject: |
| buddy boy wrote: |
How did you get the caps to fit on the rear, spacers? And nice ride  |
Posted: Thu Jul 30, 2009 2:07 am Post subject: |
shaved them down !! _________________ "love lasts forever, tattoos last six months longer"
crusty67t2 Trailer Park King
Joined: January 11, 2005 Posts: 559 Location: flori-duh!!!
Posted: Thu Jul 30, 2009 6:23 am Post subject: |
16x6s all around 195 45s 205 50s
4 inch beam
2 inch tubs
any one wanna trade a pair of 7s for a pair of my 6s hit me up... _________________ WIDEFIVE !!!
60 swivel seat Kombi
59' rag top
57' crusty oval |
