Fun 181 Zu Geil!
Joined: October 20, 2006 Posts: 1003 Location: Connecticut
Posted: Sun Apr 08, 2007 8:44 am Post subject: Now THAT'S a breather box! |
Check out my new crank case breather box.
3 lines in. 1 from each valve cover and 1 from the oil filler neck. All the lines are SS with polished 8AN fittings. I have small holes drilled in the backof the ammo can for ventilation and a piece of folded air filter foam inside for a filter.
After looking at generic breather boxes from CIP1 and other distributors I checked out some higher end set ups from Gene Berg and his son Clyde Berg. Then I found a thread in the Volksrod forums regarding custom breather boxes and some joker suggested using an old ammo can. Several others chimed in and said they thought it was a great idea, but I don't think anyone went ahead and tried it.
So here you go.
Ian Epperson wrote: |
Holy poop, that's full of awesome! |
Towel Rail Horizontally Opposed
Joined: April 15, 2005 Posts: 4622 Location: SE CR IA US NA PE
Posted: Sun Apr 08, 2007 9:35 am Post subject: |
Ha! That's perfect! _________________ 1974 Thing -- under the knife
1967 Beetle -- spring/summer/fall driver
1996 Subaru OBW (EJ22, 5-speed, AWD) -- winter car, 3-seasons "don't feel like biking today" car
049 > 070 > 053 > 009 |
Ian Epperson Samba Member
Joined: January 12, 2005 Posts: 2262 Location: Alameda, CA
Posted: Sun Apr 08, 2007 12:12 pm Post subject: |
Excellent!
I've been going through my engine compartment lately trying to figure out how I'll get everything to fit - forgot about the breather box! Maybe I'll just punch some holes and mount it by the tranny - boooring!
Here's what I'm working on:
http://farm1.static.flickr.com/86/209337786_ef1c326d97.jpg
Dual carb, serpentine belt, cast fan backing plate... got any more pics of your engine and compartment? |
Fun 181 Zu Geil!
Posted: Sun Apr 08, 2007 9:09 pm Post subject: |
There are still a few additional odds and ends that need to be taken care of, but here are a couple more pics of the engine.
Before...
and after...
Berg sump, Berg welded fan and Berg full flow oil filter system. I'm also running a pertronix flame thrower II ignition system. For the engine I still need to hook up the digital rev limiter, install the Dakota digital cylinder temp gauge (plus oil temp, oil pressure, tach)and work out some issues with the fuel regulator.
I'll post more pics in a week or two. _________________
npconnor Samba Member
Joined: February 13, 2007 Posts: 194 Location: Central Texas
Posted: Mon Apr 09, 2007 8:34 am Post subject: |
I like your paint job, mine is sort of similar, olive drab looking color... _________________ '73 Thing
Austin Air-coolers Gang |
Posted: Mon Apr 09, 2007 11:37 pm Post subject: |
Thanks for the pics! Looks very slick! |
kubelmann Samba Member
Posted: Tue Apr 10, 2007 8:44 pm Post subject: |
I want to know more about the tri exhaust very Sickkkkkk |
PIMPPRIDE Samba Member
Joined: November 19, 2003 Posts: 879 Location: Carson California
Posted: Wed Apr 11, 2007 5:15 pm Post subject: |
kubelmann wrote: |
we sell those... the fitment is great and its hard to find a better system for the price, let me know if you have any questions, here is our add
Anthony / ISP WEST
http://www.thesamba.com/vw/classifieds/detail.php?id=182538 |
Posted: Wed Apr 11, 2007 6:45 pm Post subject: |
I have had a very good experience every time I have had the good fortune to buy parts from you guys. Can you tell me if this system support a 1776 with a single Zenith ndix or a high compression 1915 with dual Delorto 36 carbs. I like it. I want to buy one. Do you guys want to do a group buy? I can get that part together if you wnat ot give say 10 of us a better deal as a group buy. Thing owners swing on the group buy. We are small in numbers but strong in spirit. K-mann |
lukesky Samba Member
Joined: July 12, 2006 Posts: 246 Location: See The Rabbits, IA
Posted: Wed Apr 11, 2007 8:50 pm Post subject: |
That stuff looks awesome. I wish I knew what the $*%@ you were talking about... _________________ You get what you get, and you don't throw a fit.
-Gabi |
Fun 181 Zu Geil!
Posted: Wed Apr 11, 2007 10:24 pm Post subject: |
I think I did get the exhaust from ISP. a.k.a. "Pimppride" from eBay. It was $279 and a smooth transaction.
The exhaust obviously fits on a 2110 although it had to be adjusted out a bit to fit the heads.
I also have matching ceramic coated heater boxes (the good German kind). I forgot where I got them. Either CIP1 or Mid America. Probably around $400 for the pair. I see ISP has them too.
The whole exhaust system has been replaced, but I'm still getting exhaust smell in the car (with the top and windows up). Not as bad as the old stock set up, but still quite noticable - i.e. headache after a long drive. I want to add some exhaust tips and try and angle the fumes down and away from the car.
Did I mention that it is LOUD?
I like it. _________________
Posted: Thu Apr 12, 2007 7:21 am Post subject: |
Fun 181 wrote: |
I'm still getting exhaust smell in the car (with the top and windows up). |
Perhaps it's leaking into the engine compartment? Is your decklid modified with louvers or do you run with it open? Are the side muffs modified with additional openings? Do you have all the sealing tin around the engine? I see the side tins, but I don't see the rear tin and can't see the forward tin in your pictures. |
Ferretkona Samba Member
Joined: December 03, 2005 Posts: 1306 Location: Columbia, CA
Posted: Thu Apr 12, 2007 4:42 pm Post subject: |
My experience tells me old/well used motor. They really spew a rich fuel odor.
You might want to get a professional tune up, a really badly tuned up motor will stink up the cab.
The exhaust on Things are just plain loud, get over it, lol. |
Fun 181 Zu Geil!
Posted: Thu Apr 12, 2007 7:11 pm Post subject: |
I just did a search on "Thing exhaust fumes" and see that this topic was recently discussed.
The big concern here is carbon monoxide poisoning on a long (or even short) drive. Headaches are a mild symptom. More severe symptoms can be quite unpleasant - i.e. death.
Since the engine, transaxle, exhaust system and all other components are brand new I think the issue is the short tail pipes. The engine only has about 60 miles on it, and just came out of the shop last week where it was built.
The decklid and side muffs haven't been modified or cut. The engine compartment seals are all new and all the tin is new and in place.
Over the years I've noticed that same exhaust smell while riding in older convertibles regardless of make or model. I have even smelled it when driving in my '97 4Runner with the back window down.
I have to assume that the air flow over the vehicle is carrying a lot of the exhaust up and back into the car. With all the open gaps in the Thing's top it's not surprising that fumes are getting in even with the top up.
I'm hoping that longer exhaust tips (pointing down) will help the situation.
Perhaps I can fabricate some out of an 81mm mortar shell casing!
Posted: Thu Apr 12, 2007 8:22 pm Post subject: |
Are you getting exhaust smell or fuel smell? With mine buttoned up, it smelled like you were driving an empty gas can. I put new filler hoses on the tank and it took care of the problem. They didn't look bad from the outside, but once I took them off, I could see that they were rotted. _________________ You get what you get, and you don't throw a fit.
-Gabi |
Fun 181 Zu Geil!
Posted: Thu Apr 12, 2007 8:54 pm Post subject: |
When I first got the car I could smell both gas and exhaust! The exhaust smell was pretty bad. After a short drive I could smell the fumes in my clothes for hours afterward. And the gas smell... P.U. The first time I filled up the tank the smell was so bad it was like I was swimming in gasoline.
I have since replaced ALL the fuel lines near the tank (the little breather lines to the charcoal filter and the larger filler hoses) and can't smell any gas at all. It was just like you said, the lines looked O.K., but once removed you could see the rot. Replacing them did the trick.
The exhaust smell isn't nearly as bad as it was, but it's still there. The headache was the real tip off. _________________
