klokard Samba Member
Posted: Thu Apr 12, 2007 3:18 pm Post subject: Looking for a '74 passanger side mirror! |
I have had a WTB ad in Thing parts for a month now with no help. I need a passanger side mirror for a '74 (long arm). I now have 2 nice '73 mirrors from good intention sellers but they are incorrect. Even if it's just the frame and no glass, I'll make it work. Short of finding one, what do others do to see out of the R/S mirror? Thanks in advance. |
Ferretkona Samba Member
Joined: December 03, 2005 Posts: 1306 Location: Columbia, CA
Posted: Thu Apr 12, 2007 3:51 pm Post subject: |
I see,eeeee nothing!
I bought a pair of 74 mirrors and the right one needs new glass.
One of these days I will get around to cutting some glass for it, or find someone who will.
I have had plenty of cars without right hand mirrors, easy to look over my right shoulder. My only problem is backing into the garage along side a older car.
I think Kubelman sells the adapter in stainless steel for using bus mirrors on our 181's.
Ian Epperson Samba Member
Joined: January 12, 2005 Posts: 2262 Location: Alameda, CA
Posted: Thu Apr 12, 2007 4:40 pm Post subject: |
I believe that the threads for the mirrors between '73 and '74 are also different. I've got the Thing Shop door hinge mirror mounts on mly '73, and my mirrors have a different thread. |
ztnoo Samba Member
Al Capulco Samba Member
Joined: October 31, 2005 Posts: 532 Location: Northridge, CA.
Posted: Thu Apr 12, 2007 7:20 pm Post subject: |
I think the Thing Shop sells the "Long Arm" mirror new. I saw them at a show a couple of years ago. They are not cheap. But they did look good. |
J Flare Samba Member
Joined: September 27, 2004 Posts: 309 Location: San Diego
Posted: Fri Apr 13, 2007 7:44 am Post subject: |
I talked to Larry from the Thing shop last year at the Classic and he was not very happy with the durabilty of the 74 passenger side mirrors they sell.
Joe |
Posted: Sun Apr 15, 2007 10:01 pm Post subject: I AM GETTING DESPERATE. |
O.K. SOMEONE HAS TO HAVE A USEABLE '74 RIGHT SIDE MIRROR THEY'D BE WILLING TO SELL. I'M WILLING TO GO ABOVE A HUNDY FOR A GOOD USED ONE. ANYBODY? PLEASE! |
pjmacua Samba Member
Joined: May 22, 2003 Posts: 199 Location: Cantal, France
Posted: Tue Apr 17, 2007 5:45 am Post subject: |
Hello
If you're not in a hurry, I think that I can help you.
I should get soon (next week maybe) some NOS right side mirrors, chromed, with the extra long arm.
They are different from the right mirrors with the extension.
The arm is clearly longer and it is in one piece.
Price should be about 70 or 75 euros + shipping.
Regards
Pierre-J MACUA |
kubelmann Samba Member
Posted: Tue Apr 17, 2007 10:27 pm Post subject: |
Thanks to ztnoo for posting the link to my efforts in a quality machining of the oe 73 mirror extension. BUT the 74 has an extension that is different for the passenger side. I am currently tooling up to make another run of the extensions. BUT I have no data for the length of the 74 passenger side extension. All my Things have been 73. I have never had a 74.. I would love to create some 74 extensions in this next run. BUT I need data.... If you got the data or can take a measure, please share.
About the threads. There is a big supply of bus/Thing aftermarket mirrors that among other faults have a dfferent shaft thread. It is not a matter of 73 vs 74, it is a matter of afermarket shit vs oe parts. The other fault of the after market mirrors is that it takes very little time before the aftermarket ball joint on the mirror develops a lazy sag. Then the mirror drops with every movement of the car.. You get what you pay for and you get what you deserve if you do not do your parts source research prior to purchase. [/i] |
Posted: Tue Apr 17, 2007 10:36 pm Post subject: |
Kmann
I went out and measured my right hand mirror and the extension is 2" long. Do you need any other measurements?
Anyone have a lead on replacement glass for the heads? |
Posted: Tue Apr 17, 2007 10:46 pm Post subject: |
You send me any mirror with defective mirror glass. i send it back with new 21st century mirror glass installed for exact return shipping cost and exact cost to replace mirror glass. This is way cheaper than any other solution to bad mirror glass. I am unable to tell you how many mirrors I have put back into decades of services for far less than the cost of a crummy aftermarket replacement. |
Posted: Tue Apr 17, 2007 10:54 pm Post subject: |
My extensions are the same length. So this supports my theory. The passenger side on a 74 Thing is not the same as any other mirror. I suspect I can lengthen my extension and make a mirror the same length as the 74 pasenger side mirror. I suspect they used a mirror with a longer arm.. Send me a picture of an oe 74 passenger side mirror |
Posted: Wed Apr 18, 2007 11:52 am Post subject: |
kubelmann wrote: |
About the threads. There is a big supply of bus/Thing aftermarket mirrors that among other faults have a dfferent shaft thread. It is not a matter of 73 vs 74, it is a matter of afermarket shit vs oe parts. |
I've got the brass door-hinge mirror mounts from The Thing Shop on my '73 - I bought them several years ago. When I took my mirrors off the doors and threaded them into the mount, the mirrors' threads collapsed - the left one stayed in place for years, but the right one never fit properly. I though it was an issue with an old part, so back when TU was trustworthy, they sent me a set of replacements for the mirror (nut? bolt? It's the bit that screws into the body that the bottom of the shaft connects to). Anyway, I carefully cleaned all the threads and carefully threaded the new parts in - and the threads collapsed again! The threads are just slightly different, and the mirror's metal is softer.
So, either the Thing Shop parts have the correct threads and I've only tried aftermarket mirrors (and the mirrors were not fitting properly to begin with - which is likely) or the Thing Shop's mount has aftermarket threads and the original mirrors don't fit it.
I'll measure what I've got tonight. K-mann, do you have anything to measure the correct mirror thread? |
Posted: Wed Apr 18, 2007 4:49 pm Post subject: |
Are you talking about the large threaded sleeve that threads into the door? Or the threads where the extension and mirror attach? Yes I can measure threads and thread pitch. |
uberautowerks Samba Member
Joined: October 17, 2005 Posts: 1600 Location: Longmont Co
Posted: Wed Apr 18, 2007 5:55 pm Post subject: |
-The threads are 16mm x 1.5 n both '73 and '74 Things, Bay windows, Beetles, Type 3's and 4's.
-I have an expensive tap in that size just for cleaning bunged up threads and correcting Thing shops mounts!
-Also the right side mirror has a longer "diagonal" arm with the effect as to put the mirror head further away from the body so you can see better. In the end... You can't. _________________ --- The major difference between a thing that might go wrong and a thing that cannot possibly go wrong is that when a thing that cannot possibly go wrong goes wrong it usually turns out to be impossible to get at and repair.
- Douglas Adams -
'74 Thing (White)
'71 Single cab (White too)
'70 Weekender (White three)
'05 Evolution VIII (White also!!!)
'68 F-250 (White over black) |
Posted: Wed Apr 18, 2007 5:59 pm Post subject: |
The threads in the door.
I just went and measured them, and they are identical - 1.5 pitch on both the body and the mirror. So, I don't know what the hell is wrong
Maybe I just have to run a tap through it or something. I spent half an hour cleaning the threads before my last try, only to end up with the brand-new mirror's nut strip out. |
Posted: Wed Apr 18, 2007 6:04 pm Post subject: |
Yes I agree. I measured and found it to be 1.5 also. BUT I found two old nasty sleeves that had threads that would not go into the door threads i was playing with. So I suspect that IF the threads are nasty it will crunch up the mirror part. What part do you need? I have been working on the mirror issue for a while and have a parts. |
warrant_nielsen Samba Member
Posted: Sat Apr 21, 2007 7:03 pm Post subject: |
When I got my Thing I ordered stainless hinge-mirror mounts from The Thing Shop. Then off of Ebay I got stainless mirror extensions onto which I added bus mirrors and everything works GREAT! (and tightensup) This was probably a much more expensive way to go but it worked.
___________________________
Life sucks for a Samba ‘trainee’!
1959 - Bug
1974 - Type 181 Acapulco Thing
1982 - VW Diesel Caddy Pickup
2004 – New Beetle Convertible ‘Mellow Yellow’
1966 Bug, 66-67-68 Bug Convertible, 68 Bug, 70 Bug, 72 Bay Window Camper Van.
Diesels – 80 Rabbit, 82 Rabbit, 84 Golf, 86 Jetta, 2000 Jetta ‘TDI’, 2002 Jetta ‘TDI’, 2006 Jetta ‘TDI’ … [/url] |
Posted: Sun Apr 22, 2007 6:45 pm Post subject: |
I still suspect that everyone will be better off installing hinge mirror mounts using my extensions on bus mirrors. I have NEW Hagus Bus mirrors and am tooling up a new run of extensions... (PS) where do you think the "other" folks get their hagus mirrors.. Uberworks already gave you a hint. i know where the German pipeline enters the US and it ain't in Garden Grove or Chandler.. Larry does have a good supply of some low dollar aftermarket mirrors.. why else would he drop the price to $60... |
Posted: Sun Apr 22, 2007 8:44 pm Post subject: Hinge mount mirror |
Kubelman,
Doesn't a hinge mount put the mirror in the same place it already is on a '74? I understand the hinge mounts for a '73 but what advantage is gained by putting them on a '74? Also, don't the extensions just raise the mirror? I need to move mine out away from the windshield frame to see out of all the mirror. Please clear this up for me as I am now beyond desperate as I have only 1 lead on an OEM '74 mirror from PJ.
Charlie |
