king pin reamer
john7
john7 is offline
PostPosted: Thu Apr 26, 2007 10:31 pm    Post subject: king pin reamer Reply with quote
I have a double reamer that came with some vw front end tools that i bought that i believe is for the king pin bushings on an early bus.
does anyone know the size of the king pins?
i will have to measure the reamer but it is approx 20mm
Kommercial
Moderator
Kommercial is offline
PostPosted: Fri Apr 27, 2007 12:16 am    Post subject: Reply with quote
The reamer should be adjustable 21 to 24.5mm I believe, any markings on it? I am looking for a bus one, sent you a pm.
campingbox Premium Member
campingbox is offline
PostPosted: Fri Apr 27, 2007 9:45 am    Post subject: Reply with quote
I'm not sure what you mean by "double reamer"?
Look for markings on the size, they will be printed in inches.
RockNbus
RockNbus is offline
PostPosted: Fri Apr 27, 2007 2:56 pm    Post subject: Reply with quote
He probably means a reamer that reams the upper and lower sections in-line at the same time.
PostPosted: Fri Apr 27, 2007 4:17 pm    Post subject: Reply with quote
Can't say I've seen one of those before. The service reamer for this repair has a guide which fits into one bushing while the reamer cuts the other.
RockNbus
RockNbus is offline
PostPosted: Fri Apr 27, 2007 4:36 pm    Post subject: Reply with quote
We have used them in aerospace where it is important to have the two bushings in-line. Of course a proper jig is used to assure that the first hole is not way off.
mr. warehouse Premium Member
mr. warehouse is offline
PostPosted: Sat Apr 28, 2007 12:21 am    Post subject: Reply with quote
Bridge reamer is the proper term.
I use them for king pins Bug and Bus.
New not Hazet, so don't bother asking if they are for sale.
john7
john7 is offline
PostPosted: Sun Apr 29, 2007 9:51 pm    Post subject: Reply with quote
yes exactly what i mean it reams both busuings at the same time and is non adjustable
it is blue point (sold by snapon)
it measures .800 on the shaft. i cant read the imprinted #
paul_f
paul_f is offline
PostPosted: Wed May 02, 2007 3:30 pm    Post subject: Reply with quote
No a bridge reamer is a tapered reamer used for correcting missaligned bolt holes in steel structures. It just so happens that the taper of these matches something else on a bus spindle.
The correct term is a reamer + pilot. The pilot screws onto the end of the adjustable reamer
PostPosted: Wed May 02, 2007 6:24 pm    Post subject: Reply with quote
You are correct.
I was thinking adjustable like this, but called it a bridge
I wouldn't use a bridge reamer for anything on a Bus, maybe the reverse taper on a spindle, but even that is pushing it..
http://www.chadwickreamers.com/products.php
