Joined: April 27, 2002 Posts: 6371 Location: Pentwater, Michigan
Posted: Mon Apr 30, 2007 5:55 pm Post subject: KDF distributor? How to tell... |
Just wondering. I was told it is. I have been rebuilding some oldies but nothing quite this old. Some differences I can find on cursory inspection:
pin at bottom of drive pinion
Brass collar at case mating surface.
Adjustment thumb screw at base.
Name plate says: Lavalette Bosch F1VE4AS66 some letters numbers are hard to make out.
One clip is missing the other is broken.
Any help ID'ing this beute would be great! Thanks!
https://www.thesamba.com/vw/gallery/pix/348026.jpg
https://www.thesamba.com/vw/gallery/pix/348027.jpg
It does fit into the distributor mount hole and mates with the drive pinion of a 36 horse engine. The mounting bracket that came with it lines up good on a 36 hp case too. |
Glenn Mr. 010
Joined: December 25, 2001 Posts: 76902 Location: Sneaking up behind you
Posted: Mon Apr 30, 2007 6:06 pm Post subject: |
Did you just buy that on eBay?
I saw it and don't think it's for a KDF. The drive on the bottom looks like a early Mercedes. _________________ Glenn
Member #1009
#BlueSquare |
Posted: Mon Apr 30, 2007 8:03 pm Post subject: |
What this old thang...
Yeah it was on ebay. It cost me less than $20 shipped so I'm not out too much. I bid not knowing what a KDF distributor should look like. Might at least be the same era.
comments from anyone else. |
Posted: Mon Apr 30, 2007 9:00 pm Post subject: |
Did a little research and found that Lavalette a French parts manufacturer partnered with Bosch between WWI and WWII since import duties to the Germans was making anything coming out of Germany too expensive for anyone to buy.
The partnership started in 1928 and must have ended somtime before 1940 as this is when German re-invaded France at the beginning of WWII.
So I guess this piece predates the KDF by a number of years.
Didn't know Bosch history went back that far. |
53 0val Samba Professor
Joined: July 03, 2003 Posts: 11396 Location: Irvine, CA
Posted: Mon Apr 30, 2007 10:11 pm Post subject: |
tasb wrote: |
http://www.bosch.us/content/language1/html/2706.htm _________________ "What a fool believes he sees, no wise man has the power to reason away." Dobee, Dobee, Do |
olivierfr Samba Member
Posted: Tue May 01, 2007 2:33 am Post subject: bosch 343 ? |
Does anybody know what is a 343 distributor ? |
EverettB Administrator
Joined: April 11, 2000 Posts: 69809 Location: Phoenix Metro
Glenn Mr. 010
Posted: Tue May 01, 2007 7:35 am Post subject: |
No... the KDF used a "343" distributor where the last 3 digits were 343... like the "383" used in the Splits. _________________ Glenn
Member #1009
#BlueSquare |
25horseboxer Samba Member
Posted: Tue May 01, 2007 8:54 am Post subject: |
or like the common 009, 010 dist. |
Glenn Mr. 010
Posted: Tue May 01, 2007 8:59 am Post subject: |
25horseboxer wrote: |
0231 137 009 or 0231 178 009
VJU4BR8 or VJR4BR8
You really can't use just the last 3 digits. _________________ Glenn
Member #1009
#BlueSquare |
Posted: Tue May 01, 2007 9:47 am Post subject: |
Yes, I figured that out when I came across a vacuum advance 009! |
HeSa Samba Member
Joined: January 15, 2007 Posts: 466 Location: FINLAND
Posted: Tue May 01, 2007 10:08 am Post subject: |
Anyone information on ver4brs383? No visual difference compared to ve4brs383. And it accepts flat cap and rotor.
Posted: Tue May 01, 2007 1:35 pm Post subject: |
I mean end of reference is 343, as a 383 distributor , but 343.
so, it's kdf one, thanks Glenn .
EverettB wrote: |
Do you mean it has a part # beginning with 343? For example 343 905 205.
343 = Type 34, although most Type 34 parts I have seen begin with 341. |
usariemen Samba Member
Joined: August 28, 2004 Posts: 1745 Location: Germany
Posted: Tue May 01, 2007 1:47 pm Post subject: |
Hello
Funny, to come home and see this thread.
I just bought this morning on a swap meet a carb that seems just the one there was talked about. Here are pics.
The number says VEK 4 BS 343 T
By the way. The lovely "traffic jam" on the way to the place.
Heb in front, then a swimmer, a early oval, a split vert and a barndoor.
_________________ Master of my domain! |
Glenn Mr. 010
Posted: Tue May 01, 2007 1:59 pm Post subject: |
HeSa wrote: |
The "R" means it was intended to use with a rotor that has a resistor in it, but the distributors are identical.
I've worked on both VJ4BR25 and VJR4BR25 and they are identical.
VJ4BR25
VJR4BR25
Member #1009
#BlueSquare |
HeSa Samba Member
Posted: Tue May 01, 2007 2:40 pm Post subject: |
Thanks Glenn, it did come with a taller non-flat-cap rotor. Holy simplicity but what is the function of a resistor in the rotor? Why would a VW 25 hp or Porsche 356 have this option? |
Posted: Tue May 01, 2007 2:48 pm Post subject: |
The resistor was meant to prevent distortions of the radio income I think. _________________ Master of my domain! |
Glenn Mr. 010
Posted: Tue May 01, 2007 3:07 pm Post subject: |
usariemen wrote: |
The resistor was meant to prevent distortions of the radio income I think. |
Exactly. _________________ Glenn
Member #1009
#BlueSquare |
HeSa Samba Member
Posted: Tue May 01, 2007 3:11 pm Post subject: |
Does this mean that a radio was a factory option at that time and a R distributor came with it? After market radio installer would have just changed the rotor and the cap. Could also be a military or police spesific part? |
coad Samba Scapegoat
Posted: Tue May 01, 2007 3:23 pm Post subject: |
The quickest way to tell a 343 from the more common 383 is the lack of the O-Ring on the shaft (although I think early 383's lack the ring too?)
And the wartime 343's didn't have the "made in Germany" on the ID Tag
