heywebonya Samba Member
Joined: July 08, 2010 Posts: 236 Location: Portage, MI
Posted: Thu Dec 22, 2011 10:02 am Post subject: |
Wythac, Great guidance, I went by a fabricator today with picture of a simple cage. One of the pictures is your buggy.
I am also going for the third iteration of the strap. I think I may have built it to snuggly up to the die rather than the pipe. _________________ If I knew what I was doing; I wouldn't be building a buggy! |
BuggyFaron Samba Member
Joined: September 01, 2005 Posts: 309 Location: Canyon Lake, Texas
Posted: Thu Dec 22, 2011 11:19 am Post subject: |
I loaded my Street Buggy on a trailer and took it to 3 Fab Shops one day. I ended up going with a guy that has been building and repairing Race Cars for over 50 years. He is going to fab up a area around the back of the chassis to clean it up a little. Then he will build out the floor pieces, floor cross members that will mold over the center tunnel, front and back hoops, a center cross member in the rear hoop to install 3 point seat belts, center cross member front hoop to install the steering column, cross members between the front and back hoops, and down posts for looks in the back. The top half of the cage will be removable so that I can remove the body a little more easily to work on it, or should I say be honest and say repaint the body from time to time. I will be making up my mind on if I want side cross members between the front and the back hoop on Tuesday. He gave me an estimate of $1500.00, and I have added a few ideas. I am expecting to pay between $1700.00 and $2000.00, I will let you know when I pick it up. Just watch my build thread I will be posting photos as well as the finial price. _________________ Come join us at the Buggy Blast in Marble Falls. |
joescoolcustoms  Samba Member
Joined: August 08, 2006 Posts: 6323 Location: West By God Virginia
Posted: Thu Dec 22, 2011 1:01 pm Post subject: |
In the next couple of weeks I will be ordering 10 joints (I will get a price break at 10 joints) of 1 5/8 inch CREW tubing at $ 4.12 per foot, tax included.
I am figuring around 100 feet of tubing in my cage. That is $ 412.00 just in tubing. It does not include the welding supplies, additional plate steel, grinding wheels, a couple hole saws for the tubing notcher, electric for the welder, labor, overhead and profit. My cage will be more extensive than a 6 point cage, but will include custom bumpers and side impact protection.
In addition to my buggy build, I am building a '56 oval into a baja that will also have a cage, rock sliders, custom bumpers and so forth.
I cannot afford to pay a fabricator to build my design. So... I modify and use my HF Kinker to get er done. I turn my labor/time into the finished product I desire.
If you do not have the tools or the ability to imagine the design and go from a thought in your head to a finished product, finding a fabricator just may be the best route to go. Screwing up a couple bends on a main hoop will cost you more in the long run in wasted tubing. _________________ The early bird might get the worm, but the second mouse gets the cheese.
Looks like it was painted with a live chicken,polished with a brick and buffed with a pine cone
Member of Wagenfolks
http://images.thesamba.com/vw/gallery/pix/870707.jpg
http://www.thesamba.com/vw/forum/viewtopic.php?t=479740 |
MURZI Samba Member
Joined: August 25, 2005 Posts: 3689 Location: Madisonville, La
wythac Samba Member
Posted: Thu Dec 22, 2011 6:22 pm Post subject: |
The "knockdown" cage I was thinking of buying was from Neil at Hawkeye Buggies, like the one on Murzi's buggy. My decision not to go that route had nothing to do with the quality of Neils work, I was ready to pull the trigger. It was more that when I considered that for the cost of the cage and shipping from TX, I could throw a few extra hundred (OK, several hundred) bucks toward an upgrade of my welding equipment to a new wire feed and a bender.
I think I was into the materials (about 100ft of 1.5" .120 wall DOM) about 4-500 bucks....same material today would be about double. If I had to do it again today I would use CREW metal tube. Add the cost of a new wire feed and a bender to that and my cost was over 2K...but I still have all my fabrication tools and still use them on other things, so that cost is amortized.
I would say that unless you considering doing more tube work once your cage is done, if you can find someone to do it for 1500-2000 bucks you are doing really well...most everything else you need you can do with simple metal fab tools, grinders, and a stick welder. |
Posted: Thu Dec 22, 2011 6:57 pm Post subject: |
I tried the screw down strap method without success. I think it may be the 1.25 tubing in the 1.33 die.
I am going to try the 1" next. I would like to build my cage out of smaller diameter tubing to limit the interferences.
Did you special order 1.625" (1 5/ tubing? The down side to ordering is the vendor never gives discounts on orders, I can get drops for 1/2 price.
Jeff _________________ If I knew what I was doing; I wouldn't be building a buggy! |
Posted: Thu Dec 22, 2011 9:43 pm Post subject: |
| Quote: | | Did you special order 1.625" (1 5/ tubing? |
Yes, I had to order the 1 5/8 tubing. It takes two days to come in after ordering. My supplier normally carries 3 to 4 sticks of the tubing on stock, but they have a truck running from Chicago on Tuesdays and Thursdays. _________________ The early bird might get the worm, but the second mouse gets the cheese.
forkzilla Samba Member
Joined: November 20, 2009 Posts: 154 Location: North Central Ohio
Posted: Sun Dec 25, 2011 5:38 pm Post subject: |
| I work for a company that manufactures DOM tubing from 12.500 OD down to 1.000 OD, and they sell it to employees (scrap) for 6 cents per pound. I am using 1.750 X .120 1026 DOM for my rail, but they only let us buy 1000 pounds per year. |
didget69 Samba Member
Joined: July 22, 2004 Posts: 2805 Location: Capital, North Carolina
Posted: Mon Dec 26, 2011 9:26 am Post subject: |
| forkzilla wrote: | | I work for a company that manufactures DOM tubing from 12.500 OD down to 1.000 OD, and they sell it to employees (scrap) for 6 cents per pound. I am using 1.750 X .120 1026 DOM for my rail, but they only let us buy 1000 pounds per year. |
New year & new 1,000 lb allotment starts a week from today...
You could make new friends here quickly on the Forum -
bnc _________________ Internet listed credentials impress no one but Mom... |
VOLKSWAGNUT  Fastest VW Belt Changer
Joined: October 14, 2007 Posts: 4903 Location: At the wheel in N.C. U.S.A.
Posted: Thu May 24, 2012 9:22 am Post subject: |
Draggin' this back up...
Does anyone sell prefab roll cages with slip joint for buggies.
I need to upgrade my mouse trap roll bar to a cage. _________________ aka Ken
Your car picture into a kustomizable piece of frameable art. http://www.thesamba.com/vw/classifieds/detail.php?id=1471653
Search "VOLKSWAGNUT" on YouTube since you cant watch "IT" here.
Better to roll em' how you want and wear em' out.... then let em' rot out.
It's more about the going --- not the showing.
Rebuilt to drive not decorate. |
streetbuggy8804 Samba Member
Joined: August 25, 2009 Posts: 525 Location: Long Beach, Ca
Posted: Thu May 24, 2012 2:56 pm Post subject: |
First time ever. Bent this on up in about 2 hours. Rented in from Craig. You can find him on here if you type in tube bender rental. Awesome service
[IMG]http://i6.photobucket.com/albums |
Posted: Thu May 24, 2012 2:58 pm Post subject: |
Well that didnt work.
Posted: Mon Jun 04, 2012 9:41 am Post subject: |
| VOLKSWAGNUT wrote: | Draggin' this back up...
I need to upgrade my mouse trap roll bar to a cage. |
Really? Nobody makes a universal Buggy prefab unit? _________________ aka Ken
GTBRADLEY Samba Member
Joined: February 27, 2009 Posts: 580 Location: Katy Texas
Posted: Mon Jun 04, 2012 11:19 am Post subject: |
Hawkeye will. You will just have to do some good measuring and he will weld one up for you. Give them a call. Very reasonable too. You can pick it up when you come to Texas for the Buggy round up for LaborDay  _________________ Brian B
1973 Surfer GT Boat
1966 Thunder Bug Buggy-current project
1949 Dodge Coronet-retirement project
that is family owned since new |
Posted: Mon Jun 04, 2012 11:52 am Post subject: |
Yeah I need one shipped...not heading to TX for that one. _________________ aka Ken
Posted: Mon Jun 04, 2012 12:06 pm Post subject: |
He'll ship. I think JSPTown got his show cage from there and he is in the northeast _________________ Brian B
1973 Surfer GT Boat
Posted: Mon Jun 04, 2012 12:07 pm Post subject: |
| GTBRADLEY wrote: | | He'll ship. I think JSPTown got his show cage from there and he is in the northeast |
Got a contact number or information? _________________ aka Ken
Posted: Mon Jun 04, 2012 1:03 pm Post subject: |
http://www.hawkeyebuggies.com/ _________________ Brian B
1973 Surfer GT Boat
Posted: Mon Jun 04, 2012 1:22 pm Post subject: |
| GTBRADLEY wrote: | | http://www.hawkeyebuggies.com/ |
Thanks..
I've made the first contact
Ill report the results. _________________ aka Ken
