deadaheadub Samba Member
Joined: April 18, 2004 Posts: 787 Location: New Mexico
Posted: Sun May 06, 2007 6:41 pm Post subject: replacing dipstick boot |
Can I do it without removing the fan housing? |
hazetguy Samba Member
Joined: April 06, 2001 Posts: 10773 Location: iT StiNgeD iTseLf tO dEAd
Posted: Sun May 06, 2007 6:43 pm Post subject: |
yup _________________ thebucket: I invested in hoodride, now DBD won't return my call?
hazetguy: invested?
thebucket: Yeah Haze, its where people put money into a company in hopes of a return on their money |
EZ Gruv King of Plaid
Joined: December 10, 2002 Posts: 8544 Location: Las Vegas
Posted: Sun May 06, 2007 6:46 pm Post subject: |
Its a tough job, but yeah it can be done. Be patient. _________________ Eric
1977 Deluxe Westfalia - 2.0L FI Type IV, Completely Original
Photographer for HotVWs, VolksWorld, AirMighty, VW Camper & Commercial, Hayburner, and more.
My Photography Page. |
Randy in Maine Samba Member
Posted: Sun May 06, 2007 6:47 pm Post subject: |
Airheadparts.com
Part Number: 021-119-245
Type 2 72-79, Type 4 Wagon 70-74
Made from quality VITON. Easier to Install and Longer Lasting! $2.95
Long skinny screwdriver and some patience helps. |
vdubyah73 Samba Member
Joined: July 05, 2003 Posts: 2541 Location: somewhere in Texas, my house has wheels
Posted: Sun May 06, 2007 6:58 pm Post subject: |
Gotta hold yer tongue right! Walk away from it when you feel frustration mounting.
Bill _________________ burning down the house
73 bounty hunter, sold.
'77 transporter, junked had crotch rot.
Dubless, but have a CPR built stroker waiting for a new to me Beetle
'93 Fleetwood Bounder 34' |
Posted: Sun May 06, 2007 7:03 pm Post subject: |
installation tip:
use some silicone lubricant inside the ends of the boot.
slide the boot onto pipe that comes out of the case. slide it down as far as you can, until the top of the boot clears the pipe sticking out of the fan housing.
then slide boot upwards onto the pipe in the shroud until there is equal amounts of the boot on both pipes.
i don't think you'd get it on if you tried to put it on both pipes at the same time. _________________ thebucket: I invested in hoodride, now DBD won't return my call?
hazetguy: invested?
Posted: Sun May 06, 2007 7:28 pm Post subject: |
Thanks, all. I'll take all tips. |
Zeen Samba Member
Joined: July 24, 2004 Posts: 1308 Location: The Sunny Part of Michigan
Posted: Sun May 06, 2007 7:32 pm Post subject: |
I use the trick of warming the boot in boiling water to soften it up. Seems to help. _________________ The consequences of your decisions should not be confused with fate. |
JMazier Samba Member
Joined: February 20, 2006 Posts: 900 Location: In my garage, Georgetown, Ontario, Canada...
Posted: Mon May 07, 2007 3:33 am Post subject: |
My wife installed ours...small hands help... She also indicated that having it well warmed up helped. Use a screwdriver under the lip to help push it up but on be careful not to puncture it. _________________ Cheers!
Jérôme
’79 Cali Westy 2.0 F.I.
'74 Honda CB 350 Four
'78 Honda CB 750 K
'12 Golf GTI
'11 Ural Patrol |
Posted: Mon May 07, 2007 7:36 am Post subject: |
You all are talking about on a 2.0 L, right? I forgot to mention that. So I don't have to remove the tin that the alternator is behind and attached to?
Thanks for the help |
Posted: Mon May 07, 2007 8:30 am Post subject: |
deadaheadub wrote: |
Yes, 2l... My wife did remove the tin under the engine that covers the thermostat. She said that it was not necessary but made it easier...4 screws to remove for that tin... _________________ Cheers!
Jérôme
'78 Honda CB 750 K
'12 Golf GTI
'11 Ural Patrol |
Posted: Mon May 07, 2007 10:06 am Post subject: |
Thanks for the help, people.
This site is such a great resource to have to be able to turn to for help! |
Posted: Mon May 07, 2007 6:41 pm Post subject: |
in this thread in 2005 http://www.thesamba.com/vw/forum/viewtopic.php?p=2189384&highlight=#2189384
udidwht wrote: |
First remove your dipstick and remove the old dipstick boot. Then slide the narrow end of the boot on first, then carefully work the larger side of the boot onto the opening while using the (long slender screwdriver to work the boot around the larger opening). |
I'm kind of confused. I thought the fatter end goes on first and sits at the bottom? What larger opening? Isn't there just one tube? Don't you slide the boot from the top down, fat end on first and at the bottom, thinner end at the top? Thanks |
Zeen Samba Member
Posted: Mon May 07, 2007 8:12 pm Post subject: |
udidwht wrote: |
There's no magic, whichever way you go it's just a pain the ass. You'll probably end up trying it both ways, and the one that works will be the one you swear by. Try Hazetguy's method first, he's done it a million times. _________________ The consequences of your decisions should not be confused with fate. |
trackwesty Samba Member
Joined: May 11, 2004 Posts: 511 Location: Long Beach, CA
Posted: Mon May 07, 2007 8:28 pm Post subject: |
Make sure you get a quality one I believe airhead parts now have them made from Viton rubber. A few years ago I got one from WCM and it cracked in a few months. They gave me another one and it was fine.
I put mine on the oil filler (large side) then used the dipstick to help align the small end with the dipstick tube. but overall its a PITA for sure. _________________ AKA The Mummy |
Posted: Tue May 08, 2007 8:49 am Post subject: |
trackwesty wrote: |
Make sure you get a quality one I believe airhead parts now have them made from Viton rubber. |
I already got one from BusDepot. Anyone know of its quality? Is it viton?
Quote: |
I put mine on the oil filler (large side) then used the dipstick to help align the small end with the dipstick tube. but overall its a PITA for sure. |
Isn't it all one "tube" you're pushing it down over, the tube that the dipstick gets pushed into? And that just goes straight through the black metal tin that the alternator is bolted to, and then through the thicker aluminum fan shroud, as all one continuous tube, until you reach the point it connect with the actual oil filler tube base? Sorry for the noob questions, but this talk of slipping it down over one tube and then a smaller tube is confusing me. Putting it over the "oil filler" (which I consider the place where I add oil, not where I put the dipstick), I can't make sense of, most likely due to my lack of experience (that's why I'm doing all of this myself- to gain needed experience!) . Don't I "just" slip it down the one dipstick tube all the way, with the fat end first?
Sorry and thanks! |
Posted: Tue May 08, 2007 9:16 am Post subject: |
78westy not westy78 wrote: |
There's no magic, whichever way you go it's just a pain the ass. You'll probably end up trying it both ways, and the one that works will be the one you swear by. Try Hazetguy's method first, he's done it a million times. |
lol, a million? i wouldn't say that. but i would say that i've done it 3 times in the past month. when i worked at a VW shop i would do it somewhat regularly. i just find it "easier" to put it on the large, tapered end first.
it is not one tube, hence the need for a boot. through the fan housing it is one tube, but it is not one tube all the way in to the engine case. there is a gap between the tube in the fan housing, and the end on the oil filler pipe. it is not much of a gap, which makes installation of the boot (besides the crapmed space) somewhat of a pain.
tube coming through fan housing:
"tube" on oil filler showing boot orientation and different sized ends:
hazetguy: invested?
Posted: Tue May 08, 2007 10:02 am Post subject: |
Thank you, Hazetguy! Those pics and your comments are very helpful and informative to me, the uninformed. From that top photo it looks like there is no room between the tube coming through the fan housing and the fan housing. Can the boot go around the outside of that tube as it goes through the housing (thus the PITA), or does it go inside that tube and then around the outside of the the second lower tube that is attached to the oil filler? My dipstick tube sticking out of the housing has some kind of putty? around it at the point it enters the housing so I haven't seen what kind of gap there is to squeeze the boot through, which is what I've imagined I'm going to have to do. Is that putty? rubber? stock, part of the old boot, or a half-assed attempt to stem the flow of oil without changing the broken boot?
Thanks again
Posted: Tue May 08, 2007 10:09 am Post subject: |
hazetguy Those are some nice pics!
Quote: |
My dipstick tube sticking has some kind of putty? around it at the point it enters the housing so I haven't seen what kind of gap there is to squeeze the boot through, which is what I've imagined I'm going to have to do. Is that putty? rubber? stock, part of the old boot, or a half-assed attempt to stem the flow of oil without changing the broken boot?
Could be any and all that you mentioned, but it supposed to be clean. But it could be some epoxy used to seal the area due to a loose fitting tube.
Quote: |
Can the boot go around the outside of that tube as it goes through the housing (thus the PITA), or does it go inside that tube and then around the outside of the the second lower tube that is attached to the oil filler? |
It goes on the outside of both. _________________ AKA The Mummy |
