Tuke71 Samba Member
Posted: Fri May 21, 2021 2:36 pm Post subject: Checks whole engine is out |
I am restoring a 1971 Beetle. I’ve removed the motor so I could better get at the engine compartment to clean and repaint if. I was wondering what checks should I do while he motor is removed from the car?
Thank you in advance |
VW_Jimbo Samba Member
Joined: May 22, 2016 Posts: 9971 Location: Huntington Beach, CA
Posted: Fri May 21, 2021 3:21 pm Post subject: Re: Checks whole engine is out |
Welcome to the Samba!
Remember, front is front of the car, and rear is rear of the car!
I would look at the transmission mounts (all 3), the transmission rear seal, the engine front seal, the clutch plate, the TO bearing, the input shaft, engine compartment seal.
On the engine, take a look at everything! Go through and snug up whatever is loose.
Have fun! _________________ Jimbo
TDCTDI wrote: |
67rustavenger wrote: |
GFY's Xevin and VW_Jimbo! |
67rustavenger Samba Member
Joined: February 24, 2015 Posts: 9772 Location: Oregon
Posted: Fri May 21, 2021 3:46 pm Post subject: Re: Checks whole engine is out |
If there is a moist with oil spot on the left side of the engine. Look to see if the oil cooler seals are leaking.
If funds are available. Install new fuel lines and move your fuel filter next to the trans where the hard fuel line comes out of the frame horn.
Maybe clean up some of that jacked/hacked up wiring in the engine compartment too.
Are the compartment seals in good nic? This is an opportune time to put new ones in. .
Also are the sound deadening cards in good condition? You want them to be firmly against the rear firewall. If the sound deadening sags away from the firewall. It can block the fresh air flow to the fan intake. That is a bad thing!
Yet another good time to change them.
There's more to check. But these two posts are a good start.
X2 on the welcome to the samba. Have fun and enjoy your ride. _________________ I have learned over the years.
Buy Once, Cry Once!
Glenn Mr. 010
Joined: December 25, 2001 Posts: 76949 Location: Sneaking up behind you
Posted: Fri May 21, 2021 4:36 pm Post subject: Re: Checks whole engine is out |
Check the wiring to the rear lights. Much easier to correct with the engine out. _________________ Glenn
Member #1009
#BlueSquare |
AutoMechanic Samba Member
Joined: December 28, 2019 Posts: 483 Location: Roanoke Virginia
Posted: Fri May 21, 2021 9:17 pm Post subject: Re: Checks whole engine is out |
Definitely the transmission mounts like another poster said. |
Tuke71 Samba Member
Posted: Fri May 21, 2021 10:32 pm Post subject: Re: Checks whole engine is out |
Glenn wrote: |
Check the wiring to the rear lights. Much easier to correct with the engine out. |
I replaced the entire wiring harness already. No oil leaks anywhere that are noticeable. I’ll check the trans mounts tomorrow. Mot real sure how go check the seals. This is all sort of new to me but I’m picking it up faster than I expected. |
Marinablau703 Samba Member
Joined: January 09, 2021 Posts: 169 Location: Hudson Valley/LI, NY
Posted: Sat May 22, 2021 5:09 am Post subject: Re: Checks whole engine is out |
If removal of the fan shroud isn't on the list, it should be. Vermin LOVE to make nests in there, and then the engine cooks. In my case, my shroud was clear, but the oil leaks built up so much gunk on the cylinders that there were no cooling fins: the cylinders were smooth! While the engine is out, replace every seal in the thing, even the ones that aren't leaking. My oil cooler seals were solid plastic by this point, and I pulled 24 pushrod tub seals off of 8 pushrods...
Also clutch kit, as it is a cheap "might as well." Brand new Sachs clutch, pressure plate, throw out bearing and alignment tool with lifetime warranty from FCP, only $70. When the clutch wears out, I send it back and get a new one for the cost of shipping. |
gt1953 Samba Member
Posted: Sat May 22, 2021 6:01 am Post subject: Re: Checks whole engine is out |
Take your time and photos. It is nice to see before and after. _________________ Volkswagen: We tune what we drive.
72 type 1
72 Squareback
Pez Samba Member
Joined: September 16, 2003 Posts: 583 Location: Texarkana
Zundfolge1432 Samba Member
Posted: Sat May 22, 2021 7:18 pm Post subject: Re: Checks whole engine is out |
Learn how to check parts for wear. The specifications are in Bentley manual. Just shotgunning and replacing can get expensive. The aftermarket parts available now are shit compared to OEM. Some people here are using 60 year old parts and they are fine. I’m using clutch parts from 1960s and 70s |
Max Welton Samba Member
Joined: May 19, 2003 Posts: 10697 Location: Black Forest, CO
