piercedvw Samba Member
Joined: December 28, 2006 Posts: 109 Location: BC Canada
Posted: Wed May 16, 2007 7:20 pm Post subject: Seam sealer.. rust bullet.. what comes first? |
Ok.. dumb... but kinda not.. I've got new welds in areas.. seam seal and THEN rust bullet?
.. and then in the engine area, I've scraped out all the old sealer (muddy mess underneath...)... light coat of rust bullet first then seam sealer?? |
Posted: Wed May 16, 2007 7:23 pm Post subject: |
Here's pics..
Berfore:
During
After
toddyvol Samba Member
slow36hp scott wimberley
Joined: August 09, 2004 Posts: 3113 Location: mukilteo washington
VWsArent4Hippies Samba Member
Joined: April 13, 2005 Posts: 3076 Location: The Bull City
Posted: Wed May 16, 2007 8:21 pm Post subject: |
Depends on the kind of seam sealer you're using. SEM and 3M both make flexible seam sealers that can be applied over bare metal and painted on in about 30 minutes. _________________
aeromech wrote: |
in my opinion you don't know shit |
That's what I was thinking.. Thanks guys. |
fungi Samba Member
Thrasher22 Samba Member
Joined: October 05, 2010 Posts: 858 Location: Calgary, Canada
Posted: Sun Oct 12, 2014 2:35 pm Post subject: |
With any rust treating product, it won't work unless it actually makes contact with the rust. But at the same time, you might have adhesion issues if you apply seam sealer over paint, especially of rust bullet has a glossy finish. If that is the case, you'd just need to scuff the surface. _________________ 1975 Westfalia - http://www.thesamba.com/vw/forum/viewtopic.php?t=516701 |
Northof49 Samba Member
Joined: July 22, 2013 Posts: 1759 Location: Winnipeg, Manitoba, Canada
Posted: Mon Oct 13, 2014 9:03 am Post subject: |
It's the lack of paint ability why they say not to use silicone based. I did one side of my jeep with body shop seam sealer and the other side with black silicone. Both over epoxy primer. The silicone held up perfectly after 10 years of salty winters. The body shop seam sealer contracted and cracked in some places. When I peeled some silicone off, it showed perfect metal underneath. I used it on floor repairs too. Sealed out corrosion perfectly. Just doesn't take to painting well. It would make perfect undercoating if it were cheaper. _________________ 1958 Karmann Ghia owner |
fungi Samba Member
Posted: Mon Oct 13, 2014 11:17 am Post subject: Spoke with Rust Bullet Rep |
I ended up talking to a rep at Rust Bullet. There advise is two coats of Rust Bullet first. Then urethane based Seam Sealer. Then another coat of Rust Bullet.
Rust Bullet is urethan based so they should work well together. If the application directions are followed carefully. i.e. respect flash times etc...
I am using 3m Dynatron 552 & 550 Seam Sealer.
FYI: same advise for applying Body Filler, fiberglass, Primer
http://www.rustbullet.com/faqs/automotive _________________ http://rivieraresto.blogspot.com/ |
