vmx12vmx12vmx12 Samba Member
Joined: March 19, 2005 Posts: 155 Location: Ontario, Canada
Posted: Sat May 19, 2007 7:17 pm Post subject: Clutch problem |
I just installed my pedal assembly today and my motor a couple months ago....the clutch it seems will never disengage the motor from the trans...I adjused it with slack and re-adjusted it the butterfly about an unvh on the thread...close to the end. I knoe last year it all worked fine, and I never took the clutch out of the car...is there something I could have done wrong installing the motor? Or is there an adjustment I can make to the clutch itself???????????
my dealine awaits. _________________ "Don't you say another word about dat boy. Fact'o business, don't you say another word to me. I ain't listening to you no more mmmhhmm"---Slingblade---"I like them French fried potaters" |
Towel Rail Horizontally Opposed
Joined: April 15, 2005 Posts: 4622 Location: SE CR IA US NA PE
Posted: Sat May 19, 2007 7:26 pm Post subject: |
What's your clutch pedal freeplay? Should be 3/8"-3/4". _________________ 1974 Thing -- under the knife
1967 Beetle -- spring/summer/fall driver
1996 Subaru OBW (EJ22, 5-speed, AWD) -- winter car, 3-seasons "don't feel like biking today" car
049 > 070 > 053 > 009 |
Posted: Sat May 19, 2007 7:32 pm Post subject: |
I had about 1 inch and I tightened it and loosesed it...nothing seems to make any difference.... _________________ "Don't you say another word about dat boy. Fact'o business, don't you say another word to me. I ain't listening to you no more mmmhhmm"---Slingblade---"I like them French fried potaters" |
Posted: Sat May 19, 2007 9:06 pm Post subject: |
LOL, I am very tired...I re-read my post and it looks as though I failed grade 4 english..I'll try again...
I just installed my pedal assembly today and my motor a couple months ago....the clutch it seems will never disengage the motor from the trans, althought the shifter works with engine off...I adjusted the freeplay....there is good resistance on the pedal. I know last year it all worked fine, and I never took the clutch off the flywheel...is there something I could have done wrong installing the motor? Or is there an adjustment I can make to the clutch itself??????????? _________________ "Don't you say another word about dat boy. Fact'o business, don't you say another word to me. I ain't listening to you no more mmmhhmm"---Slingblade---"I like them French fried potaters" |
suntour Samba Member
Joined: November 25, 2004 Posts: 443 Location: Woodinville, WA
Posted: Sat May 19, 2007 9:46 pm Post subject: |
Have someone press the clutch petal down while you’re under the car and see how far the cable moves. If it looks fine or looks like it moves and inch or so and no amount of adjustment to the cable fixes your problem I would consider pulling the engine and having a look. Sometimes the factory spot welds on the throw-out fork break. If one or both spot welds break your throw-out bearing will not fully disengage the pressure plate.
(I hope that makes sense.) _________________ Order of the Voodoo Spoon |
Posted: Sat May 19, 2007 9:56 pm Post subject: |
While we're on the topic, do any of you guys use the "heavy duty" cross-shafts? _________________ 1974 Thing -- under the knife
TimGud Samba Member
Joined: March 03, 2002 Posts: 6459 Location: Rio Rico Arizona
Posted: Sun May 20, 2007 7:58 am Post subject: |
The cable may have come off the hook when you installed the pedal assembly. |
Posted: Sun May 20, 2007 8:48 am Post subject: |
had my darlin wife press the clutch down while I was under the car...I get over an inch of movement at the 'clutch arm where the buterfly adjustment nut is. _________________ "Don't you say another word about dat boy. Fact'o business, don't you say another word to me. I ain't listening to you no more mmmhhmm"---Slingblade---"I like them French fried potaters" |
Posted: Sun May 20, 2007 5:02 pm Post subject: |
everything checks out outside the bellhousing...i'm getting about an inch to 1.5 inches of movement at thre adjuster.... I even put a large nut on before the wingnut to give it that much more....still nothing...Do I pull the motor now? and look for what? Nothing was touched since it last worked...could I have eukred it when installing the motor? _________________ "Don't you say another word about dat boy. Fact'o business, don't you say another word to me. I ain't listening to you no more mmmhhmm"---Slingblade---"I like them French fried potaters" |
Ray Syverson Samba Member
Joined: February 12, 2006 Posts: 74 Location: Lake Zurich, Illinois
Posted: Sat May 26, 2007 8:05 am Post subject: |
How long was your engine sitting out of the car with the clutch attached ?Your clutch disc may have slightly bonded itself to the flywheel and now it wont disengage.This happened to me.I took the engine out to replace the clutch in the fall.The engine sat till spring with a new clutch on it before I put it back in the car. The clutch would not release.Took the engine out. The clutch disc was stuck onto the flywheel.You can try rocking the Thing with the shifter in neutral to break the bond if this is the problem.
Its been a few days since your posting so perhaps you've found the problem by now. If not I hope this helps. Ray. |
markie61 Samba Member
Joined: April 11, 2005 Posts: 583 Location: Northern Virginia
Posted: Sat May 26, 2007 9:36 am Post subject: |
Towel Rail wrote: |
While we're on the topic, do any of you guys use the "heavy duty" cross-shafts? |
Yes. Got one with the red urethane busings from CIP. But the bushing was so tight, it wouldn't release the arm, so I reintalled the old bushings. Worked great.
Mark _________________ Whut is that-there Thang!?
Chicks dig my Thing - so what if it's little and yellow...!? |
