What did you do for your Bus today?
Goto page Previous  1, 2, 3 ... 481, 482, 483 ... 525, 526, 527  Next
dawerks
dawerks is offline
PostPosted: Thu Jun 28, 2012 7:51 pm    Post subject: Reply with quote
It's better to point it into the vents, and squeeze till the extinguisher is done. Then wait!
If you open the engine bay, you're feeding the fire with what it wants, oxygen. I've never had to test this out, but instead of messing with opening the hatch, etc. I would grab my fire ext. and jam the nozzle in a vent and go to town.
57 PGSG 'Carpet Bus'
"There is only one sin; disconnection from self."
Tyler 5447 Premium Member
Tyler 5447 is offline
PostPosted: Fri Jun 29, 2012 6:53 pm    Post subject: Reply with quote
Finished installing my interior panels from Clara in my '64 Single Cab today. Can't find the cable to download pictures right now though.
'64 Single Cab-----
http://www.thesamba.com/vw/forum/viewtopic.php?t=505634
'58 Panel Van------
http://www.thesamba.com/vw/forum/viewtopic.php?t=518055
Da TOW'D
Da TOW'D is offline
PostPosted: Fri Jun 29, 2012 7:00 pm    Post subject: Reply with quote
good points Dawerks
so today I showed my grandson where the fuel lines run and where the the most likely fuel problems would happen
cheers
'57 type 1 Blackberry
'58 SC Ruf
'86 Vanagon Syncro "syncro da Dr.Mayo"
and NUTS
BorisGrishenko
BorisGrishenko is offline
PostPosted: Fri Jun 29, 2012 7:24 pm    Post subject: Reply with quote
One thing about fire extinguishers is that you have to point them at the base of the fire for them to be at their most effective. Through the vents may get the gas or dry chemical into the engine bay, but whether it will reach the seat of the fire is the real question. Opening the bay will feed more oxygen, but will also allow a much more direct attack on the base.
Now, I don't have a bus handy to look at, but would it be feasible to simply shoot the dry chem up from underneath beside the engine rather than through the vents? It seems like even if the material hit the upper panel of the engine compartment, some of it might drop back down onto the seat. Not as good as direct, but would it be better than angling it into the vents and not having it all go in, or does the nozzle of your extinguisher fit in the vent well enough not to lose any? And would more of it make it over the engine, or stay on the side?
I don't have much fire extinguisher use experience on vehicles, I've always used a fire hose in the past, where there's not a limited supply.
2006 Jetta TDI Mk. V
Hope someday to add a bus
Campy
Campy is offline
PostPosted: Sat Jun 30, 2012 12:58 am    Post subject: Reply with quote
I have begun going through the "restored" 1959 double door panel that I bought through Ebay.
The worst thing the body man did was to overlap sheet metal (behind)over a window hole that had been cut on each side of the upper rear side, tack weld it, and fill up the gap on the outside and beyond it with filler. I've removed the main filler and, after removing the sheet metal backing, I will butt/tack weld inside each hole with upper side sheet metal that I cut off an old bus body.
As seems to be the norm, I had to make two lengthwise cuts in the front shifting shaft coupler in order to remove it, then I removed the front shifting shaft so I could drop the stock frontend and install the 1964-1967 frontend that I had rebuilt and painted black. It looks good.
The body was painted inside and outside but has "orange peel" on the outer body, and what was supposed to be light gray paint looks beige, so I will be repainting it.
Don't worry; be happy. (Baba)
Clara Premium Member
Clara is online now
PostPosted: Sat Jun 30, 2012 11:45 am    Post subject: Reply with quote
Greg removed the spun drum from our new 55 truck.
You have to jack the axle tube down with a scissors jack to get the tire off:
The drum was bad:
The area the nut tightens against on was worn into a dish:
The new drum is Italian:
cdennisg
cdennisg is offline
PostPosted: Sat Jun 30, 2012 1:59 pm    Post subject: Reply with quote
Clara wrote:
Check out Clara's Bling!
Olddog52 wrote:
horn test. one tab to ground, the other to a 12 volt source. Listen intently for a sound.
cru62
cru62 is offline
PostPosted: Sat Jun 30, 2012 2:11 pm    Post subject: Reply with quote
SAK & BRMs! Shocked Are Greg and Clara taking a walk on the WildSide?
Founding member of
Arrested Decay
WANTED-Safari Latch-HELP! http://www.thesamba.com/vw/classifieds/detail.php?id=1441574
"Buy the best and cry once."-Gene Berg
crukab
Samba Chef
crukab is offline
PostPosted: Sat Jun 30, 2012 3:56 pm    Post subject: Reply with quote
Picked up more Palets today, after unloading, my Dogs had to check out the SC.... My new to us GSD is in the one w/ the red colar.
Oh and I got the truck inspected this week w/ the 2nd 9 pin WW sent me... Confused
'65 Bus/Panel/camper W/T/Shed
'66 Singlecab
'66 Westy
'82 Rabbit Truck
'86 Doublecab W/T
and others.
PostPosted: Sat Jun 30, 2012 4:19 pm    Post subject: Reply with quote
You should be fine now, parts don't break when everything is colour-matched.
How to: Post Photos | Search
Everett Barnes - [email protected] | My VWs | My wanted ads
Jerry
Jerry is offline
PostPosted: Sat Jun 30, 2012 7:29 pm    Post subject: Reply with quote
I found a little time today to button up the overhang.
I was dreading it like the plague but it just fell into place for some reason.
'67 21 Deluxe, Ollie
'66 So42, Misty
'67 13 deluxe
Clara is online now
PostPosted: Sat Jun 30, 2012 8:38 pm    Post subject: Reply with quote
That is gold powdercoat by the P.O.
OK. Test drive. The transmission pops out of 4th. I suppose I should have suspected that when the bus came with a spun drum and no shifter.
type47fan1
type47fan1 is offline
PostPosted: Sat Jun 30, 2012 8:54 pm    Post subject: Reply with quote
Awesome work, I would have dreaded that as well.
My 66 Deluxe Build
http://www.thesamba.com/vw/forum/viewtopic.php?t=490764
My 66 Westy Build
http://www.thesamba.com/vw/forum/viewtopic.php?p=5825134#5825134
Daddybus
Daddybus is offline
PostPosted: Sun Jul 01, 2012 1:47 am    Post subject: Reply with quote
Got the fuel filter and pump away from the heater boxes and exhaust and mounted them so that they would be easy to service.
Bus has been "flying in the driveway" (up on jack stands) for too long according to the city. I've got until July 6th to "remove it" or the city is going to remove it on July 7th. It'll be running tomorrow. I might drive it to city hall, take a picture of it parked in front, and email the picture to my friendly neighborhood code enforcement guy. Funny, some how a college student could park his 350Z on the street from December to June without moving it and it wasn't considered abandoned nor was it towed.
ricekooker
ricekooker is offline
PostPosted: Sun Jul 01, 2012 3:31 am    Post subject: Reply with quote
Nice work Jerry, as usual.
pyrOman
Fire Master
pyrOman is offline
PostPosted: Sun Jul 01, 2012 5:21 am    Post subject: Reply with quote
Do it! Razz
Include a pix of the Z car too! Twisted Evil
Daddybus
Daddybus is offline
PostPosted: Sun Jul 01, 2012 11:30 am    Post subject: Reply with quote
pyrOman wrote:
Do it! Razz
I didn't get a picture of the Z car. Sad
motofly196
motofly196 is offline
PostPosted: Sun Jul 01, 2012 8:02 pm    Post subject: Reply with quote
I got most of my "Uber Kombi" interior panels installed from Clara. Thanks for the locating holes on the back Clara!! Almost all of them lined up perfectly, amazing considering the screws could of been drilled anywhere from the factory! Still have the cab to do. I'll put up some pics when I finish.
Scott
I'm looking to buy a Light Grey decklid and
Pearl White low hinge cargo doors (no recess)
EasternBikesMike
EasternBikesMike is offline
PostPosted: Mon Jul 02, 2012 7:46 am    Post subject: Picked Up From Body Shop Reply with quote
Borrowed my brother in laws wrecker to pick up my 21 today. All the rust is fixed and only needs another a few little things to be ready for paint. Been contemplating taking all the underneath apart and painting. Finally decided to go ahead and do it before he went any further with the body. So now starts the process of removing everything from underneath. Looks pretty straight if you ask me.
WOB1
WOB1 is offline
PostPosted: Sun Jul 08, 2012 12:28 pm    Post subject: Reply with quote
Took the 53 to a local show, together with a friends 49 split beetle Smile))
Page 482 of 527
