RobzKombi Samba Member
Posted: Sat Aug 02, 2014 5:12 pm Post subject: Re: What I did for the Daddybus over summer vacation |
Daddybus wrote: |
What I did on my summer vacation...
-Installed a gas filler flap inside the filler neck to keep the gas from sloshing out when I make a left turn
This is something I would be interested in doing, can you share the info on this mod? |
'64cal lookdub 1200 Deluxe
Posted: Sat Aug 02, 2014 9:44 pm Post subject: |
Fresh tires
zozo Samba Member
Joined: October 15, 2005 Posts: 5217 Location: South of Ol' San Antonio
Posted: Sat Aug 02, 2014 10:04 pm Post subject: |
I finally remembered to clean up the gas filler door and area behind it. I've intended to for years, but never seemed to remember until I opened the door to fuel up. It was so nasty in there I thought it was body putty around the seams. Nope, just crud. I sincerely doubt that anyone had ever actually cleaned it out in there.
ricekooker Samba Member
Joined: April 09, 2006 Posts: 1788 Location: Winter Park, FL
Posted: Sun Aug 03, 2014 5:03 am Post subject: |
'64cal lookdub wrote: |
Fresh tires
Give that paint some love. It looks like it'll buff out nice. |
kenshapiro2002 Samba Member
Joined: April 26, 2013 Posts: 1826 Location: Bawlmer Hon
Posted: Sun Aug 03, 2014 7:10 am Post subject: |
No! You'll remove half of what's left!!! _________________ Looking for a correct 1967 rear seat
Looking for '67 Engine / Block HO 183xxx - HO 194xxx |
Tmiller3 Samba Member
Posted: Sun Aug 03, 2014 7:16 am Post subject: |
Yesterday, I was able to take the 1962 vw bus for a drive for the first time in 25 years! Thanks to scottvw, OgCalLook, and jonny1309 for EVERYTHING they did to help me make this day a reality. You guys are the best!
cdennisg Samba Member
Joined: November 02, 2004 Posts: 20275 Location: Sandpoint, ID
Posted: Sun Aug 03, 2014 9:50 am Post subject: |
kenshapiro2002 wrote: |
No! You'll remove half of what's left!!! |
Not if you do it right, and use TR3 glaze.
_________________ nothing |
Posted: Sun Aug 03, 2014 10:12 am Post subject: |
ricekooker wrote: |
Fresh tires
That's the plan!
cdennisg wrote: |
Thanks for the tip, I was going to try Turtle Wax Color Back or 3M Finesse It-II. The paint is really thin on the drivers side, but you can still see a nice sheen on the passenger side. |
Posted: Sun Aug 03, 2014 10:16 am Post subject: |
I have heard the 3M stuff is good, too, but I have not tried it. _________________ nothing |
motofly196 Samba Member
Joined: June 01, 2008 Posts: 1467 Location: Eastern WA
klcarrie Samba Member
Posted: Sun Aug 03, 2014 9:26 pm Post subject: |
got the LH door off Snappy.
gonna need some a-pillar work...
_________________ Pritchin'
Currently looking for:
- Bay Bus Pinion Nut Socket
- 64-67 big nut (rear) drums and brake parts, 46mm axle nuts (Big Nuts)
'55 Wolfburg Pannel Project
'55 Wolfsburg SC Project
'71 Westy |
turbo_g Father of Samba Cookie Lover
Joined: October 30, 2002 Posts: 717 Location: Laguna Hills, Ca
Posted: Sun Aug 03, 2014 10:19 pm Post subject: |
I took The Hatch camping...
_________________ Turbo_g
66 TinTop Westy SO42
63 Sub-hatch Westy SO33
SV2s Member #425
"Three out of four voices in my head say 'Go for it'." |
pyrOman Fire Master
Joined: July 21, 2003 Posts: 12408 Location: Over 2002 posts deleted!
xavi_242 Samba Member
Joined: May 06, 2005 Posts: 1672 Location: Barcelona (SPAIN)
Posted: Tue Aug 05, 2014 1:48 am Post subject: |
adjusted 4 brake shoes on my westy before the summer holidays... What a difference! _________________ 1967 Split SO-42 Dormobile |
robin.richard Samba Member
Joined: February 17, 2012 Posts: 497 Location: V. Beach VA
Posted: Wed Aug 06, 2014 3:38 pm Post subject: |
Replaced a broken clutch cable. I was surprised how easy it was with the help of this site. Thanks Samba!
Now to learn how to drive without a clutch so I don't have to drive for several miles in first gear again...
-Rich |
mandraks Samba Member
Joined: November 28, 2004 Posts: 7050 Location: Lawrenceville, Ga
Posted: Thu Aug 07, 2014 7:28 am Post subject: |
robin.richard wrote: |
-Rich |
it is very easy to drive a bus without the clutch. Practice it by simulating double clutching.
drive off in 1st, at a fairly low speed try to drive at constant speed. (accelerating and decelerating puts load on the transmission)
now, just take the car out of first into neutral. You will find this is not difficult and does not grind the gears.
Now, without touching your clutch. blip the throttle, step on it briefly, rev it, this will make sure that the motor driven shaft and the rear wheel driven shaft in your tranny both rotate at similar speed. now simply slide it into second like you mean it. if you wait to long or do it too slow it will grind, if you do it right it will just go in.
wash and repeat. Now, shifting up is MUCH easier.
when you downshift the same basic rules apply but you have the really blip the throttle.
Just avoid unnecessary shifts. 3rd is your friend. you can use it exclusively around town unless you need to stop. practice that.
now, if you have to drive it without clutch in traffic and have to stop....
coast to the light in second, leave it in as long as possible, just in case the light turns green before you stop...
once you have to stop, take it out of gear, and stop the motor.
Put it in second!
when the light turns, simply hit the starter, it will start and drive off in 2nd. leave it in this gear until you really need to shift into third, (avoid unnecessary shifts)
back to the double clutching thing, this will make it easier to practice the blipping of the throttle when your clutch is working
step on the clutch, take it out of gear into neutral, let off the clutch, blip the throttle, clutch it, shift, and so forth.
you will find that doubleclutching can become second nature, it helps with downshifts under load. Once you have a good feel for how much to blip the throttle, you will find it easy to stop using the clutch altogether in the higher gears. This is not bad for your transmission either. if you match your throttle to the gear shifts, there is no load on the gears when you shift, it just makes you a better driver, who also can drive their car when the clutch is broken, or when you finally upgrade to an unsynchronized tranny in a really old vw _________________ regards
Uli
Don66bus Samba Member
Posted: Sat Aug 09, 2014 5:42 am Post subject: Double clutching |
I learned early to double clutch old buses. When you are downshifting, going uphill, a double clutch means that you get no engine braking as you drop into the lower gear. Your revs stay higher where the engine has maximum power. |
williamM Samba Member
Joined: August 07, 2008 Posts: 4333 Location: southwest Arizona
Posted: Sat Aug 09, 2014 7:33 am Post subject: |
Rescued the white bus from the painters - yikes _________________ some days I get up and just sit and think. Some days I just sit.
opinion untempered by fact is ignorance.
Don't step in any! |
Daddybus Samba Member
Posted: Sat Aug 09, 2014 1:27 pm Post subject: |
You'll need to vent the top of the phatchick tank to the filler neck if you want to be able to fill the tank completely without having to rock the bus to burp the tank. |
pyrOman Fire Master
Posted: Sat Aug 09, 2014 3:15 pm Post subject: |
True that! It's in the low priority list right now! _________________ Some people are so busy being clever they don't have time enough to be wise. |
