Daddybus Samba Member
Posted: Sun Nov 16, 2014 9:34 pm Post subject: Re: Tow hitch |
Added some gussets to the tow hitch
[/quote] |
RHD Notch Samba Member
Joined: April 06, 2007 Posts: 1412 Location: Joshua Tree, CA
Posted: Sun Nov 16, 2014 10:10 pm Post subject: |
casey & the cricketes wrote: |
i built a couple repair panels yesterday
the outrigger took me a few tries to get right. i made it from 18 gage steel
That's some nice fab work casey & the crickets...you should also post your handiwork here:
http://www.thesamba.com/vw/forum/viewtopic.php?t=534933&highlight=metal
I liked that fab thread a lot, but it seemed to lose steam quickly... _________________
Lind wrote: |
I am at the point where I hardly want to own anything that isn't original paint. |
campingbox wrote: |
I have some other projects I'd like to finish first and I want to drive this bus while I'm working on those to help stay motivated. |
norcalmike Samba Member
Joined: May 14, 2005 Posts: 4784 Location: Marina, CA
Posted: Sun Nov 16, 2014 10:20 pm Post subject: |
On all 4s for the first time in decades
'64cal lookdub 1200 Deluxe
Posted: Sun Nov 16, 2014 10:29 pm Post subject: |
That bus is badass. |
Posted: Sun Nov 16, 2014 10:37 pm Post subject: |
'64cal lookdub wrote: |
Thanks! It's a work in progress but I'm pretty stoked to have it |
srfndoc Samba Member
Posted: Mon Nov 17, 2014 8:38 am Post subject: |
Looks good Mike, what tires did you go with? _________________ RPM=(MPH*336* (R&P*4th*1.26))/Tire Diameter in inches |
Posted: Mon Nov 17, 2014 9:58 am Post subject: |
srfndoc wrote: |
Looks good Mike, what tires did you go with? |
General grabber A/T 205 75 15 |
glifahrenheitcameron Samba Member
Joined: September 29, 2013 Posts: 54 Location: United States
Posted: Mon Nov 17, 2014 1:33 pm Post subject: |
Bought a narrowed/adjustable beam |
BlastMasterMannyFresh Samba Member
Joined: November 21, 2001 Posts: 6102 Location: #31peach
Posted: Mon Nov 17, 2014 1:56 pm Post subject: |
norcalmike wrote: |
BRAVO!! |
Posted: Mon Nov 17, 2014 6:41 pm Post subject: |
Thanks Manny! its no Coram Rug Works but it will do |
Posted: Mon Nov 17, 2014 10:36 pm Post subject: Westy trim |
Finally installed the westy door trim in OG L87 Pearl White. Used my hole locator to drill the holes in the wod panels.
Stocknazi Samba Member
Posted: Tue Nov 18, 2014 7:59 am Post subject: Re: Westy trim |
Daddybus wrote: |
Can you elaborate on the hole locator? How does it work? _________________ WANTED:
"Resistance to tyrants is obedience to God."
Thomas Jefferson |
Posted: Tue Nov 18, 2014 5:23 pm Post subject: Re: Westy trim |
StockNazi wrote: |
Daddybus wrote: |
Can you elaborate on the hole locator? How does it work? |
It is used in the aircraft industry to locate holes for patch panels in aircraft. It is like a set of flat tweezers. One side has a male tip that goes into the hole. That male tip has a female hole on the back. The other side of the tweezers had a hole for a drill bit. The two sides align, so you locate the tip into your pre-existing hole, the panel in sandwiched between it and then you drill through the locator's drill bit hole and the bit contacts the female notch on the back of the tip for a perfectly aligned hole.
Clear as mud I'm sure. |
thom Samba Member
Joined: October 12, 2000 Posts: 5943 Location: Sacramento
Posted: Wed Nov 19, 2014 10:07 am Post subject: |
Spent some time getting the corner and quarter panel sorted out with new AutoCraft panels. I had originally started trimming the corner for the KF replacement, which is why there's an extra cut. Long story, don't want to incite another KF debate.
_________________ -Thom
1956 Single Cab
1957 Porsche 356A Sunroof
1957 23-Window Deluxe
1963 Unimog 404
1965 E-Type |
dawerks Samba Member
Posted: Wed Nov 19, 2014 10:15 am Post subject: |
Nice job!
I tried to look up a bus on your Vintage Bus Registry but it gives a '500 Internal Server Error' when I hit submit. _________________ "There is only one sin; disconnection from self." |
thom Samba Member
Posted: Wed Nov 19, 2014 11:38 am Post subject: |
dawerks wrote: |
Nice job!
I tried to look up a bus on your Vintage Bus Registry but it gives a '500 Internal Server Error' when I hit submit. |
Looks like they've buggered up the server again.
bash: symbol lookup error: /XxJynx/jynx2.so: undefined symbol: DH_free _________________ -Thom
1956 Single Cab
1963 Unimog 404
1965 E-Type |
Who.Me? Samba Member
Joined: July 14, 2014 Posts: 2211 Location: UK (South)
Posted: Wed Nov 19, 2014 1:33 pm Post subject: Re: Westy trim |
Daddybus wrote: |
StockNazi wrote: |
Daddybus wrote: |
Nifty gadget. The description was fine, but Googling 'hole locator tool' brings up ebay links for the tool (which was a relief - that search could have gone very wrong).
Could come in very handy for locating cab trim panels too. |
crofty Judas of the North
Joined: August 09, 2000 Posts: 19672 Location: Land of Whine and Phonies
Posted: Wed Nov 19, 2014 1:36 pm Post subject: |
A little premature but I had the seats redone for my 62 and did a little mock up. _________________ Your Vanagon sucks, Stop waving at me.
HamburgerBrad wrote: |
I slept on crofty's tent once. I passed out drunk from two bottles of Everett's brother's wine. |
thom Samba Member
Posted: Fri Nov 21, 2014 6:47 am Post subject: |
Got the passenger-side corner and quarter tacked in last night
1956 Single Cab
1963 Unimog 404
1965 E-Type |
Posted: Fri Nov 21, 2014 8:04 am Post subject: |
Nice! _________________ Your Vanagon sucks, Stop waving at me.
