vwserphguy Samba Member
Joined: April 30, 2009 Posts: 175 Location: Vail Valley
Posted: Sun Mar 01, 2015 9:00 pm Post subject: |
Removed old paint from an original pressed bumper that I bought here on the samba a few years ago. I straightened it out as best i could awhile back. I think it should be pretty usable now.
Before:
During:
After:
_________________ "Relax and just enjoy the ride knowing everybody passing is wishing they had one." |
Ran When Parked Samba Member
Joined: September 26, 2013 Posts: 781 Location: Birmingham, AL
Posted: Sun Mar 01, 2015 9:45 pm Post subject: Sardines |
Stuco and I managed to fit three buses in a two car garage. Three buses and one roof clip.
I thought I was going to have to leave the normal stuff a guy has in his garage out in the elements. Then I remembered that I have a shed.
It is easy access due to the double doors.
Maybe we can fit one more.... |
curtis4085 Samba Member
Posted: Mon Mar 02, 2015 5:34 am Post subject: Re: Thermostat |
Hokie87 wrote: |
I decided to take Clara's (and other's) advice that engines should have thermostats and installed one. I got the flaps and mount from Awesome Powdercoat.
OG style spring clips
New tension spring
Where did you locate a new tensioning spring? _________________ Special Thanks to:
Headflow Masters - Vista, CA
www.headflowmasters.com |
Hokie87 Samba Member
Joined: May 27, 2010 Posts: 280 Location: Richmond, VA
Posted: Mon Mar 02, 2015 6:26 pm Post subject: |
It came with the flaps and thermostat from Awesome Powdercoat. He may sell just the spring. Can't hurt to ask.
http://www.awesomepowdercoat.com/ |
Tyler 5447 Samba Member
Posted: Mon Mar 02, 2015 9:09 pm Post subject: |
Thanks for posting that link, I have been hunting for some German tin and hopefully these guys can help me out. |
Posted: Sun Mar 08, 2015 8:57 pm Post subject: Removed Acorns and Insulation |
After the sun went down, I had two full hours for VW stuff. I removed the last two rolls of house insulation from the driver's side of the cargo area. Then did some sweeping and vacuuming around the two engines.
Check out the exhaust pipes on this pair. Must be former dune buggy engines.
'64cal lookdub 1200 Deluxe
Posted: Mon Mar 09, 2015 12:18 am Post subject: |
I'm replacing all my shift rod bushings before I install my trans. Typical PITA front shift rod coupler. After soaking, beating, heating, cussing, etc. I decided to cut it with my Dremel. I dug into the shift rods slightly in a few places but nothing to cause any harm. I'll be sure to lube the rod ends and new coupler up with anti-seize. Nothing new to the bus veterans but this is my first bus so I'm getting the initiation.
SkooobaSteve Samba Member
Joined: March 23, 2005 Posts: 3152 Location: Dothan Alabama
62DoKaGuy Samba Member
Joined: May 22, 2011 Posts: 1276 Location: Surprise, AZ
Posted: Wed Mar 11, 2015 9:57 am Post subject: |
Over the last week or so, I changed the oil and associated seal/gaskets/etc, replaced rubber fuel lines (almost had a fire hazard on my hands), and removed old pointed rear bumper and replaced with stripped/primered/painted correct slash rear on my '62 DC. She's coming around slowly but surely.
Cheers,
Brian _________________ ,,Wenige Menschen denken, und doch wollen alle entscheiden.'' -der Alte Fritz
EverettB wrote: |
...I went at it from both ends but going from the rear didn't seem to do anything, although I did spray some rust breaker in there... |
4/62 Double Cab
5/61 Panel (sold)
4/59 Single Cab (sold) |
Kiwinw Samba Member
Joined: March 28, 2014 Posts: 58 Location: Portland, Oregon
Posted: Sun Mar 15, 2015 9:16 am Post subject: |
Yesterday, I dropped my bus....
And then I spent a while picking it back up off the floor and getting it back on the jack stands
I thought about photos, but was too embarrassed. Best news, I wasn't under it, and other good news is it did little damage. _________________ I need a long camper side WINDOW for a 66 Riviera - please let me know if you have one!
1975 Westfalia
1967 Westfalia
1966 Riviera
1966 Deluxe |
Darth Wolfsburg Samba Member
Joined: August 14, 2012 Posts: 13 Location: Miami Florida
Posted: Wed Mar 18, 2015 8:30 pm Post subject: |
Kiwinw wrote: |
I thought about photos, but was too embarrassed. Best news, I wasn't under it, and other good news is it did little damage. |
Dang man... how'd it happen? |
Kiwinw Samba Member
Posted: Wed Mar 18, 2015 9:47 pm Post subject: |
Darth Wolfsburg wrote: |
Kiwinw wrote: |
Rooky mistake. Ive been trying to fix some things under the wheel well and theres not much room with a welding helmet, and keeping clear vision for a beginner welder. So, I decided to jack it a little higher from the rear. It was all looking great (going slow), then the front jack stands skidded forward and the jack followed. I had one front left wheel on, and the rear jack stands caught under some of the frame. So the entire bus actually stayed off the ground, just dented my frame a little (and my pride). Its not a show bus, just patching it back to a daily driver, so the new dents in the frame support did not worry me too much. There were already others under there. I wish I had some more height though to make this easier. _________________ I need a long camper side WINDOW for a 66 Riviera - please let me know if you have one!
1975 Westfalia
1967 Westfalia
1966 Riviera
1966 Deluxe |
Big Bill Samba Member
Joined: June 21, 2005 Posts: 1783 Location: Santa Rosa, Ca
Posted: Thu Mar 19, 2015 6:17 am Post subject: |
Installed one of WW slider window locks today. My OG lock was striped out when I removed it, this one is very nice, about the same weight and works great.
Posted: Sat Mar 21, 2015 5:35 pm Post subject: Learning Curve |
I started to put my engine on a standard engine stand to drain the oil and 'refurbish' it (spark plugs, wires, and stuff).
After looking at the stand and the engine and not wanting to break the studs or case, I decided to do some engine stand thread reading, Glenn's posts included.
Being hard headed, I ended up spending half the day trying and failing to get the engine on the stand.
I learned a lot, like buy the right part. This was after I cut the long pipes on two of the stand arms to be able to get nuts on the short studs. Next, I learned (first hand mind you) that the fly wheel was still in the way. I didn't quit, I swapped the bolts around so the short head was closer to the fly wheel and I moved the arms to the back of the plate.
LOL.
I have a shipment of metal coming from a Samba classified seller. I called and asked him to throw in a VW Engine Stand Yoke if possible. As luck would have it, he had a few and I will be receiving the right part for the job soon.
My 'wasted' half day is shown below. The circle shows the cut pipe and the arrow shows where I flipped the bolts and arms around.
The good news is that nothing VW was harmed while making this post.
BlastMasterMannyFresh Samba Member
Joined: November 21, 2001 Posts: 6102 Location: #31peach
Posted: Sat Mar 21, 2015 6:12 pm Post subject: |
took the front brakes apart Front Brakes.
Last year I redid the entire brake system on this bus and the front wheels cylinders were crap since day one.
Posted: Mon Mar 23, 2015 12:20 pm Post subject: welder |
I picked up a Lincoln Power Mig 180 Dual and a bottle of argon 75 cd 25 from Airgas. |
RHD Notch Samba Member
Joined: April 06, 2007 Posts: 1412 Location: Joshua Tree, CA
Posted: Wed Mar 25, 2015 6:08 pm Post subject: |
Just installed a new German stop light switch in my '60 panel...Let there be (brake) light! _________________
Lind wrote: |
I am at the point where I hardly want to own anything that isn't original paint. |
campingbox wrote: |
I have some other projects I'd like to finish first and I want to drive this bus while I'm working on those to help stay motivated. |
Clara Samba Member
Posted: Wed Mar 25, 2015 9:30 pm Post subject: |
'64cal lookdub wrote: |
great pics! _________________ The Obsolete Air-Cooled Documentation Project http://oacdp.org/ |
67X2 Samba Member
Joined: April 30, 2012 Posts: 17 Location: California
Posted: Thu Mar 26, 2015 8:53 am Post subject: |
Hey Y'all,
Possibly in the wrong place with this question but I thought I'd ask anyway...
(1967 Bus) I am changing my oil cooler to a late model oil cooler with the offset bracket, doghouse, etc. and the studs for the offset bracket won't fit into the case holes (x2) that hold the bracket (the stud coming up from the case is smaller too but a washer and nut can fix that "problem"). The studs are slightly too big. I can easily drill out the holes but thought I would ask first before I start drilling. Is this normal? Do I have the wrong bracket? Earlier cases have smaller holes? Friends haven't experienced this problem so I am out of peopple to ask.........until now.
Any help/advice would be greatly appreciated!
Cheers! |
ricekooker Samba Member
Joined: April 09, 2006 Posts: 1788 Location: Winter Park, FL
Posted: Thu Mar 26, 2015 9:14 am Post subject: |
I put some hubcap decals on my late commercial caps.
I forgot to take a before pic so here's a "just getting started" pic.
Here's the finished product with a light coat of wax.
