Dubskii Samba Member
Posted: Sun Aug 02, 2015 10:06 pm Post subject: |
Changed the brushes on my generator. Top was first and was pretty easy. Bottom was more of a pain but got through it. Took an hour or so. Need to pick me up some snub screwdrivers... _________________ 69 Sunroof Deluxe - Montana Red/Cloud White (Sold)
57 Kombi - Dove Blue http://www.thesamba.com/vw/forum/viewtopic.php?t=648240
WTB Early Dove Blue Bus Driver's Side Door
WTB Joe Heishman VW Arlington, VA License Plate Frame or Other Memorabilia |
srfndoc Samba Member
Posted: Mon Aug 03, 2015 8:02 am Post subject: |
Created a new reverse light harness as some PO thought it wasn't necessary. New OG housings (old ones were stripped) and reverse lights are now working great.
Also cleaned up a spare set of OG headlights with new seals/paint to replace my rusted buckets.
_________________ RPM=(MPH*336* (R&P*4th*1.26))/Tire Diameter in inches |
crofty Judas of the North
Joined: August 09, 2000 Posts: 19672 Location: Land of Whine and Phonies
Posted: Mon Aug 03, 2015 8:17 am Post subject: |
Installed the lower passenger side dogleg this past weekend.
_________________ Your Vanagon sucks, Stop waving at me.
HamburgerBrad wrote: |
I slept on crofty's tent once. I passed out drunk from two bottles of Everett's brother's wine. |
crukab Samba Chef
Joined: December 13, 2002 Posts: 6116 Location: Vermont
Posted: Mon Aug 03, 2015 12:00 pm Post subject: |
Oil Change, new Plugs & adjusted the throtle cable, then drove to the Maine Show & back, 260 mile round trip, the truck ran great !! _________________ Tom
My Pops:
In the yard right now:
'51 Dodge 5 window truck
'65 Bug
'66 Singlecab
'82 Rabbit Truck Diesel from CALI
'86 Doublecab W/T
'88 Dodge Ram pickup
'11 Jetta Wagon |
oakman Samba Member
Joined: February 05, 2014 Posts: 1715 Location: Edge of the Desert, Ca
Posted: Tue Aug 04, 2015 4:08 pm Post subject: |
Started the bus after a couple months of sitting due to my work schedule. Engine wouldn't idle so i pulled the carb off and cleaned the idle jet and all the other passages out. Re-installed, started up and all is back to normal (for now)! |
zozo Samba Member
Joined: October 15, 2005 Posts: 5217 Location: South of Ol' San Antonio
Posted: Wed Aug 05, 2015 5:33 am Post subject: |
After putting up with a very difficult to close passenger door, I finally used the 2x4 pry trick outlined in several other threads. MUCH improved. I can close it now without lifting and closing simultaneously. Still a little tight, likely because it's been hit on that front right corner eons ago, and never fixed. |
thom Samba Member
Joined: October 12, 2000 Posts: 5943 Location: Sacramento
Posted: Wed Aug 05, 2015 7:19 am Post subject: |
MOre media blasting on myu 1957 23-window
_________________ -Thom
1956 Single Cab
1957 Porsche 356A Sunroof
1957 23-Window Deluxe
1963 Unimog 404
1965 E-Type |
Posted: Wed Aug 05, 2015 7:37 am Post subject: |
^Nice! _________________ Your Vanagon sucks, Stop waving at me.
peecee69 Samba Member
Joined: January 27, 2005 Posts: 1572 Location: Annapolis, MD/Bloomfield Hills, MI
Posted: Wed Aug 05, 2015 7:51 am Post subject: |
Is that some sort of see-through screen in the left side of the picture? It looks like you're in a garage. |
Posted: Wed Aug 05, 2015 8:09 am Post subject: |
Looks like some kind of sunshade or landscaping material. Good to keep the dust down when blasting. _________________ Your Vanagon sucks, Stop waving at me.
thom Samba Member
Posted: Wed Aug 05, 2015 12:58 pm Post subject: |
peecee69 wrote: |
That's in my carport; I kicked a couple of cars out so I'd have enough elbow room for blasting. The front and back have shade cloth coverings. _________________ -Thom
1956 Single Cab
1963 Unimog 404
1965 E-Type |
Clara Samba Member
Posted: Fri Aug 07, 2015 9:33 pm Post subject: |
The other day Greg replaced the bad generator in the kombi. The red light had been intermittently saying hi for a bit, then as of early July just stayed on. But honestly, it is summer and is fully light at 5am, and didn't get dark till 10:30. You can push start the bus if needed. On the trip round the Olympic Peninsula we did have to swap batteries with Matt's bus after a few days, though.
So I did the diagnostic and yes it was the generator. Greg found we had a brand new Bosch generator in the box. He started to try to replace it with motor in the bus, but decided it was too much of a PITA, and just pulled the motor to swap it out.
The hub was kinda stuck on the fan, and you could just see a crack starting. It was not as bad as Richies:
but the center bit popped off when the hub was removed.
All together with a good fan and new generator, and now the light stays off. _________________ The Obsolete Air-Cooled Documentation Project http://oacdp.org/ |
Posted: Sat Aug 08, 2015 10:20 pm Post subject: |
Installed some new WW front seat belts, ivory wiper and headlight knobs, painted the shifter plate, greased my shifter and covered it with a new boot. Added a new ivory shifter knob. Heat shrank some sleeves over some questionable wiring. Swapped two pop out spoons so they were even on each side and installed a new cleat and strap. Then I drove her on her maiden voyage with me!
Oh, and left a few things soaked in PB! _________________ 69 Sunroof Deluxe - Montana Red/Cloud White (Sold)
joe cool Samba Member
Joined: August 20, 2006 Posts: 1259 Location: Yolo County CA
Posted: Sat Aug 08, 2015 10:43 pm Post subject: |
make it work!
It is crankster but it does work. Later shifter in earlier bus |
brettsvw Samba Member
Joined: November 22, 2007 Posts: 2145 Location: Florida
64 ragtop volks Samba Member
Posted: Sun Aug 09, 2015 6:28 pm Post subject: |
got a little more paint stripped of the farm truck. |
thom Samba Member
Posted: Fri Aug 14, 2015 6:36 pm Post subject: |
I've been slowly media-blasting the entire bus
1956 Single Cab
1963 Unimog 404
1965 E-Type |
crukab Samba Chef
Posted: Sat Aug 15, 2015 8:51 am Post subject: |
Rotated the tires & adjusted the Brakes on the '66, then it was yard work time, Singlecab style....
I'll be doing a Bon Fire w/all that the next time it Rains... _________________ Tom
My Pops:
'65 Bug
'66 Singlecab
'86 Doublecab W/T
'11 Jetta Wagon |
orangebug60guy Twin #1
Joined: June 28, 2003 Posts: 1516 Location: South Hadley Mass
Posted: Wed Aug 19, 2015 6:27 pm Post subject: |
put the beam I have been rebuilding back in the bus!
_________________ Arachibutyrophobia- Fear of peanut butter sticking to the roof of the mouth.
Coprastasophobia- Fear of constipation. |
PapaG1954 Samba Member
Joined: October 06, 2007 Posts: 73 Location: Fort Lauderdale,Fl.
Posted: Thu Aug 20, 2015 8:24 am Post subject: '67 Bus Locking Rear Hatch and Locking Engine Lid latches |
I wanted to pass on some good info...
Just installed The Locking Rear hatch and Locking Engine Lid Latch on my '67 Bus. They were Original '67 parts and I ordered them from
Chadd Magee. [email protected]
They fit perfect the first time and it was a major relief after buying an aftermarket engine lid latch that didn't open after it was installed! Finally popped it open with a screwdriver...
This guy is my go to parts guy from now on. |
