Daddybus Samba Member
Posted: Sat Dec 03, 2016 7:53 pm Post subject: Re: What did you do for your Bus today? |
Welded the seams of the side plates. Tack welded the adjuster teeth into place.
brettsvw Samba Member
Joined: November 22, 2007 Posts: 2145 Location: Florida
crukab Samba Chef
Joined: December 13, 2002 Posts: 6116 Location: Vermont
Posted: Mon Dec 12, 2016 1:04 am Post subject: Re: What did you do for your Bus today? |
Finally got around to putting a Bay Tank in my Singlecab. _________________ Tom
My Pops:
In the yard right now:
'51 Dodge 5 window truck
'65 Bug
'66 Singlecab
'82 Rabbit Truck Diesel from CALI
'86 Doublecab W/T
'88 Dodge Ram pickup
'11 Jetta Wagon |
5657 Samba Member
Joined: April 11, 2010 Posts: 170 Location: North Okanagan, BC CANADA
Posted: Mon Dec 12, 2016 11:05 am Post subject: Re: What did you do for your Bus today? |
Installed the lights and emblem on the front of the 1956 Wolfsburg ambulance to check for fit.
BlastMasterMannyFresh Samba Member
Joined: November 21, 2001 Posts: 6102 Location: #31peach
Posted: Mon Dec 12, 2016 12:05 pm Post subject: Re: What did you do for your Bus today? |
crukab wrote: |
Finally got around to putting a Bay Tank in my Singlecab. |
how much gas does it hold now ? |
wcfvw69 Samba Purist
Posted: Mon Dec 12, 2016 1:16 pm Post subject: Re: What did you do for your Bus today? |
mannys66 wrote: |
crukab wrote: |
My 1970 bay gas tank holds 16 gallons. _________________ Contact me at [email protected]
The Samba member since 2004.
mandraks Samba Member
Joined: November 28, 2004 Posts: 7047 Location: Lawrenceville, Ga
Posted: Mon Dec 12, 2016 1:34 pm Post subject: Re: What did you do for your Bus today? |
crukab wrote: |
the perfect fix for a single or crewcab. virtually undetectable, and in an early one you don't even have to worry about a fuel gauge. _________________ regards
Uli
crukab Samba Chef
Posted: Tue Dec 13, 2016 3:28 am Post subject: Re: What did you do for your Bus today? |
mandraks wrote: |
crukab wrote: |
the perfect fix for a single or crewcab. virtually undetectable, and in an early one you don't even have to worry about a fuel gauge. |
It will be a "see what happens" situation w/ the stock sending unit, not sure how well it will match up w/ the '67 gage, but I usually use a note book to track miles & fill-ups.......
And yes, 16 Gallon tank, easy to put in a Truck. I've had the tank for a few years, got it cleaned & coated last year, finally get to use it. _________________ Tom
My Pops:
'65 Bug
'66 Singlecab
'86 Doublecab W/T
'11 Jetta Wagon |
62DoKaGuy Samba Member
Joined: May 22, 2011 Posts: 1276 Location: Surprise, AZ
Posted: Tue Dec 13, 2016 7:15 am Post subject: Re: What did you do for your Bus today? |
crukab wrote: |
mandraks wrote: |
crukab wrote: |
And yes, 16 Gallon tank, easy to put in a Truck. I've had the tank for a few years, got it cleaned & coated last year, finally get to use it. |
I've run a Bay tank for about 18 years in my '62 DC, having replaced it with a new one earlier this year. Greater fuel capacity, but I agree the mixture of a stock split sending unit, coupled with a 6v fuel gauge in a 12v system, concerns me every so often. Still, it is all together pretty spot on. _________________ ,,Wenige Menschen denken, und doch wollen alle entscheiden.'' -der Alte Fritz
EverettB wrote: |
...I went at it from both ends but going from the rear didn't seem to do anything, although I did spray some rust breaker in there... |
4/62 Double Cab
5/61 Panel (sold)
4/59 Single Cab (sold) |
Posted: Sat Dec 24, 2016 11:28 pm Post subject: Re: What did you do for your Bus today? |
Finished my 2" narrowed ball joint adjustable beam for the daddybus. I had misplaced one of the tow hooks that I welded to the lower tube. I knocked the center blocks loose, then cleaned up the welds and painted it.
Jacco Verveer Samba Member
Posted: Tue Dec 27, 2016 1:59 pm Post subject: Re: What did you do for your Bus today? |
got the last parts on
ready for next year i hope
Posted: Wed Dec 28, 2016 12:36 am Post subject: Re: What did you do for your Bus today? |
Removed the brake booster bracket (before paint) then installed NOS needle bearings and added some eye candy for the tow truck driver.
EeVeeWee Samba Member
Joined: April 02, 2015 Posts: 836 Location: Amersfoort, Netherlands
Posted: Thu Dec 29, 2016 2:53 pm Post subject: Re: What did you do for your Bus today? |
I put some pieces of roof at the place where the top vents were.
Who.Me? Samba Member
Joined: July 14, 2014 Posts: 2207 Location: UK (South)
Posted: Fri Dec 30, 2016 3:44 pm Post subject: Re: What did you do for your Bus today? |
Spent the last few mornings cleaning up the transmission cradle and torsion bar. Scraped off the result of six decades of oil leaks bound up with what looked like Gypsom.
It'll make working under there a lot more pleasant.
After...
Forgot to take decent pictures before, but this was what it looked like when I bought the truck. I'd not have guessed that the torsion tube or cradle were blue...
_________________ Andy
Looking for info on my truck's history. Are you from Campbell California or nearby. Do you recognise it? ... http://www.thesamba.com/vw/forum/viewtopic.php?t=636786 |
Posted: Sun Jan 01, 2017 2:12 pm Post subject: Re: What did you do for your Bus today? |
I didn't like the wrinkled look of my westy you spare tire cover and I was thinking about getting a hard plastic cover from a bay bus. A friend who does upholstery suggested that I make a hardboard insert. So I did.
From this...
To this...
Like night and day (had to say it) |
nlorntson Crazy VW Lady
Joined: March 13, 2004 Posts: 3783 Location: Twin Cities, MN
Posted: Mon Jan 02, 2017 9:45 pm Post subject: Re: What did you do for your Bus today? |
Got the new poptop canvas installed in the SO44 today. Still need to adjust the tension in the spring.
Old canvas
New canvas
Alan Brase Samba Member
Joined: March 28, 2004 Posts: 4532 Location: Cedar Falls, Iowa
Posted: Tue Jan 03, 2017 2:12 am Post subject: Re: What did you do for your Bus today? |
62DoKaGuy wrote: |
crukab wrote: |
mandraks wrote: |
crukab wrote: |
I've run a Bay tank for about 18 years in my '62 DC, having replaced it with a new one earlier this year. Greater fuel capacity, but I agree the mixture of a stock split sending unit, coupled with a 6v fuel gauge in a 12v system, concerns me every so often. Still, it is all together pretty spot on. |
I always figured 15.8 gallons, I drove a bay perhaps 350,000 miles.
I think the splittie sender is too short to give a full range of travel. Most all bay senders I've taken out were shot. I imagine one could restring the resistance wire. If you have the patience of Job. But there are a few people out there that know about this on the bay list. Bus Depot sells a VDO replacement that is totally different and adjustable. A lever type. That might be a good answer.
But REAL type 2's have reserve taps. Ones that can be rebuilt and new cable bought. Personally, I'd leave the in tank filter off and put a nice metal one just under the tank by the top. Not a fan of see thru plastic fuel filters.
Al _________________ Al Brase
Projects: 67 sunroof bug, 67 Porsche 912 Targa, 70 Westy
Dec 1955 Single Cab pickup WANT 15" BUS RIMS dated 8/55, thru 12/55
To New owners: 1969 doublecab, 1971 Dormobile
Vanagons:
80 P27 Westy JUL 1979, 3rd oldest known US
83 1.6TD Vanagon, 87 Wolfie Westy daily driver, swap meet home |
srfndoc Samba Member
Posted: Tue Jan 03, 2017 12:24 pm Post subject: Re: What did you do for your Bus today? |
nlorntson wrote: |
That looks great! I still haven't installed my canvas from Helmut but will one of these days. _________________ RPM=(MPH*336* (R&P*4th*1.26))/Tire Diameter in inches |
easy e Samba Member
Joined: May 28, 2008 Posts: 3931 Location: 1 hr north of Santa Barbara
Posted: Tue Jan 03, 2017 1:30 pm Post subject: Re: What did you do for your Bus today? |
srfndoc wrote: |
nlorntson wrote: |
That looks great! I still haven't installed my canvas from Helmut but will one of these days. |
X2... nice job!... I've been watching your patient effort progress to success! _________________ aka: Evan
Searchable, click-navigable 1958 Bus Parts List |
Posted: Tue Jan 03, 2017 1:45 pm Post subject: Re: What did you do for your Bus today? |
srfndoc wrote: |
nlorntson wrote: |
The piece Helmut makes is top notch quality.
Had I not had other things to get done, I think it would have taken around 5-6 hours start to finish.
I'm contemplating putting a write-up together. |
