KevinAlbrecht Samba Member
Joined: March 07, 2002 Posts: 970 Location: Ocean City > Boca > Pompano > Kirkland > Eugene
Posted: Wed May 30, 2007 11:27 am Post subject: Difference in Doglegs |
What years did Doglegs switch from Thinlip to Fatlip or vice versa? I have a '63 walkthrough panelvan, and need to find out which I have. - Thanks!
Kevin |
Anchovy Samba Member
Joined: August 05, 2000 Posts: 2922 Location: San Diego, CA
BUCIOBATISTI Samba Member
Joined: April 17, 2002 Posts: 6956 Location: San Diego, California, USA
Posted: Wed May 30, 2007 1:27 pm Post subject: Re: Difference in Doglegs |
KevinAlbrecht wrote: |
Kevin |
1962 was the last year for the thick doglegs. Thin doglegs started in 1963. _________________ Please check us out on Instagram at @holygrailgarage
That's the best place to see the latest things we are up to as well as catch an occasional sneak peek of our latest car and parts listings! |
splitpile Samba's Worst Speller
Joined: May 03, 2000 Posts: 5927 Location: back to living where hell meets the suface
Posted: Wed May 30, 2007 1:41 pm Post subject: Re: Difference in Doglegs |
BUCIOBATISTI wrote: |
Kevin |
1962 was the last year for the thick doglegs. Thin doglegs started in 1963. |
Did they start when the louvers went to innys from outtys, isn't that the same time they went from flat wheel wells to raised lip? and changed the doglegs at that time? My mind just doesn't remember these detailed year changes. _________________ Stocking distributor of "The Funky Green Panels"
"no more hacking my sig line" |
Posted: Wed May 30, 2007 2:30 pm Post subject: Re: Difference in Doglegs |
splitpile wrote: |
Kevin |
Did they start when the louvers went to innys from outtys, isn't that the same time they went from flat wheel wells to raised lip? and changed the doglegs at that time? My mind just doesn't remember these detailed year changes. |
Ronnie- I can't say anything for sure in regards to when exactly the change took place as I've seen some odd combinations from around that time. I know that the flat wheel/outward vent/thick dogleg combo was what came on 1962s but then in early 1963 you will see some lipped wheel well/outward vent/thin dogleg Buses and then they went to the later lipped wheel well/inward vent/thin dogleg Buses sometime during "1963" production. _________________ Please check us out on Instagram at @holygrailgarage
diy570 Samba Member
Joined: September 19, 2003 Posts: 1062 Location: Maggie Valley, NC
Posted: Wed May 30, 2007 3:00 pm Post subject: |
the ones on it in that picture are the thin/later style. |
Posted: Wed May 30, 2007 4:07 pm Post subject: |
Thin lipped, inny vents, lipped wheel well.
Got it Kevin. I have 1 set coming for you _________________ Stocking distributor of "The Funky Green Panels"
Posted: Wed May 30, 2007 4:10 pm Post subject: |
My wheel well have a lip(I think), but I have outie vents! |
mattoreg Samba Member
Posted: Wed May 30, 2007 4:54 pm Post subject: |
So the 4.8 cm thickness is 62 and earlier? and the 2.4cm thickness is ~63 and later? _________________ 62 Turkis DC |
Posted: Wed May 30, 2007 5:00 pm Post subject: |
mattoreg wrote: |
So the 4.8 cm thickness is 62 and earlier? and the 2.4cm thickness is ~63 and later? |
Yep. _________________ Please check us out on Instagram at @holygrailgarage
faster Samba Member
Posted: Wed May 30, 2007 5:03 pm Post subject: |
how many ft. are in a cm. ? |
_monkey_ Samba Monkey
Joined: April 11, 2005 Posts: 1584 Location: New England
Posted: Wed May 30, 2007 5:05 pm Post subject: |
faster wrote: |
There are approximately 30.5 cm per foot. Or roughly 2.54 cm per inch. |
faster Samba Member
Posted: Wed May 30, 2007 5:11 pm Post subject: |
monkey_69 wrote: |
faster wrote: |
Hell what was I thinking ? I should have know that. |
Kommercial Samba Moderator
Joined: December 28, 2000 Posts: 1154 Location: San Tan Valley, Arizona
Posted: Thu May 31, 2007 5:37 am Post subject: |
Rear wheel well lips were added at the same time that the doglegs were changed, according to VW on july of 62 at #971550. Like Buciobatisti stated, there was some strange things going on at that time. My early June 12th 62 #957602 og paint actually has the newer style skinny doglegs which hadn't even went into effect yet but still has the earlier style rear wheel wells as it should and outtie vents. Anyone else have a 62 earlier than that with skinny doglegs?
Metalwizard Samba Member
Joined: October 21, 2003 Posts: 696 Location: Archdale, NC
Posted: Thu May 31, 2007 2:16 pm Post subject: |
Mullens has a 15 window here, 06 11 2 . It has skinny doglegs, fat rear lips and outtie vents. Weird. Later _________________ http://s461.photobucket.com/albums/qq335/Metalwizard/
Kelly aka
"Bubble & Nut Buster for wannabe BadBoy's of Restoration"
"There is no cure for Stupid"
ITMC "Drill SGT" |
type241 Samba Member
Joined: June 02, 2006 Posts: 972 Location: MOSES LAKE, WA
Posted: Wed Jan 23, 2008 5:04 pm Post subject: |
Sorry to drag up old thread. I have a 62 23 vin 847xxx that has fat doglegs. I also have a 62 23 vin 955xxx with thin doglegs. Both of which have outie vents. If there was an actual transsition it is somewhere between these two busses of mine. I would surely like a definite answer.
Neither of my 62's have lip rear well. |
vwuguy Samba Member
Joined: November 01, 2005 Posts: 1053 Location: southwestern ontario, on and netherlands and bc
Posted: Fri Mar 05, 2010 9:28 pm Post subject: doglegs |
Do wolfsburg busses have different doglegs than the hanover busses 1956-63 _________________
Aaron Samba Luddite
Posted: Fri Mar 05, 2010 10:03 pm Post subject: |
Yes, they are known as "seamed" doglegs. A picture "Campingbox" posted.
joescoolcustoms Samba Member
Posted: Fri Mar 05, 2010 10:14 pm Post subject: |
My front dogs on my '59 are badly rusted. I am going to be running off road with larger tires and will have to cut the lips to clear.
Will thin lips fit and provide more clearance? I will have to cut the existing rusted ones for clearance and patch in metal and was thinking if the thins would provide better clearance, it would make a much better repair. _________________ Bad News Racing 2018 NORRA 1000 3rd in Class
