justice91423 Samba Member
Joined: December 04, 2006 Posts: 143 Location: los angeles
Posted: Wed May 30, 2007 2:19 pm Post subject: What is this thing under my dash? |
I haven't had my 74 Ghia for long. I noticed this thing under my dash. it has 2 wires going to it. What is it?
Gary  Person of Interest
Joined: November 01, 2002 Posts: 16962 Location: 'Murrica
Posted: Wed May 30, 2007 2:35 pm Post subject: |
Oh ok. Where can I buy a replacement?  |
dr. no Samba Member
Joined: August 06, 2004 Posts: 414 Location: Santa Fe
Posted: Wed May 30, 2007 3:51 pm Post subject: |
OEM, NOS, OG or aftermarket with a microprocessor? _________________ Scott
http://lungehphoto.com
'83.5 Westy s/p 1.6td and 4sp transplant--wonderful!
'86 Isuzu Trooper turboDiesel
'05 CRV Mommymobile
'12 Suzuki
PAST VWs:
'82 NA diesel Vanagon
'86 7-passenger Vanagon
'77 Bay
'71 Bay
'74 Things (2)
'69 Karmann Ghia (the only one I miss--in nice weather, anyway...) |
Ghiaddict Samba Member
Joined: November 20, 2002 Posts: 2657 Location: Now in Honea Path, SC
Posted: Wed May 30, 2007 4:23 pm Post subject: |
| Icy wrote: | | It's called, "something some previous owner installed that will most likely cause problems in the rat's nest of a wiring system behind the dash". |
Sorry, but that is a VW OEM part you have there for your
1974 Karmann Ghia. HTF and kind of rare, actually.
Here's one I posted in the Samba Gallery, some time ago:
Variously called a map light or a heater control illumination
light, it's original equipment for your '74 Ghia. Usually positioned
so the light aims at the center tunnel area. Found in some 1973
models, as well. _________________ ****************************
Karmann Ghia & Beetle parts available.
Convertible tops installed. |
Posted: Wed May 30, 2007 4:43 pm Post subject: |
| Wow, it doesn't look like a light. I'll have to take it off and take a closer look at it. Can you tell me if that is how it is supposed to be mounted? |
Posted: Wed May 30, 2007 4:51 pm Post subject: |
| justice91423 wrote: | | Wow, it doesn't look like a light. I'll have to take it off and take a closer look at it. Can you tell me if that is how it is supposed to be mounted? |
Your mounting bracket appears to be in the
original/correct position. But it needs to be turned so
the light shines toward the center tunnel.
When you get the chance to look at it closer,
you'll notice the light lens is mounted in the housing
so it can be swiveled or aimed like an eyeball.  _________________ ****************************
Posted: Wed May 30, 2007 4:53 pm Post subject: |
| Ghiaddict wrote: | | Icy wrote: | | It's called, "something some previous owner installed that will most likely cause problems in the rat's nest of a wiring system behind the dash". |
models, as well. |
Dayum I need to find a 74 to part out The 73 I have doesn't have that in it. Must be an end of model year item. _________________ -
Download this spreadsheet for NOS/OE parts inquiries--> http://vwjudsonregister.tripod.com/IMAGES/2013-parts-spreadshhet.xls |
| Thats pretty cool. thanks |
Plantman Samba Member
Joined: July 12, 2004 Posts: 664 Location: Brevard,NC
Posted: Wed May 30, 2007 7:05 pm Post subject: |
I have a couple of those in my parts boxes. How are they turned on? Or are they wired to the headlight circut?
David _________________ Every day may not be good, but there is something good in every day,
No matter where you go, there you are.
'69 bug & '71 Ghia |
waxhead Samba Member
Joined: January 19, 2004 Posts: 607 Location: Philly 'burbs
Posted: Wed May 30, 2007 7:21 pm Post subject: |
You guys are all wrong. It's actually a tiny camera - Big Brother keeping an eye on things back in the day...
 _________________ Mike B.
1976 Porsche 912E #1047
1976 Porsche 912E #1299
1974 Thing |
bugninva Samba Member
Joined: December 14, 2004 Posts: 8888 Location: sound it out.
Posted: Wed May 30, 2007 7:26 pm Post subject: |
my 73 (11/72) ghia has it.... as i understand it vw had to install them in US spec cars due to the US goverment requiring HVAC controls to be "lighted".... this was their solution...the light is very dim... _________________
| EverettB wrote: | | I prefer to refer to everyone as my "bitch". |
rumplestilskin Samba Member
Joined: January 13, 2007 Posts: 963 Location: los banos,CA
Posted: Wed May 30, 2007 10:01 pm Post subject: |
| yup required instrumentation thingy, i hate em |
///Mink Samba Member
Joined: May 03, 2000 Posts: 5029 Location: Fair Oaks, CA
Posted: Wed May 30, 2007 10:27 pm Post subject: |
I'll be damned....I never noticed that thing before. My '74 still has the bracket and grommet, but the light is missing.
Learn something new every day. |
Posted: Thu May 31, 2007 4:33 am Post subject: |
| Plantman wrote: | I have a couple of those in my parts boxes. How are they turned on? Or are they wired to the headlight circut?
David |
There is no dedicated switch for the light as it is
wired directly to the fuse panel, headlight circuit.
It's true, the light is very dim but it's a cool/unique item nonetheless.
Fatchicks rule!  _________________ ****************************
scooter8 Samba Member
Joined: October 27, 2005 Posts: 286 Location: Third stone from the sun (cos)
Posted: Thu May 31, 2007 1:14 pm Post subject: |
| Those are in the dash of early bugs too, shines down on the heater controls at night. |
Posted: Thu May 31, 2007 6:04 pm Post subject: |
Ghiaddict,Thanks for the info.
sslick Samba Member
Posted: Tue Mar 20, 2012 8:47 am Post subject: |
| Mine has a rubber bracket that houses the light....does anyone have one? |
mstencel Samba Member
Posted: Tue Mar 20, 2012 12:38 pm Post subject: |
My 73 has one as well. Works too. My car was built in May of 1973.
| Gary wrote: | | Ghiaddict wrote: | | Icy wrote: | | It's called, "something some previous owner installed that will most likely cause problems in the rat's nest of a wiring system behind the dash". |
models, as well. |
Dayum I need to find a 74 to part out The 73 I have doesn't have that in it. Must be an end of model year item. |
sslick Samba Member
Posted: Wed Mar 21, 2012 8:51 am Post subject: |
[quote="mstencel"]My 73 has one as well. Works too. My car was built in May of 1973.
Mine has a plastic housing where the one pictured looks like metal. It's broke into 3 pcs. I'm just gonna glue it back for now but if anyone has a plastic housing.....let me know. |
