It's_A_Girl_Thing Samba Member
Posted: Fri Jun 08, 2007 12:09 pm Post subject: What kinda Tires |
I'm looking for Tires for my thing, the size i need is 215 70 14.
I want something that i will be able to use on the beach sand as well as the road. Unpaved as well. Once again i like Safari's ride.
Can anyine help me out so i can get them ordered as soon as possible.
Jenn |
iltis74 Samba Member
Joined: November 20, 2003 Posts: 826 Location: Anchorage, AK
Posted: Fri Jun 08, 2007 5:14 pm Post subject: |
I don't know what's needed on the beach, but the BFG Radial Long Trail T/A, or maybe just the Radial T/A, may fit your needs. The AT doesn't seem to come in that size. |
Towel Rail Horizontally Opposed
Joined: April 15, 2005 Posts: 4622 Location: SE CR IA US NA PE
Posted: Fri Jun 08, 2007 7:32 pm Post subject: |
205/75R14s work well, too. No need to limit the search to just one size. My Thing is getting 7.0x15s next. _________________ 1974 Thing -- under the knife
1967 Beetle -- spring/summer/fall driver
1996 Subaru OBW (EJ22, 5-speed, AWD) -- winter car, 3-seasons "don't feel like biking today" car
049 > 070 > 053 > 009 |
kubelmann Samba Member
klokard Samba Member
Posted: Fri Jun 08, 2007 9:24 pm Post subject: I like these |
Check out these tires I have on my stock wheels.
Posted: Sat Jun 09, 2007 4:21 pm Post subject: Re: Here's the web site |
I have 14 rims on my thing which one of these would fit? |
Posted: Sat Jun 09, 2007 5:14 pm Post subject: |
225/70/14
What do these Numbers actually represent/stand for. my back tires are currently 215/75/R14 these are actual VW Rims. my front tires Are a newer rim and they are 185/70/R14
I like the yokohama tires you showed for the front but i need something good for sand for back tires.
Jenn |
Ferretkona Samba Member
Joined: December 03, 2005 Posts: 1306 Location: Columbia, CA
Posted: Sat Jun 09, 2007 7:28 pm Post subject: |
It's_A_Girl_Thing wrote: |
225/70/14
What do these Numbers actually represent/stand for. Jenn |
the 225 is the width in metric
the 70 is the height of the tire based on the percentage of the width - 70%
the 14 is your rim size. |
Posted: Sat Jun 09, 2007 9:15 pm Post subject: |
I'm looking for a tire that will alow me to drive in the sand. I just need a brand that is good. It will be for back tires only. this is just to get me by while my husband is out at sea. I don't want to look like a complete idiot if i get stuck out on the beach. I also cannot lift my thing at this time. so i need to stick with my 14 inch rims in the back.
Jenn |
Posted: Sat Jun 09, 2007 11:19 pm Post subject: Tire choice |
Jen,
If your hubby is out at sea due to deployment in the military, God Bless Him. If he's out at Sea because he got lost, I'll send you my cell number, we need to talk. Anyway, the tire I am showing is AWESOME for sand. It is a 78GX14 tire. That extrapulates to a 215X14 radial. Make no mistake, this is NOT a radial, it is a bias tire. It's awesome, plus it cost's half of the other tires. Any questions, gimme a shout. If hubby is still at sea, come by with a 1/5th of Pedron silver Tequila and we'll talk tires.
CW |
chefopie Samba Member
Joined: May 23, 2007 Posts: 9 Location: Columbia, South Carolina
Posted: Tue Jun 12, 2007 5:27 am Post subject: |
I just purchase a set of four Uniroyal Tiger Paw GTS tires (215/70R14). They seem to run fine. White raised lettering helps them stand out a little more. However keep your spare the orginal size so it will fit in the trunk. Opie |
mattt Samba Member
Posted: Tue Jun 12, 2007 9:05 pm Post subject: |
I'd say your best bet for a 14" tire that will help with traction in sand is the BFG All Terrain, size 27 X 8.5-14. They fit stock wheels on an unlifted Thing. You may still get stuck with that size tire, but if you air them down when running in the sand you will have much better luck. You should be able to air them down to 10PSI or less in the sand. Don't drive on the hwy. at that pressure though. So, make sure to bring a compressor with you to air back up if necessary. |
Rev. Scott Samba Member
Joined: June 04, 2006 Posts: 770 Location: Philo, Ca.
Posted: Wed Jun 13, 2007 8:40 pm Post subject: |
damn! you beat me to that reply. i used to run my stock '78 honda civic on the dunes in pismo...not competitively but we had some fun. buy yourself a 12v compressor to air them back up when your done with the fun, and simply let some air out of your street tires, yes 8-10 psi is good. i rolled my civic on the dunes a few times but it was light and easy to upright and i NEVER got stuck. always carried a few two by four lengths in the trunk just in case though. for my nor cal expeditions however, im liking those bias ply's... |
Captain Spalding Samba Member
Joined: February 19, 2005 Posts: 2519 Location: . . . in denial.
Posted: Wed Jun 13, 2007 10:58 pm Post subject: |
A good trick for getting out of sand is to carry a few strips of old carpet and a spade. When the wheels dig in, you use the spade to cut ramps in front of the wheels, and then lay in the strips of carpet on the ramps. Easy to climb right out on the carpet. The whole shebang is very easy to stow in a small duffel. |
