XcrackassX Samba Member
Posted: Wed Jun 13, 2007 6:02 pm Post subject: center caps for the front??? |
you can kind of see from this pic. I cant get center caps to fit because the hub sticks out to far. spacers wont work since my tires rub enough as it is any ideas for fitting? can i grind down the hubs? its only needed on the front the back has plenty of space. I have 3 prong spinner caps but they dont fit because the screws to tighten them in hit the hub. I would love to use porsche caps but i think i would really have to grind down the hubs. Any help would be appreciated. thanks
Soul Samba Member
Posted: Thu Jun 14, 2007 8:12 am Post subject: |
Install a chrome bearing cover. |
Hotrodvw Samba Member
Posted: Tue Jun 19, 2007 10:30 pm Post subject: |
Wolfsburg caps will fit no problem. I ran that same set up yrs. ago. If you ever want to get a set of polished 5 spokes, PM me......I'll trade ya. _________________ '67 Sunroof
Eric
78x94 with IDA's....oober fun
Horsepower is an addiction........Addictions cost
lots of money!
Hose & Fittings
Posted: Thu Jun 21, 2007 7:38 pm Post subject: |
i also have a set of polished empis i just took them off. I have the 3 spoke "spinner style" caps that came with them but the hex bolts hit the hub and wont let it fit on. i am thinking about hamering them down so i can fit something. the back has plenty of space but the front it looks like the only way may be to bang them in. any sugestions? |
Posted: Thu Jun 21, 2007 9:55 pm Post subject: |
My 'cone' style caps are 2-1/2". I believe they will fit just fine. _________________ '67 Sunroof
Eric
lots of money!
Hose & Fittings |
Posted: Fri Jun 22, 2007 6:48 am Post subject: |
i have cone caps for my empis, 2 are on tires at home and 2 are at work in a box on top of the unused desk next to me |
Posted: Fri Jun 22, 2007 6:50 am Post subject: |
That accomplishes nothing. _________________ '67 Sunroof
Eric
lots of money!
Hose & Fittings |
GhiaCouple007 Samba Member
Joined: February 02, 2006 Posts: 10 Location: Rock Falls IL
Posted: Wed Jul 04, 2007 4:02 pm Post subject: 3 spoke knock-offs with 8 spoke wheel on ghia |
I own a red 1974 Ghia coupe. I bought 8 spoke Empi's, painted them white & also bought 3 spoke knock-off caps to put on them. The back caps will fit ok but the front won't fit past the bearing caps ! Someone suggested chrome bearing caps. Will this solve the problem? Where can I get them?
Thanks |
Posted: Wed Jul 04, 2007 4:05 pm Post subject: |
You'll either have to modify your bearing caps, or get new center caps. Use some clay under the bearing cap, and see how much clearance there is. Once you determine that, you may be able to tap the caps with a hammer and dent them in, so the center caps fit. It's just a thought. _________________ '67 Sunroof
Eric
lots of money!
Hose & Fittings |
Posted: Thu Jul 05, 2007 4:53 pm Post subject: center caps |
thanks I will check that out. I really hope I can use the 3 spoke knock-offs , I think they have a unique look. |
Soul Samba Member
Posted: Tue Jul 10, 2007 1:12 pm Post subject: Re: 3 spoke knock-offs with 8 spoke wheel on ghia |
GhiaCouple007 wrote: |
Thanks |
Bearing caps are often refered to as grease caps. While it won't exactly solve the problem it can make your wheels look a bit better. They can be found at most VW parts suppliers. I think Larry's Offroad has them in stock.
Look at the pic below, the owner used chrome grease caps, and axle nuts to solve the problem.
One of my favorite cars BTW |
mr. warehouse Samba Member
Joined: February 27, 2001 Posts: 5001 Location: Nor Cal 707
Posted: Tue Jul 10, 2007 2:09 pm Post subject: |
Beat the $2 grease cap down with a mallet and you'll be fine. |
RobzKombi Samba Member
Posted: Tue Jul 17, 2007 2:29 pm Post subject: |
mr. warehouse wrote: |
Does this method apply to a 1963 grease cap on a bus?
I'm trying to install the center cap of my Empi(repros) five spokes but being that the grease cap is so wide, the center cap won't snap on. Any ideas? |
Posted: Tue Jul 17, 2007 10:14 pm Post subject: |
Put the cap on the wheel first, then put the wheel on the drum. |
Posted: Tue Jul 17, 2007 11:58 pm Post subject: |
Thanks, I'll give it a try. |
GMendoza Samba Member
Joined: November 15, 2007 Posts: 341 Location: Alta Loma, CA
Posted: Mon Jun 08, 2015 7:18 pm Post subject: |
To bring this back from the dead, I'm having the same issue. My dust caps wont clear my wheel center caps. I tried hammering them in some more but thats as far as they go.
Has anyone found a solution?
Thanks
_________________ '54 Bug, '59 Speedster replica, '65 Ghia (in pieces), '66 Notch, '80 930, '85 C10, '89 928, '96 LT4 'Vette, '03.5 Esprit, '05 Elise, '06 Murcielago |
Posted: Sat Jun 13, 2015 9:11 am Post subject: |
GMendoza wrote: |
Thanks
I found a fix. Stretch, cut and weld to make new dust caps with more of a cone shape that clear the wheel's center cap. _________________ '54 Bug, '59 Speedster replica, '65 Ghia (in pieces), '66 Notch, '80 930, '85 C10, '89 928, '96 LT4 'Vette, '03.5 Esprit, '05 Elise, '06 Murcielago |
