casey79westfalia Samba Member
![](/vw/forum/images/avatars/66013494147210521b9557.gif)
Posted: Fri Jun 22, 2007 8:59 am Post subject: Trailer Wiring Help! |
I am finishing up my westy trailer and need some help with wiring. My trailer uses bus tailights so I essentially would like to tap off my bus lights and wire them back to my trailer lights. I can use brass 1 male 2 female to jump the bus and trailer lights together. The problem I am realizing is that the trailer plug I have has 4 wires. 1 for ground, 1 for turning and 1 for brakes.
If I am correct I can jump the brake light wire off of one of the bus tailights and supply the two trailer brake lights. I can also do jump one of the bus running lights and supply my trailer running lights. I now will have two wires left 1 which will have to be my ground and the other for my turn signals. The problem I have is I will need two seperate wires for the turn signals as if I supply both trailer lights with one turn signal connection from the bus my blinkers will both blink when I hit left or right!
I know getting confusing.
Correct me if I am wrong but I could jump all the connections from one bus tailight(running,turn,brake) and supply both left and right trailer tailights with the same lights except for one trailer tailight which will get its own dedicated turn signal which I could jump just the turn signal from the other bus tailight so that I get that turn signal only on the other side of the trailer! Should I just buy a plug and make this happen or is there a more professional way!
I usually can figure these things out but, I am having trouble laying it out!!
Pics of setup!
[img]
_________________ 66 Westfalia
87 Westfalia Syncro "Phoenix"
88 Double Cab
76 Porsche 914
2014 Audi Q7
2010 Tdi Sportwagen
Currently looking for 62 Double Cab, 66 Westfalia Parts!
(Rear seat and pedestal, bumpers, mirrors)
http://www.baycountrymotors.com
My 87 Syncro Westfalia 1.8t Restoration
http://www.thesamba.com/vw/forum/viewtopic.php?t=418933
"Do it the right way, or you'll pay for it" |
![](/vw/forum/templates/subSilver/images/spacer.gif) |
MedicTed Samba Member
![](/vw/forum/images/avatars/945747143489b63fd3c0c4.gif)
Joined: August 12, 2005 Posts: 2110 Location: King of Prussia, PA
busdaddy Samba Member
![](/vw/forum/images/avatars/12378363254b954827328c6.jpg)
Joined: February 12, 2004 Posts: 51057 Location: Surrey B.C. Canada, but thinking of Ukraine
Posted: Fri Jun 22, 2007 9:19 am Post subject: |
Either what Ted said or add a single wire for the ground and use the plug for stop,running,left,right. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
Posted: Fri Jun 22, 2007 10:43 am Post subject: |
Thanks Guys! Just want to make sure I have a clear idea on how I am going to accomplish this. If I was to add a ground wire how would I do that! It is the plug itself that I am trying to ground correct? _________________ 66 Westfalia
88 Double Cab
76 Porsche 914
2014 Audi Q7
2010 Tdi Sportwagen
Posted: Fri Jun 22, 2007 11:19 am Post subject: |
Don't have to ground the plug, just need an extra wire (with a disconnect) from the bus body to the tailight grounds. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
Posted: Fri Jun 22, 2007 11:26 am Post subject: |
Where are the tailight grounds? Are you saying I could essentialy use my existing 4 wire harness for all the lights and make a seperate wire with a disconnect for the ground. I am still unclear where to put the ground wire?
I could attach it to a good metal ground on the bus and the other end I could attach to the tailight grounds wherever they are! _________________ 66 Westfalia
88 Double Cab
76 Porsche 914
2014 Audi Q7
2010 Tdi Sportwagen
old DKP driver Samba Member
Joined: March 30, 2005 Posts: 4145 Location: Los Gatos,Ca.
Posted: Fri Jun 22, 2007 11:51 am Post subject: ground terminal |
Charles, reach inside the engine compartment passenger side. about 3 inches from the tail light holder there is a double male connector welded to the body. thats the ground. I also use that for my trailer 4 prong plug. _________________ V.W.owner since 1967 |
Posted: Fri Jun 22, 2007 12:08 pm Post subject: |
Thanks olddkp!! _________________ 66 Westfalia
88 Double Cab
76 Porsche 914
2014 Audi Q7
2010 Tdi Sportwagen
redbus Steve Samba Member
![](/vw/forum/images/avatars/174286417346075d6e81664.jpg)
Joined: February 09, 2004 Posts: 133 Location: Southern California
Posted: Fri Jun 22, 2007 12:32 pm Post subject: |
I also pull a Harbor Freight Trailer with my bus. When I wired the lights, I also wanted to use backup lights on the trailer. I cut the four pin connector off of the HF wiring and added 2 more wires -- a ground and a backup + lead. I used a standard 6 pin connector to wire it all together. An advantage of this is when I pull my friends motorcycle trailer or loan my trailer to someone else, the wiring is all standard.
You can find these plugs and the "pigtail" for the trailer end at most FLAPS or RV stores. I think Walmart may also have them.
Steve _________________ Steve
1970 Westy with a Riviera Top
1969 Beetle
"Her shaft is bent and the rear end leaks, you can fix her quick with an oily rag, use a nail to start her I lost the key. Don't pay any mind to that whirring sound. She uses a little oil but outside of that she's cherry." -- C.W. McCall |
Posted: Fri Jun 22, 2007 1:08 pm Post subject: |
I guess my question was where are the grounds on my tailights. I now know where to ground the wire on the bus but where on the trailer tailight! _________________ 66 Westfalia
88 Double Cab
76 Porsche 914
2014 Audi Q7
2010 Tdi Sportwagen
kkirwin Samba Member
![](/vw/forum/images/avatars/4499496324474ff0f8d9ca.jpg)
Joined: September 05, 2005 Posts: 562 Location: Billings, MT
Posted: Fri Jun 22, 2007 1:10 pm Post subject: |
How did you run the wires out of the engine compartment? I have wanted to do it like you have it but can't find a way to keep the wires from getting scorched buy the exhaust. _________________ 1978 Riviera FI Auto Trans
1973 Super Beetle
2003 Dodge Ram 1500 4X4 5.7 HEMI
2012 Suzuki VStrom DL1000
2006 Yamaha WR450 |
Posted: Fri Jun 22, 2007 1:25 pm Post subject: |
The tailight ground terminals are inside the tailights, under the grey covers. Or if you still have wires hanging out it's the solid brown ones. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
Posted: Fri Jun 22, 2007 1:30 pm Post subject: |
Yeah under the grey covers I have the bulb connections not sure which one is the ground? _________________ 66 Westfalia
88 Double Cab
76 Porsche 914
2014 Audi Q7
2010 Tdi Sportwagen
Posted: Fri Jun 22, 2007 2:05 pm Post subject: |
You can ground all the lights to the frame and just have one + lead to run to each bulb. Then connect a ground wire to the tongue near the coupler and run that to the bus.
1969 Beetle
Posted: Fri Jun 22, 2007 2:08 pm Post subject: |
If I misunderstood the question and you need to know which terminal on the bulb is ground, just compare to the lights in your bus. On my '70, all the ground connections are daisy chained with one black wire. It's pretty easy to figure out.
1969 Beetle
Posted: Fri Jun 22, 2007 4:15 pm Post subject: |
Steve's right, find the terminal that connects to all the bulbs. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
Posted: Fri Jun 22, 2007 5:09 pm Post subject: trailer lights |
here is how i have mine hooked up.[img] the pic's are in my gallery _________________ V.W.owner since 1967 |
NASkeet Samba Member
Joined: April 29, 2006 Posts: 2947 Location: South Benfleet, Essex, UK
Posted: Sun Jun 24, 2007 5:35 am Post subject: Trailer wiring |
redbus Steve wrote: |
Steve |
For a really comprehensive electrical towing socket & plug system, you could do no better than those used in Great Britain & Europe, as follows:
British & European, 12N standard 7-pole, electrical towing socket & plug, which traditionally serve all the road-vehicle lighting requirements (including reversing light and rear fog lamp), for a towed trailer, for which the following link shows the wiring circuit:
http://www.rydertowing.co.uk/trailer_towbar_wiring/12N_trailer_towbar_wiring.htm
The following link, shows the wiring circuit, for the similar looking, British & European, 12S supplementary 7-pole, electrical towing socket & plug, which serves other electrical requirements of a towed trailer or caravan, such as battery charging, interior lighting, refrigerator, etc:
http://www.rydertowing.co.uk/trailer_towbar_wiring/12S_trailer_towbar_wiring.htm
In Great Britain & European, the two pairs of matching 7-pin, 12N & 12S towing sockets & plugs, are being superceded by a single pair of matching, ISO 11446, 13-pin socket & plug, so both systems are still currently in use.
http://www.western-towing.co.uk/acatalog/Towbar_electrical_parts.html
http://www.rightconnections.co.uk/13pin-uk.htm
The following link shows the wiring circuit:
http://www.rydertowing.co.uk/trailer_towbar_wiring/13_Pin_trailer_towbar_wiring.htm
Regards.
Nigel A. Skeet |
busfreak_71 Flat 4 Junkie
![](/vw/forum/images/avatars/1627657924530b981f31c4c.jpg)
Joined: April 29, 2007 Posts: 1191 Location: Sherwood Park, Alberta
Posted: Sun Jun 24, 2007 1:32 pm Post subject: |
Ground is through the hitch, all the lights are grounded to the steel frame of the trailer. Since the battery is grounded to the body and frame of the bus, the trailer can be grounded to the frame through the hitch assembly. I hope that made sence... ![Confused](images/smiles/icon_confused.gif) _________________ '71 Tin Top Westfalia
'99.5 Bora TDI
'85 Jetta Coupe
'85 Mercedes 300SD
Resident Off-Grid hippie and diesel advocate. |
DougB Samba Member
![](/vw/forum/images/avatars/126153490351e45d46383c7.jpg)
Joined: January 09, 2007 Posts: 1076 Location: Falls Church, Virginia, USA
Posted: Mon Sep 29, 2014 8:53 am Post subject: |
Sorry to resurrect an old thread, but I'm in the process of wiring up a Hella 7-pin trailer wiring sock and have the same question as the gentleman below:
kkirwin wrote: |
How did you run the wires out of the engine compartment? I have wanted to do it like you have it but can't find a way to keep the wires from getting scorched buy the exhaust. |
I just don't see any great way to get the wires from the engine compartment to a socket I'd like to mount under my bumper without getting close to the exhaust. I've seen some pics that show a trailer plug hear the left taillight, which could be an option but I might then have to extend my trailer's plug cable to reach the longer distance.
Interested in any advice and/or photos you may have of your socket cable routing.
Thanks in advance!
- Doug ![Smile](images/smiles/icon_smile.gif) _________________ '75 Campmobile (tin-top to SpaceRoof)
'73 Fastback
'52 BMW R67/2
'41 Zundapp KS600
'55 Puch SGS250
A very, very understanding wife |
