YellowSquare Samba Member
Joined: March 29, 2013 Posts: 84 Location: Fremont, CA
Posted: Wed Apr 03, 2013 11:53 pm Post subject: |
Not a real big contribution, but I like my compufire, Ive only had it about a week. But my car started on the second crank after sitting for two years. plus it looks pretty cool
slalombuggy Samba Member
Posted: Thu Apr 04, 2013 7:31 am Post subject: |
I have the same system on my buggy, love it. Been using it for 4 years now.
brad |
808OvalGreasemonkey Samba Member
Posted: Fri Apr 05, 2013 12:13 pm Post subject: |
I used to think Pertronix sucked after it crapped out and went Compufire,then my Compufire crapped out after 16K miles and all the shop had was Pertronix,and now the pertronix is working just fine.
I did order a couple Compufires and now they are onboard as spares in both of my aircooleds. However I now realise that they are pretty much the same.
I think they are equal...................in the randomness of failure! |
modok Samba Member
Posted: Fri Apr 05, 2013 5:22 pm Post subject: |
That's a fact! some last 10 years and others 10 days, never can tell when the magic smoke is gonna leak out of an ignition module. Compufire has less scatter than petronix, the bigger magnet wheel seems to be more accurate, unless they made it wrong. Always check timing on all cylinders with these things! |
Geothon Samba Member
Joined: May 16, 2008 Posts: 153 Location: Ventura, CA
Posted: Wed Apr 10, 2013 10:44 am Post subject: |
I used Compufire to run the Volvo B21 motor for more than 100K miles with no problems. (It uses Bosch distributor so it was as easy to convert as on VW) |
FreeBug Samba Member
Joined: March 12, 2012 Posts: 4278 Location: deepest, darkest Switzerland
Posted: Wed Jul 08, 2015 12:38 pm Post subject: |
Ok, the general rule works out thusly:
-run points with a spare condenser: nothing can happen that you can't sort out with a screwdriver.
-run points conversion: you could break down anywhere.
-run points conversion with a spare module: pretty safe, but still something could blow.
-run points conversion with a spare module in the glovebox and a spare distributor, already indexed with the clamp, all set to go, in the trunk: it's guaranteed your points conversion will never burn out or fail, making you feel stupid for lugging around a spare dizzy everywhere you go...
Best I've had was a Bosch Hall effect module I found i a Volvo 245. It acted as a points conversion, really clean, precise spark from the slotted hall wheel mounted on the rotor, Bosch red coil, and the type of heat sink and controller you find in 80's golfs, vanagons, etc. Kept a spare one of those, never needed it. Asked at Bosch, but they haven't made it in 20yrs. Bummer.
Next engine, I'm hoping to use a Black Box, so can use a locked-out vanagon distributor with the nice Hall effect stuf. As clean as I'm going to get without going to crank ignition. |
Zack1978 Samba Member
Posted: Wed Aug 26, 2015 5:08 pm Post subject: |
Based on a google search, Compufire and Pertronix are the same company, right? _________________ 1972 Coupe |
Dale M. Samba Member
Posted: Wed Aug 26, 2015 7:11 pm Post subject: |
Zack1978 wrote: |
Based on a google search, Compufire and Pertronix are the same company, right? |
Would appear so....
http://www.pertronix.com
Joined: August 15, 2002 Posts: 4394 Location: Brew City
Howard 111 Samba Member
Posted: Fri Aug 28, 2015 8:25 am Post subject: |
I ran the Pertronix for years, never a problem.
I have a Compufire in an 050, never been run. I got it to upgrade an 050 I used in a drag only Ghia, from points. _________________ 1973 Karmann Ghia
Turbocharged, Fuel Injected
http://www.thesamba.com/vw/forum/viewtopic.php?t=531270 |
jjf2468 Samba Member
Joined: August 30, 2010 Posts: 10 Location: Mountlake Terrace, WA
Posted: Sat Jan 28, 2017 3:49 pm Post subject: Re: Pertronix vs. Compufire...? |
Old post, but install says avoid horizontal mounting due to overheating coil fyi :~) |
