Ian Epperson Samba Member
Joined: January 12, 2005 Posts: 2262 Location: Alameda, CA
Posted: Thu Jun 28, 2007 11:45 pm Post subject: Gettin close! |
Today, I got the intermediary bar modified to fit and bolted in place (feh, the number of "bolt on" parts that aren't...), fuel system parts machined, engine bolted in today (Thanks Solomon Grundy!!) and even bolted up the bumper and muffler for a test fit:
Hopefully, I'll be driving it before the weekend is out.
Note the modified catch for the deck lid. Cut off the old one, bought a good bracket from a surplus store, tapped a couple of holes in the rear, and now the latch can be removed to make it easier to pull or install the engine. Much nicer looking too.
PS. Yes, I know my tail lights are backwards. I'll fix them tonight or tomorrow.
Last edited by Ian Epperson on Thu Jun 28, 2007 11:52 pm; edited 1 time in total |
Posted: Thu Jun 28, 2007 11:50 pm Post subject: |
Here's a shot from this morning. Had to chop some metal off the right side of that intermediary mount and had to shave down the red urethane to get it to fit.
Welded the seams of the frame horns, modified Bugpack truss bar, modified Aircooled.net intermediary tranny mount, Rhino tranny mounts. That should hold everything still. |
bmwloco Samba Member
Joined: March 19, 2006 Posts: 1093 Location: Asheville NC
Posted: Fri Jun 29, 2007 8:15 am Post subject: |
One word: Beautiful. |
Solomon Grundy Samba Member
Joined: December 26, 2004 Posts: 747 Location: Silicon Valley
Posted: Fri Jun 29, 2007 5:40 pm Post subject: |
You should see it in person. |
GPthing Samba Member
Joined: January 10, 2007 Posts: 54 Location: Pasadena, CA
Posted: Fri Jun 29, 2007 9:34 pm Post subject: |
Alot nice stuff in the trunk
brian w |
Pinky Samba Ass Bandit
Posted: Fri Jun 29, 2007 11:22 pm Post subject: |
What kind of tranny are you running in front of that big 'ol Raby engine?
(Sorry- I haven't been following the forum the past 6-odd months) |
Kherome Samba Member
Posted: Sun Jul 01, 2007 1:47 pm Post subject: hi |
Wow what is up with that engine?? |
Posted: Sun Jul 01, 2007 3:34 pm Post subject: |
Whew! Mounting the oil cooler SUCKED! I finally got it in place:
The oil filter was also challenging, but I really like where it's located:
You can also see my new coil there next to it.
Also, got the gauges mounted Friday night (but not wired up yet):
Not far enough ahead to drive it by tomorrow (ah well) but I may be able to fire up the engine tonight! |
Posted: Sun Jul 01, 2007 3:47 pm Post subject: |
That is a really cool and accessable oil filter location, but aren't you going to spill oil all over your engine compartment every time you change it? |
Posted: Sun Jul 01, 2007 5:44 pm Post subject: |
Here's the theory: when changing the filter, crack it open a bit and let the oil drain back into the case. Note that it's up higher than anything else - even the cooler - so it should work ok. The outer portion of all filters is supposed to have a check valve preventing most of the oil from leaving the filter anywhere but the center.
We'll see how well that actually works. Changing it might just be a messy job - but also note that I've left room around it for catch rags and mess cleanup. Also, I didn't get anal about getting it level, so excess oil will roll off a known side.
Pre-oiling the filter may be right out. I'll probably just crack open the return line and crank the engine a bit after a change. |
kuebelwagen84 Samba Member
Joined: March 15, 2007 Posts: 144 Location: Edison, NJ
Posted: Sun Jul 01, 2007 7:12 pm Post subject: |
Ian Epperson wrote: |
Here's the theory: when changing the filter, crack it open a bit and let the oil drain back into the case. Note that it's up higher than anything else - even the cooler - so it should work ok. |
I work on a petroleum pipeline and we have huge engines/pumps and the works... attached to each pumping unit are softball size, lightbulb shaped (with the ball on top and the thin part facing downward, i.e letting the oil drop by gravity into the pump) oil containers which put oil directly into the bearings/pumps...
we have to change these out/refill them everynow and then and that's exactly how we do it when we don't want to make a mess... just crack them off a little, let the oil drain back down and once it stops take them fully off and refill them
while I know it's not the same thing, it's more or less the same theory so it might just work out for you _________________ // '73 Thing "Jeep Zerstörer" currently being restored / kustomized
// '07 Rabbit taking over daily driver duties
1600s of air-cooled German muscle! |
FreakCitySF Samba Member
Joined: June 08, 2004 Posts: 642 Location: San Francisco
Posted: Sun Jul 01, 2007 7:54 pm Post subject: |
I wonder if any company ever made a heatsink that could fit on the oil filter.
Just a thought. |
Posted: Sun Jul 01, 2007 10:16 pm Post subject: |
I started to bolt in the very cool Tangerine Racing exhaust manifold this evening:
#$%#$%!#~! Found out that it doesn't clear the torque bar!
I think I can relocate the lower mount and make it work, move the mount farther back and lower - pivoting off the side after grinding out the outer tranny carrier lip and getting the upright through that loop... but that means pulling out the engine and tranny again, and not being sure if it'll fit until it's all in again, and hoping that I've got enough distance on that turnbuckle to reach the new location - if not, re-re-make the upper mount. Gaaa! Two steps forward, one back.
saddlesore1 Samba Member
Posted: Mon Jul 02, 2007 8:22 am Post subject: |
Very nice. questions:
1. What fan shroud is that it look nice
2. Why the trani support?
3. Why the engine cooler in that location rather than than in the side louver vents with a fan?
Regards
Saddlesore |
Posted: Mon Jul 02, 2007 8:47 am Post subject: |
I think I can relocate the lower mount and make it work. |
Hmmm... I don't think that'll work. That would only move it forward 1/8" and allow the mount off to the side, but it probably still won't clear. I think I have to fab my own lower torque bar mount. Or maybe I'll just sell the entire setup (it looks nice!) and go with a rear traction bar instead.
Ah well, I'm going on vacation tomorrow for a week, so I'll have a few days to ponder it. |
Posted: Mon Jul 02, 2007 9:08 am Post subject: |
saddlesore1 wrote: |
Very nice. |
Thanks!
1. What fan shroud is that it look nice |
It's a DTM (Down The Middle) shroud originally designed and built long ago by Joe Locicero. When Joe passed away, Jake Raby acquired the rights to build it, and he now sells them as kits or as part of his "turnkey" engines.
http://www.aircooledtechnology.com/store/home.php?cat=248
2. Why the trani support? |
That engine should turn as much as 190HP and the stock tranny mounts were not designed to carry that much torque. A fast start may cause them to snap back and forth creating wheel hop and hammering on everything in the drive train. Additionally, I'd like this to be able to do some mild offroading, and the slight additional weight combined with a few heavy bounces can crack an unsupported frame horn.
3. Why the engine cooler in that location rather than than in the side louver vents with a fan? |
The idea is to get the heat out of the engine. If it were in the side vents, then the heat would blow right back into the compartment, through the stock cooler and also over the heads. Where it is now, it'll exhaust the heat under the car into the air stream where it shouldn't get re-consumed by the engine. Additionally, since the air doesn't flow as smoothly through a cooler as it does through the vents, less air would get into the engine compartment. Adding a fan may cause cavitation which would make the situation even worse.
Type2 owners don't put the external coolers over the vents, they're fully outside the air system on the side of the bus. I could have done that too, but I think it's an ugly look. |
74 Thing Samba Member
Posted: Mon Jul 02, 2007 9:11 am Post subject: |
Ian, that is looking good!!! Can't wait to see the final product and once you get it dialed in how you like it. What is the R&P in the tranny?
Also, be sure your filter has an anti-drain back valve in it or all of the oil will drain out when you are parked and when you start up your engine there will be a brief moment of lack of oil pressure do to this-don't ask me how I know.
Put in thos trailing arms as well-hahaha-jk, good job on all of that work! |
Posted: Mon Jul 02, 2007 5:10 pm Post subject: |
74 Thing wrote: |
What is the R&P in the tranny? |
Not sure.
74 Thing wrote: |
Also, be sure your filter has an anti-drain back valve in it or all of the oil will drain out when you are parked and when you start up your engine there will be a brief moment of lack of oil pressure do to this-don't ask me how I know. |
I understand that most of them do. This fascinating site:
http://minimopar.knizefamily.net/oilfilterstudy.html
Shows the valves inside the filters, and he rates them. I picked up the Bosch before seeing his site, but it clearly has a drain-back valve.
74 Thing wrote: |
Put in thos trailing arms as well |
Naw, rear-wheels are overrated |
