sparkleplenty Samba Member
Joined: January 09, 2008 Posts: 1110 Location: California
Posted: Wed Dec 11, 2013 4:23 am Post subject: |
^^^ ....No doubt brother, I'm with you. _________________ '56 European Oval Ragtop-Stock
'56 Karmann Ghia Coupe-Stock
'59 Italian Series I Li150 Lambretta-Stock
"Give a man a fish, feed him for a day. Teach a man to fish, feed him for a lifetime."
"Only when the tide goes out do you discover who is swimming naked." |
Posted: Wed Dec 11, 2013 4:29 am Post subject: |
retrowagen wrote: |
cseay1 wrote: |
sactojesse wrote: |
Tonyorlo wrote: |
I'm wanting to see if anyone has these 8 spoke steel wheels on their ghia? I think I am going to go with them and want an idea on how they look.
Offset doesn't look very favorable for use on a ghia, particularly the very limited rear fender clearance. I typically see those wheels on baja bugs. |
Here ya go .. using them for mock up purposes on the back of my 68, currently with original long axles. Going to swap to short axles and see how they sit, and then use them to calculate my backspace when I get my custom wheels. Note: they stick the tires out the fender so I had to lock the suspension to keep the tires from tearing up the body.
Yikes, I always connotate that style of wheel with either a travel trailer, a 1970's Jeep, or the wall display at Manny, Moe, and Jack's... |
^^^Well said...Actually, I was thinking of the wheel displays at the Montgomery Wards tire center... _________________ '56 European Oval Ragtop-Stock
cseay1 Samba Member
Joined: March 22, 2012 Posts: 1341 Location: Elkwood VA
Posted: Wed Dec 11, 2013 6:09 am Post subject: |
* ADDITIONAL DISCLAIMER: I am only using these wheels for mock-up purposes only (because they were cheap 15x6 rims that bolted on - and if I needed to cut out the centers and turn them into backspace gauges no big deal). I in no way support endorse or recommend running these rims on your Ghia! |
KGCoupe Samba Member
Joined: July 01, 2005 Posts: 3580 Location: Putting the "ill" and "annoy" in Illinois
Posted: Wed Dec 11, 2013 7:32 am Post subject: |
cseay1 wrote: |
OK, since no one is holding back how they really feel, let me be the first to say that I think those wheels certainly have their use on a Karmann Ghia.
Tell me what other wheel would look even half as good on a Baja Ghia?
lawn ninja Samba Member
Joined: January 02, 2006 Posts: 1009 Location: Round Rock, TX
Posted: Wed Dec 11, 2013 7:55 am Post subject: |
KGCoupe wrote: |
Anything else. Centerlines, some type of bead lock wheel, anything. _________________ Jason
My 64 1500 S Notchback project here
My 58 sedan project here
My 63 Ghia here |
sactojesse Samba Member
Joined: November 21, 2006 Posts: 2655 Location: Sacramento, California, USA
Posted: Fri Dec 13, 2013 5:19 pm Post subject: |
cseay1 wrote: |
sactojesse wrote: |
Tonyorlo wrote: |
_________________ 1966 Karmann-Ghia convertible |
Tonyorlo Samba Member
Joined: June 03, 2013 Posts: 182 Location: Glen dale wv
Posted: Wed Jan 01, 2014 4:31 pm Post subject: |
David, where did you get those wheels at? Do you know the offset/backspacing of them? Could you update me on how they fit when you get the short axles in?
Haha I thought everyone was going to fall in love with them and want them, I guess I was wrong? |
srobinson Samba Member
Posted: Wed Jan 01, 2014 6:37 pm Post subject: Rader 17 |
Here 17s all the way around. 205/40R17
JMM930 Samba Member
Joined: January 14, 2011 Posts: 2 Location: Auburn, WA
Posted: Mon Jan 27, 2014 1:15 pm Post subject: fuchs 2 liter wheels on air cooled VW |
Hi there,
I was wondering how you managed to fit the cebter caps over the axle nuts in the rear. did you use 3/8 wheel spacers and longer studs? Did you shorten the stub axles a bit? The stock caps don't come close to being deep enough on my '73 ghia.
Any help / guidance appreciated - thanks |
Posted: Wed Jan 29, 2014 8:25 pm Post subject: |
Ive been searching for awhile on this subject but haven't came up with much. Any chance I can fit 8" wide wheel under the rear of a ghia, and 7"s under the front? 15" diameter. I'm going to flare both the front and rear.
Will I be safe if I run 4.5" back spacing? Im assuming its possible to have a little more back spacing on the rear, what about the front? |
varagon Samba Member
Joined: November 03, 2013 Posts: 116 Location: SE Kansas
Posted: Sat Feb 08, 2014 10:19 am Post subject: |
I have this:
I was told they are aftermarket and somewhat interesting/desirable. Thoughts? _________________ 1973 Karmann Ghia Convertible |
jpstine Samba Member
Posted: Sat Feb 08, 2014 9:37 pm Post subject: |
Lemmertz - called 'Baja' wheel or Marathon
Workin on center caps _________________ “Sometimes you have to be really high to see how small you really are, I’m going home now.” Epic Felix Baumgartner quote.
1960 SO-23 Westy
1974 Ghia Vert
1970 Ghia Hardtop
1962 FC150 Willys
1950 GR22 Massy Harris
1945 VAC Case |
malley56 Samba Member
Joined: January 29, 2006 Posts: 255 Location: Martinsville, VA
Posted: Sun Feb 09, 2014 8:41 am Post subject: Re: fuchs 2 liter wheels on air cooled VW |
JMM930 wrote: |
Hi there,
I'm having the same issue... This should help
http://www.thesamba.com/vw/forum/viewtopic.php?t=412506&highlight=spacer |
noslzzp Samba Member
Posted: Wed Feb 12, 2014 2:50 pm Post subject: |
low light with 17x8s up front.. _________________ Introducing the Basilari 306R.. A low light Ghia, performance chassis and 300HP boxer six.
http://www.basilari.com/category/buildupdates/ |
Brassneck Samba Member
Joined: November 17, 2012 Posts: 420 Location: Seattle
Posted: Wed Feb 12, 2014 5:04 pm Post subject: |
noslzzp wrote: |
low light with 17x8s up front.. |
Any better pics of the set up? Perhaps a side view?
Also, what tire sizes?
Thanks, |
Posted: Fri Feb 14, 2014 9:56 am Post subject: |
Brassneck wrote: |
noslzzp wrote: |
Thanks, |
Setup is Mendeola based with some creative tweaks on the front end.
205/40/17's up front
215/40/17's in the rear. _________________ Introducing the Basilari 306R.. A low light Ghia, performance chassis and 300HP boxer six.
Posted: Fri Feb 14, 2014 3:06 pm Post subject: |
noslzzp wrote: |
215/40/17's in the rear. |
Thanks! Must have been very "creative" to get those to fit.
I've always liked those rims, but have debated getting them as I'd prefer the 5 spoke version I think...(But I'm not ready to change out my hubs anytime soon). However seeing the 4's on yours, I may have to reconsider... Do you have a profile shot of them on the car by chance?
Thanks again, |
scottkrough Samba Member
Joined: July 06, 2012 Posts: 166 Location: Nor Cal Garlic Capitol of the world
Posted: Fri Feb 14, 2014 10:27 pm Post subject: |
On most other forums when posting up in threads were it is asked what wheel are you running the customary response is with information that is useful.
pictures of your setup
manufacturer
name of wheel
size of wheels
back spacing/offset
tire size and manufacturer
any issues with rubbing
suspension type and any lowering and how
this might actually stop the constant request for information that is never given _________________ Scott
Check out our 63' Ghia Build
http://www.thesamba.com/vw/forum/viewtopic.php?t=519643 |
John Moxon Samba Moderator
Joined: March 07, 2004 Posts: 13957 Location: Southampton U.K.
