My "mild" 1600 build.
Forum Index -> Performance / Engines / Transmissions Share: Facebook Twitter
beetleboy58
Samba Conquestador
beetleboy58 is offline
PostPosted: Sat Jul 07, 2007 7:47 am    Post subject: My "mild" 1600 build. Reply with quote
This is mainly for all those who post the "how do i get more power from my 1600"topics.
This started as an AE case dual port 1600 that came in my 67 westy when I bought it. I wanted a little more go, and basically had a budget of about a thousand dollars to work with,didnt want to spend so much that I wished id just built a big engine in the first place.
The upgrades are-
Solex 35mm carbs from aircooled.net-(highly recommended )
with the bigger venturies and custom jetted.
ACN svda,custom curved to the carbs.
DRD L3 ported heads, custom cut to keep stock compression.
Bugpack header and quiet pack-
If you are adding the totals up,i did go a little over but wanted to do it right.
The installation of all this went VERY smoothly,If anyone is thinking about these carbs they are definetly worth trying. I did shim up the fuel pump a little,and had to clearande the fan shroud on the right side air snout for the throttle arm,but it went together great.After setting the static timing and just guessing on the throttle plates(1 turn after touching the stop) the engine started easily,and in ten minutes it was timed,synched, and adjusted perfectly. Timing is at 8 degrees at idle, as soon as you crack it off idle it goes right to 20,(both carbs hooked to vaccum) and maxes about 33.I'll fine tune that when it goes on the road. You definetly need to run a balance tube between the carbs-see mharney for pics-and I ran a breather hose to the right air cleaner(who needs a breather box on a 1600?)which i may tee and run to both.
Ill be happy to answer any questions about the setup.I plan to add some 1.4 rockers and the road test results will be in soon! I have routed every thing a lot cleaner and installed all the tin,so back off! j/k...
The Man of All Men
The Man of All Men is offline
PostPosted: Sat Jul 07, 2007 8:33 am    Post subject: Reply with quote
You got alot goin on in that engine compartment. Clean up the wiring and hoses to make it look sanitary Confused
beetleboy58
Samba Conquestador
PostPosted: Sat Jul 07, 2007 9:54 am    Post subject: Re: My "mild" 1600 build. Reply with quote
darkdune
darkdune is offline
PostPosted: Sat Jul 07, 2007 9:57 am    Post subject: Reply with quote
looks good
krusher
krusher is offline
PostPosted: Sat Jul 07, 2007 10:58 am    Post subject: Reply with quote
I would like to see one of the vw mags do a 1600 upgrade shoot out.
(mabye they allready have)
Get a stock 1600 dyno it and them slowly add the usual basic add-ons and see what the dyno says.
I ould say the heads are where you spend you money wisest, i would ove to see a dyno comparison of all your mods with stock heads and withthe DRD ones.
Very Happy
The Man of All Men
PostPosted: Sat Jul 07, 2007 11:26 am    Post subject: Re: My "mild" 1600 build. Reply with quote
beetleboy58 wrote:
Alittle snappy today Laughing
mailman
mailman is offline
PostPosted: Sat Jul 07, 2007 2:42 pm    Post subject: Reply with quote
I'm contemplating a similar project, but with Kadrons instead of Solexes. I already have them, and they've just been worked over by A. J. Sims. I also bought the new SVDA he sells, curved to match the carbs. I already have the same exhaust you are using....it's old, but should clean up nicely. I'm planning on a fresh short block with balanced, counter-weighted crank and new bearings and lifters.
My questions are about cams, rockers, and heads. Stock valves and ratio rockers, or mild cam and stock rockers? And as to heads....will fresh stock heads be good, or would I be better off with something else?
Cost effectiveness is a concern, but ultimately drivability is the deciding factor for me.....
'64 Bahama Blue Beetle / steel sunroof
'64 Bahama Blue Beetle Sedan (future ragtop)
Towel Rail
Horizontally Opposed
Towel Rail is offline
PostPosted: Sat Jul 07, 2007 3:13 pm    Post subject: Reply with quote
Nicely done. How does it perform now?
1974 Thing -- under the knife
1967 Beetle -- spring/summer/fall driver
1996 Subaru OBW (EJ22, 5-speed, AWD) -- winter car, 3-seasons "don't feel like biking today" car
049 > 070 > 053 > 009
krusher
krusher is offline
PostPosted: Sun Jul 08, 2007 3:43 am    Post subject: Reply with quote
Well you want and answer, but then throw in cost effectiveness.
I would say a cam from the Cb cheater cam up to the engle 110 (depending on vehicle and driving style) and a good set of standard valave size ported heads.
Aj can sell you all you need and advise you.
vwdmc16
vwdmc16 is offline
PostPosted: Sun Jul 08, 2007 1:32 pm    Post subject: Reply with quote
my mild 1600 uses kads, header, hideaway muffler, and my 034 is connected now. it has stock internals but is much more snappy than stock
"Fiberglass is for boats and race cars-Steel is real-fix it right the first time"-Wolff
'72 Ghia: http://i111.photobucket.com/albums/n146/vwdmc17/100_1964.jpg
'72 Honda Z600
'81 Delorean
www.EVILGENIUSRACING.com
Michael Fischer
Michael Fischer is offline
PostPosted: Sun Jul 08, 2007 1:53 pm    Post subject: Reply with quote
This is a bone stock 1600 with 36 dells and a merged header.
Its a little screamer.
stan_tichomirov
stan_tichomirov is offline
PostPosted: Sun Jul 08, 2007 4:50 pm    Post subject: Reply with quote
Congratulations, good job. Did you keep short-block as it was, and just upgrade the top end? What are your fist impressions of the change, if you don't mind me asking?
I've done the same. First, I've upgraded stock 1600 with L3s and 1.25 rockers, then IDFs, then built a fresh 1600 from scratch adding a cam, then up'ed it to 1641. It's going strong, I've had ICTs and IDFs on it (IDFs now), and I even have a Mallory distributor on it now Rolling Eyes Problem is, I want more power Razz
It's a great cheap practice engine though, and pushes the car around very nicely. Can't wait to build my 2110 though.
Stan
Aircooled.net
Jansen Enterprise
My 1835cc build
My budget 2276 build
beetleboy58
Samba Conquestador
PostPosted: Sun Jul 08, 2007 4:53 pm    Post subject: Reply with quote
It's a great cheap practice engine though, and pushed the car around very nicely. Can't wait to build my 2110 though.
Stan
Yes,the cam,crank etc.are stock. Ive been working my ass off trying to finish the car so i can drive it,but i will probably be done in a week or two.
MURZI
MURZI is offline
PostPosted: Sun Jul 08, 2007 5:11 pm    Post subject: Reply with quote
I just built a 1600 as well, with a stock cam, counterweighted crank, lightened flywheel, port matched 043's, 40 idfs and a 010 dizzy. I used the euro 2 tip exhaust and it runs great!! more power than expected.
When building it I resisted the urge to do anything to it other than improve effiency. Now I have a great little stock engine with just a little umph. When I build my 2276 this will be the spare engine. The idea will to keep it complete with shroud, alt, clutch etc. for easy in and out swapping.
before the 010 swap-----by the way, with the move from 009 to 010 the engine feels alot more crsip and throttle responsive.
62 vert
69 Jim
69 Jim is offline
PostPosted: Sun Jul 08, 2007 7:05 pm    Post subject: Reply with quote
I screamed also. I screamed "YUCK, LOOK AT THAT CRAP!!!! Shocked
Hotrodvw
Hotrodvw is offline
PostPosted: Sun Jul 08, 2007 9:51 pm    Post subject: Reply with quote
Hmm.....this might be cheating, but here's my 1641 with 40 Dells, and a 110 cam. Be nice 69Jim. Wink
'67 Sunroof
Eric
78x94 with IDA's....oober fun
Horsepower is an addiction........Addictions cost
lots of money!
Hose & Fittings
69 Jim
69 Jim is offline
PostPosted: Sun Jul 08, 2007 10:14 pm    Post subject: Reply with quote
Laughing
That is clean. Wink
MURZI
MURZI is offline
What size vents are you running? Valves?
62 vert
Hotrodvw
Hotrodvw is offline
PostPosted: Sun Jul 08, 2007 10:17 pm    Post subject: Reply with quote
I probably should be running 28 venturis, but CB Perf. was out of them when I bought them. I installed 32's instead. It runs pretty well! Stock heads and valves. As it sits, it dyno'd @ 57+ rwhp. I figure it's in the 70+hp range at the crank.
'67 Sunroof
Eric
lots of money!
Hose & Fittings
Michael Fischer
PostPosted: Sun Jul 08, 2007 11:46 pm    Post subject: Reply with quote
Its been cleaned up a little better since that photo. That was before it was up and running. Thank you.
Reply to topic    Forum Index -> Performance / Engines / Transmissions All times are Mountain Standard Time/Pacific Daylight Savings Time
