cc79westie Samba Member
Joined: May 12, 2007 Posts: 468 Location: Greenport, N.Y.
Posted: Wed Jul 18, 2007 9:01 am Post subject: Fuel Tank Reseal /Reinstalling. FAQ |
Hey Everyone,
A couple of issues I'd like to throw your way and hopefully get some insight on:
I just got a replacement fuel tank for my 79 Westfalia (F.I.). The inside of this tank is very clean, but I still wanted to reseal the inside of it. The thing I found out is that there is a screen inside the tank (to filter junk out?) The guy who was going to reseal it said he can't do it because of clogging this screen up with the por15 sealer that is used. Is there any way to overcome this, or does that screen rule out any chance of resealing it?
Also I was told that the new tank (off a 78 bus with F.I.) would not fit through the bulkhead cover of my 79 because this tank was too long and too fat. I planned to lower the engine enough to give me the room I needed and get it out through the bulkhead. So the only way is to drop the engine all the way and getting the tank out from the bottom? I trust the 78 tank will fit ok in the 79 compartment? Thanks for any assistance on these 2 issues. |
davis911s Samba Member
Joined: July 07, 2005 Posts: 976 Location: Lethbridge, Alberta, Canada
Posted: Wed Jul 18, 2007 9:30 am Post subject: |
I can't help you with the POR and the inner screen question
But I can tell you that the 78 tank WILL fit in a 79 body, they are the same
Shawn _________________ "I choose to use CAA on old cars with character...instead of car payments on a new car "
1973 Westfalia, Camper Special with 75 FI. Automatic 003 . Non-pop top
1977 Porsche 911S Targa, 2.7 L with 5spd
1992 Passat G60 Syncro Wagon (SOLD)
1975 Westfalia (SOLD)
1979 Westfalia (SOLD) |
waterboy Samba Member
Joined: January 19, 2006 Posts: 233 Location: Lake county, california
Posted: Wed Jul 18, 2007 9:34 am Post subject: |
Sorry to hi-jack this but, when you remove a tank to seal it, what sealant do you use off the shelf that you can do yourself? Any special steps when doing my '70? |
Posted: Wed Jul 18, 2007 9:35 am Post subject: |
I always thought so too. It's good reassurance to hear it from someone else though. |
VWsArent4Hippies Samba Member
Joined: April 13, 2005 Posts: 3076 Location: The Bull City
Posted: Wed Jul 18, 2007 10:08 am Post subject: |
waterboy wrote: |
Eastwood sells a kit for 50 bucks, and POR has a kit too, but I don't know how much it is. I'm sure there's also others out there... _________________
aeromech wrote: |
in my opinion you don't know shit |
Randy in Maine Samba Member
Posted: Wed Jul 18, 2007 10:30 am Post subject: |
No sock in FI tanks (they all have 2 lines at the bottom of the tank 1 in and 1 out).
Best (and fastest) way to install in my opinion is to remove engine and slide it in. Don't forget the screws in the firewall attached from the bottom. |
Posted: Wed Jan 02, 2013 10:11 am Post subject: |
I have a 71 bay panel and took out the tank for rehab and the outlet on the bottom was not leaking but needed to be removed to slide out tank. this aluminum fitting had no O ring or seal that I found upon removal.
Does this just thread back on and seal itself or does it require an O ring or seal of some type? if so where can I get it? thanks. |
busdaddy Samba Member
Joined: February 12, 2004 Posts: 51057 Location: Surrey B.C. Canada, but thinking of Ukraine
