Land Speed Record in vw?
Forum Index -> Performance / Engines / Transmissions Share: Facebook Twitter
HoodRich
HoodRich is offline
PostPosted: Thu Jul 19, 2007 10:31 pm    Post subject: Land Speed Record in vw? Reply with quote
what would be the speed record for a vw aircooled vehical. Do we as vw owners have are own class as for salt flat speeds? I know it would be a challenge but I have a shop willing to fund and give me a belly tanker from a aircraft and Its about the size I would need to put a beam and seat and engine into it.
any input is much appricated.
clearsurf2001
Samba Vaccinator
clearsurf2001 is offline
PostPosted: Thu Jul 19, 2007 11:39 pm    Post subject: Reply with quote
Do some homework.
http://www.scta-bni.org/
Get ready for the injection Smile
Make sure it is coherent. Rodney
mharney wrote:
I think Glenn has an EMPI crank in his engine.
nextgen
nextgen is offline
PostPosted: Fri Jul 20, 2007 5:46 am    Post subject: Reply with quote
On Sept 15Th 1996 Jeff Stahl took his 65 Daily driver to Bonniville.
It was powered by a 1970cc Type IV.
He broke the land speed record in the Sub Two Litre Class for a steel bodied car.
150.506 MPH!! The article says Other VW powered machines may have been faster but none have been close with the basic stock steel body, and the car is Street Legal.
site: www.nextgen-usa.com
email: [email protected]
[email protected]
The Type IV Upright Conversion Manual
HoodRich
HoodRich is offline
PostPosted: Fri Jul 20, 2007 6:31 am    Post subject: Reply with quote
Thanks for the help and Info. I would run a stock motor for driving the car and testing it then which to a engine and tranny set up that would get me where i need to go. That 150mph might be a fun challange.
nextgen
nextgen is offline
PostPosted: Fri Jul 20, 2007 8:09 am    Post subject: Reply with quote
Another article said he welded the front hood shut and added lead weight to keep it down. I guess in the front.
Hey I have a Type IV in my bug 2.0 from a 914 I know it will do 120 easy but it said he had special gearing to reach that speed.
The Type IVs normally have big power come in above 60mph. Which makes them great road cars. The only thing is you have to make your bug so it can handle the speeds. Mine has dropped front spindles, front and rear anti sway bars, 4 wheel discs, KYB gas ajust shocks, 195's on all 4 wheels. All that and I don't like going over 90mph.
[email protected]
Scott H
Samba Luddite
Scott H is offline
PostPosted: Fri Jul 20, 2007 8:29 am    Post subject: Re: Land Speed Record in vw? Reply with quote
Official land speed records are by engine size and vehicle type, not by make. Any VW specific records would be un-official as far as I know.
Scott
oc92 wrote:
I like the soul of an old car to be visible...
nextgen
nextgen is offline
PostPosted: Fri Jul 20, 2007 7:57 pm    Post subject: Reply with quote
Scott you are right not vehicle type. Like I said"He broke the land speed record in the Sub Two Litre Class for a steel bodied car".
[email protected]
Arnolds64
Arnolds64 is offline
PostPosted: Sat Jul 21, 2007 2:07 pm    Post subject: 150! Reply with quote
If any of you read the in How to Hot Rod VW's book about the VW's Aero abilities, it ain't good. They say that the original cars are raked with the front higher to compensate for the rear end that will come around easily above i believe like 80? I would imagine he had some aero mods? Our bugs are shaped like a wing for lift unfortunately. Audi TT had a spoiler retrofitted to them because they were leaving the Autobahn in the air at over 130 a few years ago. Our bugs are even rounder than them. I have friend that has some turbo drag bugs. At about 100 or 1/8 or more you can see them lifting as they go faster. Sorry not me!!
64 Bug, White, 2017, Dual Weber 44's, Engle 130/Engle lifters, Home P&P'd 40X35 heads, CB 4340 nitrided crank, Eagle knock off H Beam 5.5" rods, Lowering Beam, Rancho Trans, Traction Bar. 225X60's rear, 145's front on Porsche Chrome Nipple Wheels.
nextgen
nextgen is offline
PostPosted: Sat Jul 21, 2007 6:33 pm    Post subject: Reply with quote
I have seen photos the story is he welded the front hood shut, put lead either in front or on the passengers side for balance and the car had a big wing on the back. The wing made him automatically ineligible as a production bodied aircooled VW. He had to run G/FUEL Altered class. He was pushing 196hp at 7500 rpms They said " to run a VW BUG at that speed level takes a special mix of madness and driving brilliance. Roll ON".
This was in UK's Volksworld Mag. Aug. 1996
[email protected]
Bugman Jeff
Bugman Jeff is offline
PostPosted: Sun Jul 22, 2007 12:31 pm    Post subject: Reply with quote
If you're actually going to do it, get an SCTA rule book and read it THOROUGHLY atleast 3 times. Build the car around the rules, DON'T build it then find a class to run in.
Restorer of Porsche Speedster 80486 Smile
Reply to topic    Forum Index -> Performance / Engines / Transmissions All times are Mountain Standard Time/Pacific Daylight Savings Time
