Please help. Valve noise???
oval_and_out
oval_and_out is offline
PostPosted: Thu Jul 19, 2007 6:23 am    Post subject: Please help. Valve noise??? Reply with quote
One valve on #3 piston is making sucking and blowing noises which sound like a footpump blowing up a lilo. Does anyone know what this is and how serious a problem???
tkelley
tkelley is offline
PostPosted: Thu Jul 19, 2007 6:30 am    Post subject: Reply with quote
Dildo? Shocked
How can you tell it's coming from the valve? Does the sound
seem like it's coming from the head? Did you do a valve adjustment?
We really need more info.
Tom
Glenn Premium Member
Mr. 010
Glenn is offline
PostPosted: Thu Jul 19, 2007 6:38 am    Post subject: Reply with quote
Sounds like the spark plug was blown out.
Glenn
Member #1009
#BlueSquare
oval_and_out
PostPosted: Thu Jul 19, 2007 6:53 am    Post subject: Reply with quote
I had just done a valve adjustment. I could hear a noise with the engine running so i checked the valves. All looked fine, and adjusted freely. As i was turning the pulley by hand i could clearly hear, sucking and blowing as the valve in #3 (the one closest to #4) was raiseing and lowering.
oval_and_out
PostPosted: Thu Jul 19, 2007 7:50 am    Post subject: Reply with quote
would it be dangerous to drive it with the valve leeking air?
Banzai KG
Banzai KG is offline
PostPosted: Thu Jul 19, 2007 11:41 am    Post subject: Reply with quote
Either you have a loose head or a burnt valve....most likely a burnt valve.
Jim Kikuchi
Sunnyvale (near San Jose), CA
1964 Karmann Ghia coupe
V.V.W.C.A. - Golden Gate Chapter: http://www.ggcvvwca.org/
B.L.T.N. (Better Late Than Never) late model VW Club (San Jose/Santa Clara, CA): https://www.facebook.com/groups/bltnvw/
NorCal Aircooled Group (NAG) Facebook Goup: https://www.facebook.com/groups/NAGVW/
Blaubus
Blaubus is offline
PostPosted: Thu Jul 19, 2007 11:58 am    Post subject: Reply with quote
an intake valve burnt? Confused
Banzai KG
PostPosted: Thu Jul 19, 2007 12:21 pm    Post subject: Reply with quote
Ok...then a loose valve seat.
Jim Kikuchi
Blaubus
Blaubus is offline
PostPosted: Thu Jul 19, 2007 5:30 pm    Post subject: Reply with quote
broken spring perhaps
EZGZ
EZGZ is offline
PostPosted: Thu Jul 19, 2007 5:34 pm    Post subject: Reply with quote
Don't fret. If it's gone its gone.
How does it drive?
Time to start setting a little money aside for some head work.....
I have a cookie jar and when I need something in the future thats not real expensive I start throwing my change in there. When I buy stuff I always use paper so I get change back to throw in the cookie jar.
It doesn't take long to add up
64 custom Ghia, 66 Bug, Sandrail, Barrien tub
Vayabroder
Vayabroder is offline
PostPosted: Thu Jul 19, 2007 9:03 pm    Post subject: Noise Reply with quote
Worthwhile suggestions; here's another one (from my own experience): check for bad intake gaskets.
oval_and_out
PostPosted: Sun Jul 22, 2007 10:05 am    Post subject: Reply with quote
Thanks for the tips. Have been at bug jam uk all weekend so no time to check. Spring is fine, heads are new, but maybe the valve burnt or not seating correctly. I'm gonna check with the rockers off if valves are lining up straight. i really dont know much? im kinda learning as i go along.
Banzai KG
PostPosted: Sun Jul 22, 2007 12:35 pm    Post subject: Reply with quote
If you have a compression or a leak-down gauge, that would really help.
Leak-down gauge:
What Is An Engine Leakdown Test? - http://www.aa1car.com/library/leakdown.htm
Compression Test Gauge:
HOW TO CHECK COMPRESSION - http://www.aa1car.com/library/compression.htm
Jim Kikuchi
