Goranothos Samba Member
Joined: September 04, 2005 Posts: 413 Location: East Tennessee
Posted: Sun Jul 22, 2007 12:38 pm Post subject: filter pump with stock muffler |
Very soon I will be using my '70 for a daily driver, approx 12000 miles a year, and I would like to install one of these so I can extend my oil change intervals to 3k:
http://www2.cip1.com/ProductDetails.asp?ProductCode=VWC%2D043%2D115%2D115
I am running a stock muffler with a 1600dp. Will the filter pump fit, or am I out of luck? |
nc68bugman Samba Member
Joined: August 12, 2006 Posts: 681 Location: Beaufort, NC
Posted: Sun Jul 22, 2007 1:25 pm Post subject: |
No it won't fit! Went through that problem Myself last year! Read the ad, it explains this, I also learned first hand! Scott |
Posted: Sun Jul 22, 2007 1:34 pm Post subject: |
Ad doesn't explain anything. "May interfere with stock original mufflers." "May" means it might or might not. Who knows? |
Eric&Barb Samba Member
Joined: September 19, 2004 Posts: 24757 Location: Olympia Wash Rinse & Repeat
Posted: Sun Jul 22, 2007 1:51 pm Post subject: |
Hi Goranothos,
"May" if the heat riser tube on the left front interfers with the filter used. Some modern day maker/s of "stock" mufflers have switched this tube to the right side.
http://www.thesamba.com/vw/forum/viewtopic.php?t=242504&highlight=filter+pump _________________ In Stereo, Where Available!
Posted: Sun Jul 22, 2007 1:55 pm Post subject: |
Sorry, should have elaborated, I had interference from the heat riser tube which dented in the filter and wouldn't allow removal of filter plus the fact that is was laying on the filter soaking up more heat, that was with a stock og muffler and risers! Scott |
73BuzzBomb Samba Member
Joined: December 14, 2003 Posts: 895 Location: Baldwin/Smyrna, GA
Posted: Sun Jul 22, 2007 2:34 pm Post subject: Re: filter pump with stock muffler |
Goranothos wrote: |
I would like to install one of these so I can extend my oil change intervals to 3k: |
How often are you changing the oil now? You can go 3K miles without the filter. |
Posted: Sun Jul 22, 2007 2:56 pm Post subject: |
Been changing oil every 1k miles, but only going 3k a year. Gonna switch it to a daily driver which will up it to 12k a year, most of which will be 60mph highway driving. Think I'll be OK with 3k oil changes with just the strainer?
Thanks for the info, guys. I have the heat riser tube on the left, so looks like it will interfere with the filter pump. Gonna have to either leave it stock or get a full flow system with rubber hoses. |
birddog1 Samba Member
Posted: Sun Jul 22, 2007 3:25 pm Post subject: |
Goranothos wrote: |
Changing at 1K is overkill. Why not change at 2K and split the difference? |
chicagovw Samba Member
Joined: January 06, 2007 Posts: 1419 Location: Chicago IL/CHandler AZ
Posted: Sun Jul 22, 2007 4:17 pm Post subject: |
VW recommended every 3,000 back in the old days. Oil technology has greatly improved since then. I am sure it will be fine with 3,000 mile intervals. I do mine every 3 to 5,000 with no issues so far. |
Posted: Sun Jul 22, 2007 4:42 pm Post subject: |
chicagovw wrote: |
It's not the oil tech, but the fact the oil carries any small grit or metal shavings through the bearings. Having taken enough engines apart after a few tens of thousand miles since rebuild to find bearings scored by this stuff. With filter system the main bearings look brand new and each rod bearings only slightly polished in the thrust/pull directions of the piston. The less wear in the bearings, the less drop in oil pressure, and more longevity your engine can have.
Plus all the other surfaces that rub in the engine like P&Cs, cam lobes, and tappets, etc. all have that much less wear.
The oil filter/pump (Claude's Buggies one is best one made today) offers this protection, but without the oil hoses/lines that can fail on a remote filter.
With a filter setup one does not need to clean the sump plate. All that crud goes in the filter!! _________________ In Stereo, Where Available! |
DrDarby Samba Member
Joined: May 12, 2004 Posts: 6534 Location: Northern Illinois
Posted: Sun Jul 22, 2007 4:48 pm Post subject: |
If your stock muffler has the heat riser tube on the right side the pump will be fine. Many models used the tube on the right vs the left side. I just bought an NOS original German muffler here on the classified this week that has the tube on the right side. It was a 49 state 1974 muffler. I'll only need to put a pipe plug in the EGR port.
I've used mufflers with the tube on the left side but you must rebend the tube closer to the muffler and use a shorter oil filter.
With all that said although I agree a filter is a fine investment, VW's oil change intervals from way back when were already 3000 miles and I've routinely gotten 150,000 plus miles out of stock engines by simply changing the oil & cleaning the screen every 3000 miles and adjusting the valves every other oil change. _________________ Midwest Autosavers, Inc. Woodstock, IL |
a.wilson Samba Member
Joined: January 11, 2007 Posts: 2033 Location: Georgia
Posted: Sun Jul 22, 2007 5:30 pm Post subject: |
DrDarby wrote: |
I just bought an NOS original German muffler here on the classified this week that has the tube on the right side. It was a 49 state 1974 muffler. |
You lucky dog!!!.
Nothing like finding good 'ol genuine parts! _________________ Be kind to all critters. America's "H8TERZ" can drink sludgy used Motor Oil!
oemwolf |
webwalker Samba Member
Joined: January 26, 2006 Posts: 2803 Location: Mount Laurel, NJ
Posted: Mon Jul 23, 2007 7:50 am Post subject: |
OK, so here's what we know:
Either the pump has to be modded to clear a LEFT heat riser tube on stock mufflers
OR
You use a stock muffler with a RIGHT heat riser tube and use any damn full flow filter-pump you want.
So can anyone recommend a STOCK style muffler manufacturer and model that has a RIGHT heat riser tube?
M _________________ "Consistent maintenance with quality products is the cheapest warranty you'll ever need."
1977 CE1 Transporter Deluxe, Subaru EJ22, Skills Cooling, Steedle HD 091 w/ GuardT .82 4th
Click to view image |
cdydatzigs Samba Member
Joined: March 21, 2007 Posts: 307 Location: San Diego, CA
Posted: Mon Jul 23, 2007 7:54 am Post subject: |
DrDarby wrote: |
How much does anyone want to bet that the 50th state was California? _________________ -- Steve
'69 Beetle Autostick
"Discovered by the Germans in 1904, they named it San Diego, which of course in German means a whale's vagina." |
Posted: Mon Jul 23, 2007 7:55 am Post subject: |
Hoooeee!
No bet. _________________ "Consistent maintenance with quality products is the cheapest warranty you'll ever need."
abranz Samba Member
Joined: August 15, 2005 Posts: 116 Location: Osburn, Idaho
Posted: Tue Jul 24, 2007 6:01 pm Post subject: |
Aitcooled .net sells the right OE german muffler which will not interfere with a filterpump. I have it on both of my beetles which have filterpumps.
Anthony |
