DONGKG The Araneta Boys
Joined: August 28, 2006 Posts: 5475 Location: Cainta, Rizal, Philippines, "A Certified Type 3 and Karmann Ghia Maniac"
Posted: Sun Jul 29, 2007 9:36 pm Post subject: Hey, I like the wheels of your Type 3! |
When it comes to wheels, every Type 3 enthusiast has his own preference. One may use stock rims for that period appeal and for the preservation of the historical value of his Type 3; on the other hand, one may use aftermarket wheels to give his Type 3 a personalized touches and distinctive look that may create some lasting impressions.
Well, My '66 Type 3 Fasty (Sharky 2) sports an EMPI Sprintstars wheels. What about your type 3? Let us see some pictures please. _________________ '67 KG Cabrio (Mickey) ;
'66 Type 3 (Sharky 2)
'72 Type 2 Homey
'67 Splitty Bus
'65 beetle;'69 Country Buggy; '44 Kubelwagen (replica) TOOB MEMBER #20 |
Tram Samba Socialist
Joined: May 02, 2003 Posts: 22711 Location: Still Feelin' the Bern- Once you've felt it you can't un- feel it.
Posted: Sun Jul 29, 2007 9:59 pm Post subject: |
Stockitty, stock, stock, stock.
Nothing fits and looks like a stock wheel/ trimring/ hubcap. _________________ Немає виправдання для війни! Я з Україною.
Bryan67 wrote: |
vwfye Samba Member
Posted: Sun Jul 29, 2007 10:04 pm Post subject: |
stock w/trim rings on the 343
centerlines on the notch speedster
notchback had american racing 'lemans'
8 spokes are on the squareback _________________ 64 No'back Speedster "Pearl"
1980s Sand Dragster "The Plunger"
LME "Little Giant Killer 3" |
jaransonT3 Samba Member
Joined: January 01, 2005 Posts: 1262 Location: Dearborn, MI
Posted: Sun Jul 29, 2007 10:38 pm Post subject: |
I am running American Racing Aero wheels on my Sophy. 15x7 fronts and 16x7 rears. Re-drilled the drums and rotors for the 4x100mm pattern and pressed in studs.
_________________ Later,
John Jaranson
'66 Square
'69 Square
'70-1 Fasty
https://www.carartbyjohn.com
https://www.carartbyjohn.com/2024Invasion/ |
67stang302 SBS Hit Squad
Posted: Sun Jul 29, 2007 10:40 pm Post subject: |
Giovanna 17x7" Rims, Can't remember the model name but they discontinued them anyways. _________________
EverettB wrote: |
Hondaz rulez my lifez |
SBSeven 1 YR and still going
59 Kombi laying beam
64 type 34 |
vdub Samba Member
Joined: September 07, 2003 Posts: 442 Location: Valley Springs, Ca.
Posted: Sun Jul 29, 2007 10:42 pm Post subject: |
I am putting polished 8 spokes on my square. |
fasty69 Samba Member
Joined: November 28, 2006 Posts: 213 Location: CANADA
Posted: Sun Jul 29, 2007 11:20 pm Post subject: |
interceptors (kinda like empi 8 spokes, but a bit different, and rare)
_________________ Newest member of the family+New project
69 Fastback-Free of Rust |
vdub Samba Member
Posted: Sun Jul 29, 2007 11:37 pm Post subject: |
fasty69 wrote: |
Nice
I want to run 5 spokes but I am not giving up my disk's and 5 lug disks are outrages.
I almost considered adapters but they just don't look safe to me. |
vdub Samba Member
Posted: Sun Jul 29, 2007 11:44 pm Post subject: |
Nos that I think about it if I went with 5 lug I would have to use BRM's
Flat 4 of course. |
Posted: Mon Jul 30, 2007 12:38 am Post subject: |
jaransonT3 wrote: |
That is a rare wheels on your Sophy. Unique, that is. What car are those wheels equipped for? _________________ '67 KG Cabrio (Mickey) ;
'72 Type 2 Homey
'67 Splitty Bus
Posted: Mon Jul 30, 2007 10:21 am Post subject: |
DONGKG wrote: |
That is a rare wheels on your Sophy. Unique, that is. What car are those wheels equipped for? |
They are an aftermarket wheel for predominantly the front wheel drive vehicles that have fairly large positive offset. The 15x7 are 42mm offset. The 16x7 are 46mm offset, IIRC. Perfect for a Type 3.
I originally wanted to run American Racing Torque Thrust II wheels, but they don't come in an offset that is even close to being right for a Type 3. These wheels have a similar look and a good offset.
Glad you like them. _________________ Later,
John Jaranson
'66 Square
'69 Square
'70-1 Fasty
Air-Cooled Head Samba Member
Joined: October 15, 2002 Posts: 4070 Location: Chicago Suburbs
Posted: Mon Jul 30, 2007 11:16 am Post subject: |
jaransonT3 wrote: |
Re-drilled the drums and rotors for the 4x100mm pattern and pressed in studs. |
They say it can't be done Thinnes/weakens/etc/blah/blah. Is the secret sticking to a 4 lug pattern?
Currently, Porsche 2 Liters, but that may change quickly, depending on John's answer.
Fasty69
I’ve got rotating gallery of cars I like as a screen saver. Mostly VW’s, & almost all T3’s.
Yours is the first Fastback. Those Interceptors are SO much cooler than 8 spokes. _________________ Everything known to man has been written.
Readers are Leaders! |
Posted: Mon Jul 30, 2007 2:34 pm Post subject: |
Air-Cooled Head wrote: |
jaransonT3 wrote: |
Not in my experience. I have over 30K miles on my re-drilled drums and rotors without any problems what so ever.
I think the key is using the press-in studs, instead of drilling and tapping and continuing to use the lug bolts. Both the rotor and the rear hub have thickened areas where the threaded holes are for the lug bolts. I am sure this is to give the bolts enough thread engagement. If you rotate off the stock pattern by 45 degrees, you are in an area of each that is thinner, but still plenty thick for the press-in studs. I wouldn't want to drill and tap the thin area and rely on it for holding the wheels on. Maybe only half a diameter of thickness there....not enough.
Also, in the rear I am using the two drum retaining bolts, although I modified them to be a flathead so that they don't interfer with the wheel. I am using them since the 4x100 pattern is very close to the inner edge of the drum. I actually ended up with notches on the inner diameter rather than holes for the studs.
I think sticking to a 4 bolt pattern makes it much easier. If you rotate the pattern 45 degrees for the front rotors, you are in relatively flat area and one that is the same for all the studs.
In the rear, I rotated the pattern 22.5 degrees to avoid the drum retraining bolts. Again the thickness and shape of the hub is the same for all 4 studs.
If you go to a 5 bolt pattern, all of the studs will see a somewhat different thickness and shape on the back of the rotor/hub. Not really a big deal since you want to machine a nice flat for the stud to press against, but it is still a bit more work.
Again.....no issues for 30K miles. Go for it. _________________ Later,
John Jaranson
'66 Square
'69 Square
'70-1 Fasty
911Notch Samba Member
Posted: Mon Jul 30, 2007 2:38 pm Post subject: |
Flat 4/Enkei's with LanD Products billet center caps. _________________ 1963 Birch Green Notchback
1963 Gulf Blue Notchback - FOR SALE
1966 Sunroof 911 Powered Notch |
Posted: Mon Jul 30, 2007 3:28 pm Post subject: |
jaransonT3 wrote: |
I think the key is using the press-in studs, instead of drilling and tapping and continuing to use the lug bolts. |
That's about 1/3 the reason for even thinking about this
jaransonT3 wrote: |
Both the rotor and the rear hub have thickened areas where the threaded holes are for the lug bolts. If you rotate off the stock pattern by 45 degrees, you are in an area of each that is thinner, but still plenty thick for the press-in studs. |
So you'd rotate 45 degrees, just for the flatness, even if going w/ a 4x100 pattern? Theoretically, the same web could be used.
jaransonT3 wrote: |
Also, in the rear I am using the two drum retaining bolts, although I modified them to be a flathead so that they don't interfer with the wheel. I am using them since the 4x100 pattern is very close to the inner edge of the drum. I actually ended up with notches on the inner diameter rather than holes for the studs. |
And since I have rear discs, I won't have to worry about this? Just do the same as the front?
If that's the case, we be rolling 17s real soon!
Thanks! _________________ Everything known to man has been written.
Last edited by Air-Cooled Head on Mon Jul 30, 2007 3:31 pm; edited 1 time in total |
tomnotch Samba Member
Joined: October 22, 2004 Posts: 788 Location: Key Peninsula, Wash.
Posted: Mon Jul 30, 2007 3:30 pm Post subject: |
Looking Good ^^^^, Matt! _________________ Tom
DVKK
DSD, Dark Side Disciples
Progenitor |
Posted: Mon Jul 30, 2007 4:08 pm Post subject: |
jaransonT3 wrote: |
I think you have to rotate the 45 degrees. If you don't the holes for the studs will almost overlap the old tapped holes for the lug bolts.
130mm DIAMETER...65mm Radius.
100mm Diameter....50mm radius
only 15mm between the centers of the holes. My press-in studs and the original lug bolts are 12 or 14mm in diameter (i don't remember off-hand, but either way)....so not much material between the holes. _________________ Later,
John Jaranson
'66 Square
'69 Square
'70-1 Fasty
Posted: Mon Jul 30, 2007 4:27 pm Post subject: |
Thanks Tom! see you in a couple weeks. _________________ 1963 Birch Green Notchback
Posted: Mon Jul 30, 2007 4:34 pm Post subject: |
jaransonT3 wrote: |
jaransonT3 wrote: |
only 15mm between the centers of the holes. My press-in studs and the original lug bolts are 12 or 14mm in diameter (i don't remember off-hand, but either way)....so not much material between the holes. |
I rotated the 45 deg. and used 12mm screw in studs. I just slapped the rotors, hubs, drums into a CNC machine and had it drill and tap the new bolt pattern for 4X100mm I have logged 25,000 miles with 40 series tires (thin side wall) and have had no troubles with the new bolt pattern.
EverettB wrote: |
64 type 34 |
Russ Wolfe Samba Member
Joined: October 08, 2004 Posts: 25187 Location: Central Iowa
Posted: Mon Jul 30, 2007 5:17 pm Post subject: |
Before: Rubbed.
During:
After:
I have always prefered stock wheels. _________________ Society is like stew. If you don't keep it stirred up, you end up with a lot of scum on the top!--Edward Abbey
Gary: OK. Ima poop. |
