Spanky Samba Member
Joined: June 24, 2005 Posts: 82 Location: Martha's Vineyard MA and Cincinnati OH
Posted: Sun Aug 05, 2007 11:39 am Post subject: |
OK, what's a case insert or a stepped stud and how do they work?
And the studs: how do you "back them out"? Jam two nuts together at the end and turn them CCW? _________________ 1959 Renault Caravelle
1973 Citroen Maseratti SM
1974 Chevy Malibu Wagon
1979 Vespa Scooters (2), 1981 BMW R65
'73 Thingy. |
markie61 Samba Member
Joined: April 11, 2005 Posts: 583 Location: Northern Virginia
Posted: Sun Aug 05, 2007 12:43 pm Post subject: |
Spanky wrote: |
OK, what's a case insert or a stepped stud and how do they work? |
Here's a step stud http://www2.cip1.com/PhotoGallery.asp?ProductCode=VHD%2DN14%2D4521
An "insert" is a threaded hole threaded into a hole.
Both will require drilling and tapping the case.
Spanky wrote: |
And the studs: how do you "back them out"? Jam two nuts together at the end and turn them CCW? |
That's what I do.
Mark _________________ Whut is that-there Thang!?
Chicks dig my Thing - so what if it's little and yellow...!? |
wcfvw69 Samba Purist
Posted: Sun Aug 05, 2007 12:56 pm Post subject: |
Spanky wrote: |
If the damaged stud is sticking out still, grab it with a pair of vise grips and un-screw it. Remember "right for tight, left for loose". They sell new studs. If it's broken flush with the case then you will have to drill a hole in the stud and use an easy out to hopefully unscrew it. If it does unscrew, replace it with a new one. _________________ Contact me at [email protected]
The Samba member since 2004.
Spanky Samba Member
Posted: Mon Aug 06, 2007 5:49 am Post subject: |
Thank you Gents, for the link and for the advice. Since the studs are not broken, "only" stripped I'm going for the vise grip removal option.
I'll verify how many studs I need and order a couple more from Cip1.
Thanks again _________________ 1959 Renault Caravelle
'73 Thingy. |
