type 4 bus engine into beetle
Forum Index -> Performance - Engines/Transmissions Share: Facebook Twitter
superbtl
superbtl is offline
PostPosted: Thu Aug 02, 2007 6:04 pm    Post subject: type 4 bus engine into beetle Reply with quote
whats the differance between a type 4 bus or type 4 porsche engine. is it a good swap to throw a type 4 bus engine into a bug.
bugnut68
bugnut68 is offline
PostPosted: Thu Aug 02, 2007 6:27 pm    Post subject: Reply with quote
Probably want to do a search on this one, as it's been covered quite a bit. Jake Raby's the man to talk to when it comes to Type 4's...
View user's profile Send private message AIM Address Yahoo Messenger MSN Messenger Gallery Classifieds Feedback
superbtl
superbtl is offline
PostPosted: Thu Aug 02, 2007 6:43 pm    Post subject: Reply with quote
whats the major differance between the two type 4 engines
Glenn Premium Member
Mr. 010
Glenn is offline
PostPosted: Thu Aug 02, 2007 6:45 pm    Post subject: Reply with quote
The heads are a bit different.
Glenn
iRide4Sue.org Please Donate to fight Cancer. $25,000 raised in 2016, hoping for the same in 2017
werka
werka is offline
PostPosted: Thu Aug 02, 2007 7:53 pm    Post subject: Reply with quote
Check out this site.
http://forums.aircooledtechnology.com/
nextgen
nextgen is offline
PostPosted: Fri Aug 03, 2007 7:53 am    Post subject: Reply with quote
Go here and also and click on the index on the right of the page. All you whan to know
http://tunacan.net/t4/owners/
Sample: all the T-4 blocks are similar and rarely see wear.
Engines: 411 412 912e 914 72 and later buses.
The engines range in sizes from 1700 1800 and 2000 all stock.
the 2000 914 has different heads then the 2000 VW. Cranks and rods differ but all fit the case. 1700 and 1800 heads can be opened to receive 2.0 p/c's
Lifters and Push rod tubes can be replaced without removing the heads.
Being much larger then a T-4 a T-4 in a T-1 car runs very cool. Never an overheating problem.
The engine bolts into a T-1 car after an upright conversion easier then the original T-1 engine and no modifications to the body of the car.
OK go to the sites and read the rest, my fingers are getting tired.
Joe www.nextgen-usa.com
site: www.nextgen-usa.com
email: [email protected]
[email protected]
The Type IV Upright Conversion Manual
craigman
craigman is offline
PostPosted: Fri Aug 03, 2007 9:09 am    Post subject: Reply with quote
If it's a bus engine, be sure to check the heads for cracks. They live a hard life in a bus.
tuna
tuna is offline
PostPosted: Fri Aug 03, 2007 10:00 am    Post subject: Reply with quote
If you want to learn about the Type 4 engine, I'd like to point you to my web site:
Type 4: Secrets Revealed
I wrote it exactly for people interested in the Type 4 but had no clue about what makes the Type 4 different from a Type 1, and how to get the most from it.
Have a read and let us know if you have any questions.
Tuna
Click to view image
Tom's Type 4 Corner
EMPI Imp Homepage
1970 EMPI Imp
1969 Bug - 2056cc Type 4 powered Cal-Look'r
Randy in Maine
Randy in Maine is offline
PostPosted: Fri Aug 03, 2007 11:15 am    Post subject: Reply with quote
Suggestion:
Take that engine you have now over to Gregg's VW in Natick MA and have him dial in those carbs. Fix what you have first.
melville
melville is offline
PostPosted: Fri Aug 03, 2007 11:42 am    Post subject: Reply with quote
Randy in Maine wrote:
Suggestion:
You don't think a T4 wants to run through his 4.37 X 1.14 top gear? Just like Bus! How'd all that fancy stuff make it East of the Colorado river? When I lived back East, the local expert could tell the difference between SP and DP motors on a good day!
Like Randy said, dance with the one who brung ya (or the one you brung).
Later
Mel
2000 M Roadster
75 R75/6
65 Standard Micro
61 Sunroof
60 Sunroof
57 Sedan
superbtl
superbtl is offline
PostPosted: Fri Aug 03, 2007 1:15 pm    Post subject: Reply with quote
im not doing a type 4 my buddy just got one for $100. gregs in natick ....i will have to give him a call. natick is about 1 hr away i dont think the bug would make it without exploding unfortunately
Randy in Maine
PostPosted: Fri Aug 03, 2007 2:33 pm    Post subject: Reply with quote
Drive 50 all the way there.
Ask him what it would cost to gear it up enough so that you could actually drive it on the road.
superbtl
superbtl is offline
PostPosted: Fri Aug 03, 2007 6:53 pm    Post subject: Reply with quote
if i drive %) for 10 minutes my oil temps are about 230 degrees. nevermind driving 1 hr. i might just get it towed
Randy in Maine
PostPosted: Sat Aug 04, 2007 5:37 am    Post subject: Reply with quote
Call them up first and talk to him. He may point you someplace closer to where ever you are. He is going to want to know the details of the engine build (size, camshaft, heads, distributor and timing, valve sizes, compression ratio, valve train geometry, and who built it), so be prepared to answer those questions about it.
You want to be there as they are adjusting things so that you can learn out of this deal.
Be prepared to pay. When you are good at what you do, you do not have to work for nothing.
Reply to topic    Forum Index -> Performance - Engines/Transmissions All times are Mountain Standard Time/Pacific Daylight Savings Time
