Get Mad Now Samba Member
Posted: Wed Feb 02, 2011 3:57 am Post subject: |
PASHN8 wrote: |
GMN,
Thanks for your input. So you are saying that with:
Short Axles
1 inch drum spacers in the rear
Empi wide 5 disc kit rear
205 tyres
You STILL sometimes hit the plates on the inside or the body? How low are you running? Any pics of the car?
From what I can read the CB and Empi rear disc are zero offset if they come with the e-brake, non e-brake kits add an inch each side. |
I have the the kit with the e-brake......the tire only touches the spring plate when doin heavy cornering. I only know its happening because i smell burnt tire after a heavy turn...its not bad tho. Other than that no problems at all.
Thanks for the comments on the car.....i jus cleaned out my photobucket account and all my pics were removed from this topic. _________________ 64 Beetle |
bfrancis972 Samba Member
Posted: Wed Feb 16, 2011 6:36 pm Post subject: |
Hey gmn, thanks for the info about the tire size on my vert. Do you have any pictures of your tire/wheel setup? |
Posted: Wed Feb 16, 2011 6:41 pm Post subject: |
bfrancis972 wrote: |
If u click on my name and look at my classified adds my car is in there with a few pics. _________________ 64 Beetle |
Posted: Wed Feb 16, 2011 7:00 pm Post subject: |
Thanks gmn. What size are your tires? |
Posted: Wed Feb 16, 2011 7:02 pm Post subject: |
195/40/17 front
205/40/17 rear _________________ 64 Beetle |
ottvw Samba Member
Joined: February 28, 2006 Posts: 928 Location: Auburn,WA
Posted: Tue Dec 27, 2011 11:29 pm Post subject: |
I just bought my 67 back with the Escras. 4" narrowed beam with dropped disc brakes up front. I had to the adjust the steering stop out quite aways so the rim wouldn't hit the control arm. Has anyone came up with a solution to have a better turning radius? _________________ Save a tree eat a beaver |
DieSchnelleKafer Samba Member
Posted: Tue May 29, 2012 5:02 am Post subject: |
time to bring up an atient thread, does anyone know what happened to these wheels, i emailed the guy and he says they are sold out and that he will be running a new batch, i asked how long they are going to take but sadly he did not reply.. _________________ 1967 Karmann Ghia (Resto in progress...)
1956 Oval TypeIV |
Posted: Tue May 29, 2012 5:03 am Post subject: |
oh btw if anyone has a set they want to sell.. nows your time! _________________ 1967 Karmann Ghia (Resto in progress...)
1956 Oval TypeIV |
Mike Fisher Samba Member
Joined: January 30, 2006 Posts: 17970 Location: Eugene, OR
Posted: Tue May 29, 2012 9:34 am Post subject: |
You are gonna miss your prom night obsessed with the wheels! _________________ https://imgur.com/user/FisherSquareback/posts
69 FI/AT square Daily Driver
two 57 oval ragtops sold
'68 Karmann Ghia sold
PASHN8 Samba Member
Joined: January 30, 2011 Posts: 152 Location: Melbourne, Australia
3 Fold VW Samba Member
pfcmooney Samba Member
Joined: December 07, 2011 Posts: 219 Location: New Brockton, AL
Posted: Tue Jan 21, 2014 8:11 am Post subject: |
Beginning the fitment of the 17" Raders now. They fit perfect on my IRS pan as long as the wheels are perfectly straight. Doesnt rub the buckets or anything, but once I turn at low heights, the buckets hit, the through rod clamp nut hits and the fender with a 4" beam. I'm on Monroes in front.
4" Airkewld Beam
Monroe Air shocks
EMPI Disc Brakes (Front)
Ghia Rotors (Rear)
Aired Out...
_________________ Thinking comes from not knowing... |
PASHN8 Samba Member
Posted: Wed Feb 19, 2014 9:09 pm Post subject: |
What tyre sizes are you running there? Looks great!
Same question here for the '54
Set up is:
- 4" beam,
- CB 2.5" drop spindles front with matching Wide 5 discs
- JerFab 2.5" drop plates rear with CB wide 5 discs
Wheels are 17"x7" ET20, so clear the rear springplates without issue.
I'm thinking:
195 40 R17 FRONT
205 50 R17 or 45 or 40 profile REAR
I don't want silly stretch on the front, so will be staying away from anything slimmer than 185 40. I also realise I can't slam it silly with 17" x 7" so happy to run a 'guard clearing' height.
Sound ok? It's the rear sidewall height that i'm really unsure of. _________________ www.dinography.com.au - Dino!
1957 11-Window Split Bus
1954 3-fold Sunroof Oval Beetle
*** Looking for '56 Porsche T1 356A 1300 engine no. 22373 *** |
bjoy Samba Member
Posted: Thu Feb 20, 2014 5:12 am Post subject: |
these are obviously not raders, but i run 195/40's up front and 205/50's out back... 4 inch beam up front with drop spindles (ET40 on the wheels though)...
PASHN8 Samba Member
Posted: Thu Feb 20, 2014 5:16 am Post subject: |
Thanks for that, most appreciated
I ended up choosing 195 40 17 front and 205 45 17 rear. Getting fitted tomorrow, so hopefully will look good! _________________ www.dinography.com.au - Dino!
Posted: Thu Feb 20, 2014 6:16 am Post subject: |
I'm running 205/40's all around. Might end up going a little smaller up front possibly at a later date, not quite sure yet. _________________ Thinking comes from not knowing... |
Max Boost Samba Member
Joined: October 14, 2007 Posts: 38 Location: Los Angeles
Posted: Sat Mar 01, 2014 12:33 am Post subject: Is GR Wheels still in business??? |
Let's see if f anyone replies to this,
So i tried calling GR Wheels and no dial tone, also i emailed and no reply?? does anyone know who has them in stock. Or did he just go out of business any help would be great here thanks. |
Ace Samba Member
Posted: Sat Mar 01, 2014 8:38 am Post subject: |
GR pulls his ad here when he is out of stock. He did answer emails before when he was out of stock though. Never tried calling so I don't know about that. |
Posted: Sat Mar 01, 2014 7:55 pm Post subject: |
Ace wrote: |
Ok cool I was worried for a second there, ill wait another week or to for a response back thanks. |
Tom N. Samba Member
Joined: May 21, 2005 Posts: 781 Location: dReading, PennsylRAINia
Posted: Sun Mar 02, 2014 3:00 pm Post subject: |
FYI... The seller may be in the US... but the wheels come from Argentina or another country in South America as soon as you purchase them.... shipped directly to you. |
